Pioneer model sd 582hd5 Video goes out
With my TV after awhile the video will go out on all the inputs. The audio still is playing. I can get it back on by changing to a different input sometimes or turning it off and back on. It happens out 4-5 times a day and on each input.
Thanks for your help
  • rdavis472 Aug 23, 2008
    Thanks this TV has been in use for 8 years. Is it possible that cold solder joints could be causing the problem now? Can you help me locate the PC board of inspection?
    Thanks for your help.
Like most problems with this model, check and re-solder the connections on the power supply board on the right rear of the tv, just behind where the main power cord goes in. Most problems are around the upper left corner where the white connectors E-12 and others. Check all of them from loose and cold solder solder connections on the board. Hope this helps.
Posted on Sep 21, 2008
    Sergeant:
    Champion:
  • 375 Answers
Cold solder connections on the video pc board assy.
Posted on Aug 23, 2008
  • g w Aug 23, 2008
    the rear panel the has the a/v jacks attached at the rear of the unit.
No picture on my pioneer TV model SD-582hd5
The problem is on lamp try to replace it to get back the picture..
Feb 23, 2012 | Pioneer SD-P55A3-K 55" Rear Projection...
I have a model SD-582HD5 58" TV Year 2000. It all of a sudden pops off to standby for no reason. Then it wont turn back on for awhile. What can we do to fix this?
It has a loose connection on one of the boards. To test this the next time it turns off, Power it down and then back up, While its trying to come on hit the side or kick the bottom and see if it comes on. Sometimes you have to hit it hard. If it comes back on its a loose connection. A tech will have to check all the connections and if no loose connections are found he will have to resolder the joints on the boards.
Mar 26, 2011 | Pioneer SD-582HD5 58" Rear Projection...
SD-P50A5 Pioneer TV - No Video and Audio is 'chirpy'
CHECK IT FOR CRACKED SOLDIER CONECTIONS ON IC2603 AND IC2604.
resoldier all heat sink parts , this model came of the manufactior line with manny bad solider conections.
regards.
daniel.
Jan 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer 58" SD-582HD5 1080i -Rear Proj TV
Jun 02, 2008 | Pioneer SD-582HD5 58" Rear Projection...
My sd-582hd5 picture goes black
May 08, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Component video issue
You have a component not up to specs in your input 2 circuitry possibly a capacior. You would need a service manual to locate which item that isnt up to its rating. you can purchase the service manual for your set for 12.99 at the following link. They will emal it if you send them an email requesting it.
http://servicemanuals.vstore.ca/
Jan 04, 2008 | Pioneer SD-582HD5 58" Rear Projection...
HV adjust
DANGER do not adjust anything but screen voltage to each gun do this is the only adjustment you need to make
Nov 09, 2007 | Pioneer SD-582HD5 58" Rear Projection...
How to open pioneer sd-582hd5
from back good luck most problems are cold solder connections and i some models you have to replace three small caps in the video circuit
Oct 31, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
