Question about Intel Motherboard
New asus m3n72-d motherboard bios will not post
Built new system. asus mb. phenom 9950 be cpu. 4 gig g-skill 1066 ram. 2 asus 8800gt grfx cards. segate baracuda sata2 hd. 630 watt rosewill power supply. green led light comes on. all fans come on no monitor or beeps from bios. tried every thing. even RMA the mother board. same prob with new one. atx power is hooked up. tried diff power supply 480 watt okia same thing. cleared cmos. could it be bad processor? or Ram? am i missing something.
  • Anonymous Nov 11, 2008
    Was there ever a solution to this I rma'd the first one and the second is doing it too
  • scytheric Feb 11, 2009
    I have the same problem, I am using 4 gigs of recommended corsair memory. I took everything else out of the picture except for the basics. I am using the onboard vga connector, so basically just the raptor drive, 4 gigs of top end corsair memory , and a cdrom. One time out of the 5 tries it stayed on but there was no output to the monitor and no beeps from the system audio.
If you don't already have a case speaker hooked up to the board, you might want to connect one since there isn't an on board speaker and you will not hear error beeps otherwise.
Also, if you have another non-phenom AM2 processor handy you should really update the BIOS to latest release. Many late model Phenoms will not work on motherboards that have earlier BIOS releases and you will not be able to post. You should then choose "Set Optimized Defaults" and save the bios without any changes then shut down (not reset). When you power on again it should post and you should be able to get into the BIOS.
A third thing you can try (after you get a case speaker hooked up) is using a cheap pair of ddr2-6400 RAM to get the board to post so you can get into BIOS and change the voltage to the correct settings for your RAM if it requires a higher voltage than the bios expects.
Posted on Nov 17, 2008
  • Intel Master
  • 3,051 Answers
Double check the bios jumpersmake sure that they are set to normal
Posted on Aug 23, 2008
I have exact same problem ..... did you guys find any solution?
Sometimes, after loosening up screws thats fix mb to chasis, it comes alive and again starts doing this after a few reboots.... weird
Posted on Sep 18, 2010
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
Aug 25, 2011 | ASUS M2N68-AM SE2 Motherboard
Hi, I need standard spec info of VGA built on Asus P5GC-MX 1333 whether 64 Mb or 128 Mb. Many thanks & regards, Richard
you can use up to a maximum of 224 mb of your computer's RAM for the onboard video chip to use. You can install a video card with any amount of memory (which would give you a lot better video performance).
Jun 18, 2011 | ASUS P5GC-MX 1333 BULK C2D LGA775 945GC...
ASUS M3N78-VM motherboard Problemes
Good Motherboard...BTW... Reset BIOS to Factory defaults. Make sure you have the latest BIOS as well. Then you need to eliminate the other devices. Try running just on the On-Board Video...see if crashes. Run w 2 Gig Ram...same same... and of course the processor which may be impossible. Once you know it is MB or CPU... you make a choice which to buy or test. MB first... you can always return with less stress.
Dec 31, 2009 | ASUS M3N78-VM nVidia GeForce 8200 AM2+/AM2...
Can you mix 1gb and 2gb dimms in the same machine (for a total of 6gb)? I added two 2gb 1066 DDR2 dimms (''OCZ'') to a PC that already had two 1066 DDR2 1gb dimms (''Kingston''). I moved the 1gb dimms to...
Your MB is AM3 with 128MB DDR3-1333 built-in, four 1.8 Volt DDR2-1200+ depending on cpu. Have you enabled cpu 64 bit extensions? Tried slowing down your memory bus?
My ASUS use dual channel for dual core cpu. I have 2 yellow and 2 black dimm sockets. Both dimms in yellow is single channel, one in yellow and one in black is dual channel. Might try 2,1,2,1 rather than 2,2,1,1 order. If only your 2 1GB dimms are seen then why do you get 4 GB from 1GB+1GB? Sounds like sockets 1,2 are giving you 4GB and 3,4 don't work? Are the 1GB+1GB in 3,4 visible if the dimms in 1,2 are removed? Per Gigabyte page your AMD Phenom II 920 is AM2+ : "Note: Due to AMD AM2+ CPU limitation, memory module DDR2 1066 or above speed is only supported by 1 dimm per channel." Per AMD (which does not show your cpu, AM3 cpu fit AM3 or AM2+ socket and support ddr2 and ddr3, AM2+ cpu only work in AM2+ socket and support ddr2 only.
Oct 16, 2009 | Computers & Internet
Computer does not post. Fans & lights on.
Good day sir, as you describe your problem, as I see it you forgot to replace your Power Supply box. Swap in a new one, see if it runs. Also make sure that your RAM is good.
Oct 13, 2009 | ASUS A8N32-SLI Deluxe Motherboard
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
I want to build a computer with the the new phenom 2 3.0 gigs in crossfire ati hd 3850 question if a cpu is not support it will not post there fore you can not flash the bios does the jetway jha04-lf the...
how about ASUS?
M3A32-MVP DELUXE/WIFI got crossfire 2x16 you meant and it's have internal wifi dude!
4 x PCIe 2.0 ( @ dual X16; triple X16 / X8 / X8; or quad X8 modes); CrossFireX @ dual X16; tripple X 16 / X 8 / X 8; or quad X 8 modes; ATA133*1; SATA 3Gb/s*4(RAID 0, 1, 10); Marvell 88SE6121+6111; SATA 3Gb/s*3 (RAID 0, 1, 10, 1x eSATA); Wifi 802.11b/g; Dual 4xDDR2 1066/800/667/533
it's support CPU
AMD Socket AM2/AM2+ *Phenom FX/Phenom/Athlon/Sempron; *Support CPU up to 140W
it's cost 290 u$ in indonesia
Jan 19, 2009 | Computers & Internet
GA-MA790FX-DQ6 Mobo not POSTing Should i reset the bios??
no beeps, indicates you have faulty CPU or mainboard.
  • remove all components even RAM and CPU.
  • insert only CPU and Speaker (without RAM or any other componet).
  • Boot and try to hear, there must be long beep for missing RAM, if not then try to re-insert the CPU or change the CPU/Mainboard.
Thanks and Good Luck
Iqbal
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
No Output to monitor, no beeps, fans all OK
Hi karanda,
The green led on the board shows green letting you know there is power to the borad.
Does your GFX card have dual outputs? Try plugging into the other output.
If your monitor light goes from green to amber than your PCI-E is not putting out signal. Pull & re-seat video card.
Did you check Asus to see if your CPU is supported & check what bios version you may need to run CPU?
Chcek here: Check what your M2M-E supports.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
Your board only supports these two CPU's
Phenom 9500 (HD9500WCJ4BGD),2.2GHz,95W,SocketAM2+,Quad-Core
Phenom 9600 (HD9600WCJ4BGD),2.3GHz,95W,SocketAM2+,Quad-Core
You need Bios version 0802 in order to run the above CPU's.
Good Luck & kind regards!
Mar 10, 2008 | ASUS M2N-E Motherboard
THE AMD PHENOM 9600 QUAD
off course is compatible.
see this page
http://products.amd.com/en-us/RecommendedMBFilter.aspx
if you see for asus there is only 4 motherboards compatible and the last is the motherboards that you propose.
Sergio
Feb 29, 2008 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Intel Motherboard Logo
1,195 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
