Computers & Internet Logo
Anonymous Posted on Jun 26, 2011
My Samsung X120 laptop screen has started to show a white strip about 3.5 inches/9 cm wide just to the right of midscreen, running the full height. when logged on the normal icons show either side, but those that should be where the strip is do not show. However, they do work-for example logginh on to my desktop. the stripe comes on as soon as the screen /laptop is booted( so not an operating system problem) and does not show when I attach a monitor. I deduce that the problem is not the laptop but either the cable to the screen, or the screen itself. How do I tell which it is? I have found sites selling replacement screens, but not cables. Are they available if needed?
Anonymous
Level 3:
  • Master 797 Answers
  • Posted on Jun 26, 2011
Anonymous
Master
Level 3:
Answers
797
Questions
Helped
191148
Points
2336
The cables are integral to the monitor (most of the time) and will come with the replacement screen.
Samsung led 65 inch left side of screen is a 5 inch wide white vertical strip. can anyone help me ?
The Vertical colored lines that usually do show up on TV screens is when the T-Con board is not working correctly and most times this can be simply be caused from wiring that is not securely or fully fastened. Other times the T-Con Board itself might be faulty and needs to be replaced.
tip
Notebook Samsung X120 , X420 , X520 presented at IFA Berlin
Samsung has introduced its new notebook(A1185) at the IFA 2009 in Berlin, the latter the most important event in the world for consumer electronics industry . The names of the new Samsung notebooks(Sony VGP-BPS8A) belonging to the series X, X120 , X420 and X520 . All computers are able to guarantee a good time ( about nine hours) and good portability.
samsung_x120.jpg From the images collected by the presentation computers feature a beautifully designed and elegant, with the finishing touches. The colors are white pearl , black pearl and titanium . All three new models are based on Intel CULV .
The new series of notebook(Pavilion DV2000 battery) Samsung ranks among the lightest . The Samsung X120 is a 11.6- inch laptop weighs 1.3 kg , the X420 has a 14 inch display and weighs 1.8 kg , while the X520 is a 15.6 inches and weighs 2kg . The display line X are 16:9 .
Regarding connectivity, the Samsung X have nothing to envy of the competition. They are equipped with HDMI ports , wireless, webcam , Bluetooth , 3 USB ports.
The price of Samsung X120 , X420 , X520 , respectively, is 599 euros , 649 euros , 689 euros and will be available on the Italian market by the end of October .
Dell Inspiron 1521 battery Dell Inspiron 1100 battery
Toshiba PA3534U-1BRS battery
on Aug 17, 2010 • Computers & Internet
Convert calculator
One inch is exactly 2.54 cm, so if you're 5 ft 9 in then you're about 175 cm.
Inmy screen has a white strip about 3.5 inches/9 cm wide just to the right of midscreen. when logged on the normal icons show either side, but those that should be where the strip is do not show. It comes...
Hi , and thanx for using our site ..
My advice is that you have a resolution issue ...if the strip is present in both sites..it means that you are using a wrong resolution ...so get into the video properties and try a few configurations ...until you get the one fit for your screen ...(I deduced this cause it is not present in another monitor..so it's not an physical or system issue...but probably you have a wide screen and a wrong resolution in use..
have a nice day
1helpful
Image on 'normal' setting isn't using full height of tv screen.
What you will need to do is grab your remote that came with the tv - click "Menu">select "Settings">go down to "Screen" and make sure that:
1. Wide Mode reads "Full"
2. Auto Wide reads "On"
3. Display Area reads "Full Pixel"
Hope that helps.
Screen Problem
Unfortunately the fix is a new lcd. The tab welds at the top of the lcd are not allowing that portion to work correctly. As these tabs are fused to the lcd you will need to replace the lcd. My Toshiba M105 is almost the same.(I Have 4" Gone) on the right side. so to use it I clicked and dragged my system tray from the bottom to the side. And shrunk my web pages to utilize tthe good portion.
I suppose I should replace it but being only 18months old the LCD's run about 160.00 USD.(sometimes I just hook up an external monitor.
White vertical line on left side of screen
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Grand Canyon Tech
Grand Canyon Tech
