Question about RCA HD52W59 HDTV Projection Television
Rca 52 inch tv
Something is wrong with the convergence on our tv. This is the second time in 2 months. The first time it seemed to fix itself, but this time the problem is staying. We have red and green shadow on the screen. The center of the screen is pretty good but the outside is shadowed. We have tried to adjust with the convergence setting but the crosses don't look to be out of balance. This set is only 2 years old. Help.
Probley your fuse fl231
Posted on Sep 05, 2008
Different Kind of Convergence Problem - RCA 52 inch
The FL231 fuse is dead.There 3 retangles squares the one in the midle is dead near the right side of the FBT high voltage transformer.the big plastic block with a red wire hook a cap to ur CRT.
Sep 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 52 inch rca dlp hdtv. the color is out of allign and the tvs menu convergence adjustments isnt gooe enough, how do i enter the advanced convergence settings. my S/N is D52W23WX32F445C1002. thank...
Turn off your TV. Hold down the Channel Down and Volume Down buttons on the front of the TV. Hold for 8 seconds. The set will boot into the service menu.
I just fixed my convergence issue with this, no parts.
Jun 15, 2009 | RCA HD50LPW175 50" HDTV
RCA projection is having color shadows and blurred picture.
Hi, this is failed convergence and it is due to a faulty convergence board chip set. simply replacing the convergence board in this set Will fix your issues.
May 21, 2009 | RCA HD52W56 52" Rear Projection HDTV
Rca 52 inch projection tv 1996
yes convergence ics bad or caps shop 200$ do it your self 50 bucks if u dont have a general skill of electricity electronics do not attemt but easy fix un plug tv look in back u should see 2 large black square ic repalce them and caps outpt resistors this should fix ur problem parts nte semiconducters.com or u can seen it of 2 a factory 2 be serviced pts electronics.com 180.00$ good luck shawn
Apr 18, 2009 | RCA P52926 52" Rear Projection Television
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
Rca 52 inch convergence
You have a opened fuse FL231 next to flyback transfomer are 3 Fuses they look like small brown squares/ Fuse in the middle is bad when you do not have convergence listed in menu.You can pull the top off of these fuses .
Nov 06, 2008 | RCA P52960 52" Rear Projection Television
Picture is warped. rca 52 inch model p52929
This is hte beginning of a convergence problem. If you can solder, try resoldering the pins on the convergence ICs. These are large black ICs attached to a heat sink and will be marked STKxxx. If that fails to resolve the problem, replace the ICs.
Keep us posted.
Dan
Aug 25, 2008 | RCA P52929 52" Rear Projection Television
RCA HD52W59 Projection TV
Convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
178 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
