Question about KitchenAid Ovens
Kitchenaid oven schematic
Please fax or e-mail a schematic for Kaid mod# KEBS246SBL-0 if you have one. e-mail: advantageswo@hotmail.com or fax to: 949-365-
0463
If you dont have it, maybe you can send us in the right direction.
Thank you,
Brenda
Kitchenaid superba built in oven thermometer probe symbol appeared after cleaning
The last digit is a 0 not an O go to Whirlpool,com scan over service and support click manuals and literature enter your model Number for owners manual as a tech have never seen the symptom you describe do me a favor hold the 0 button for 5-7 seconds to get into diagnostics we are looking for any F error codes hopes this helps
Feb 14, 2015 | KitchenAid Ovens
The Light has gone out in my KitchenAid Microwave Model KEMC308KSS0...how do I replace it?
I have a kems308...very similar to yours. Order the bulb by finding it on the parts list and ordering it on Amazon or thru Kaid. Mine was $13.00! The bulb on mine is a baseless bulb that goes in a bulb holder held by a spring behind the control panel. The control panel is easy to remove, but turn off the power first. Plan on an hour. If you can access yours this way it saves having to remove the whole unit.
Apr 08, 2011 | KitchenAid Architect Series KEMC308KSS...
My display reads F5:E7 on a Kitchenaid Superba stove. email cmaffey@hotmail.com
Well, its 10:30 on a Saturday night, and I was so frustrated by my Kitchenaid Oven. I set it to clean, but afterwards it would not unlock. the display read F5:E7, which i found out means the door unlocker won't work.
So, how did i fix it, well there are two ways, to get your oven door open.
I only found this out after tinkering for 2 hours, and found the easiest way to get your oven going again:
Pull your range out so you can see behind it. You will see a rod in the upper center part of the oven. There is a cutout in the metal and you can see the solenoid that locks the oven. It is connected to a rod. This rod is what goes to the front of the oven and is what is keeping your door locked. Simply move that rod the opposide direction, it will click, and presto, your door is now open.
I never bothered to replace the solenoid, because I didn't know if it was bad, or the controller board. The Solenoid itself is $90, I don't want to even guess what the control board is.
So, not technically a fix, but it will get your oven open. Just don't clean it automatically any more!
Sep 30, 2010 | KitchenAid Ovens
My oven will not turn on. I notice the clock is not on but the burners do work. I have a kitchenaid superba oven with a glass cooktop.
You can download an electrical schematic from the kitchenaid web site. In the back of the stove, you will be able to trace the wires to find a loose connection. Be careful - make sure you disconnect the power before you start. You don't want to accidentally touch 220V.
Oct 03, 2009 | KitchenAid Ovens
Kitchenaid KEMS308 display is saying "enter probe temp or remove probe" No probe is plugged in or has been used in a while. This message came up after cooking for about 3 1/2 hours at 300 degrees. Now...
Apparently this is to do with moisture having affected the oven adversely (I got this error message after baking 50 potatoes with all the steam that generated. Have a look at this page http://www.howtomendit.com/answers.php?id=162257 ....the solution is to set the probe for 160F then turn the oven on for 15 minutes or so at 450F. This apparently should dry out the probe position and all work again.....I am trying it now.....
Sep 07, 2009 | KitchenAid Architect® KEMS308SSS Stainless...
Lincoln impinger 1050 ( gas and electric)
pilot is on auto ignite sequence you have a big problem
Feb 05, 2009 | Lincoln Conveyor Oven - 1133-000-A
Finding parts for La Germania- Explorer Oven
The distributor for LaGermania in North America has gone out of business. However, parts can be ordered directly from the manufacturer in Italy. A contact that worked is: Daniel Pedrazzini
Customer Support
BERTAZZONI S.P.A.
phone +39 0522 226415
fax +39 0522 226440
e-mail: dpedrazzini@bertazzoni-italia.com.Note that shipping will be expensive, but it is still much less than buying a new stove.Also, I have found a model sold in Australia that is very similar in features to the models that were sold here, with the exception that they don't have a separate burner lighting button. Here's a link:http://sampfordixl.com.au/lagermania/upload/LUEP01-90-S._W1883_%28A.pdf
UPDATE: (January 5th, 2018)
Unfortunately, the Australian distributor no longer carries the La Germania line, and has removed all La Germania related information from their website. I uploaded the manual I had gotten from the above dead link and also the parts breakdown drawings and parts list that were sent to me from the parent company in Italy, Bertazzoni. This parts list can be used to order parts from Reliable Parts, which is a U.S. distributor of Bertazzoni parts, and they can order the La Germania parts using the parts numbers from this list by contacting their Bertazzoni reps and getting the Bertazzoni part numbers where they differ.
Here's a link to the directory that contains this information on a Google Drive. Using this link you should be able to browse, view and download the documents:
https://drive.google.com/drive/folders/1dYHsPsU-_WZ71kR4nLobiv7thY-lJV2t?usp=sharing
A few notes that may help people when repairing these 1990's La Germania branded stoves:
1. These La Germania branded stoves are well built and worth repairing. They are the same quality and similar build as the stoves currently being sold in the U.S. under the parent company's name, Bertazzoni. After replacing two burned out oven heating elements (see below) in mine in 2008, it has been operating flawlessly for over 10 years -- pretty good for a 1990's dual-fuel stove.
2. Some of the electrical elements can be replaced with domestic parts. For example, I took the burned out circular convection oven element to a local used appliance store (used appliance stores often have appliance repair departments) and was able to match it up exactly to a used convection element they salvaged from a domestic stove. Unfortunately, because this was a salvaged part, I was not able to determine the make and model of the "donor" domestic appliance, otherwise I would have posted it here. However, their technician assured me that it was a commonly available part. You just need to match up the dimension of the round element (both diameter, and depth) and make sure the wattage rating is about the same -- in my case the one I found was exactly the same, including the support brackets. Since in the U.S. oven elements are 220-240V rated, they will work in the La Germania (and Bertazonni) ranges. While I was at this used appliance store repair department I also looked for a replacement for the burned out lower oven element. Unfortunately I could not find an exact match for the lower oven heating element as I had for the convection element. However I did find a used domestic lower heating element that was approximately the same dimensions and wattage, and the end with the connectors very closely matched the original element, and so could be mounted and connected up exactly as the original element had been. I had to extend the two front support legs on it by about 1/2 inch, but that was easy to do with some scrap aluminum flat stock and a small bolt, a washer, a lock washer, and a nut to hold the extension in place.
I attached this extension to the bottom of the two V-shaped wire "feet" that were already welded to the front of the used element I had found. These two wire "feet" were welded at the top of the "V", so, being attached to the bottom of the "V" the extension wouldn't get the full heat from the element. This reduction in direct heat allowed me to use easier to cut and drill flat aluminum stock instead of using much harder to cut and drill flat stainless steel scrap stock. (I would not have trusted aluminum to withstand the heat of direct contact with the heating element.)
Because I was able to find workable domestic used parts, the total cost of repairing both elements was less than $20. It would have been far more costly just to have had factory replacement parts shipped from Italy.... I also was able to do the repair immediately instead of having to wait for the parts to arrive.
WARNING!!!! If using non-factory elements it is EXTREMELY important that you pay attention to closely matching the wattage of the existing elements. Putting in lower wattage elements will result in slower warm up times for the oven, and putting in higher wattage elements could be an EXTREMELY DANGEROUS FIRE HAZARD because the element would burn hotter than the stove was designed for and could potentially cause a fire due to this, OR it could cause a fire due to overloading and heating up or burning the supply wiring inside the stove because it wasn't rated to supply that high a wattage/current. WARNING!!!!
I realize that this kind of mix-and-match parts finding is not something that a person without some good DIY skills and experience would be able to do. However, competent professional repair people can and do use quality generic replacement parts all the time for out-of-warranty repairs -- they just make sure that the manufacturer is known for their quality and the wattage is an exact or very close match, and thus maintain the engineering and safety integrity of the stove.
3. Regarding getting factory replacement parts for these La Germania branded stoves:
While the parts can be ordered directly from Italy, I was quoted more than $100 just for shipping to get the parts I wanted shipped direct from Bertazzoni in Italy. Because La Germania and its parent company Bertazzoni produced very similar products, a great many of the parts were shared. Because of this, a Bertazzoni U.S. parts distributor like Reliable Parts will be able to supply many of the wearing parts (elements, burner caps, hinges, door seals, etc.) from their existing Bertazzoni stock. They would just need to contact their Bertazzoni representative and ask for the cross-matching part numbers between the two related companies when the part numbers differ. The U.S. parts distributors order a lot of parts at a time, possibly by the container load, which drastically reduces the cost of shipping for each individual part. So, if you aren't the experienced DIY type person that can work with matching and using domestic replacement parts, or just want to stay with the original factory parts -- attempting to get replacement parts through a U.S. Bertazzoni parts distributor could save you a lot of money (and time). I know this to be true because I researched getting the parts through Reliable Parts prior to discovering I could find and use domestic replacements.
4. The oven light bulbs for these stoves are hard to find, and expensive in the U.S. because of their shape and voltage. I was quoted between 8 to 10 dollars per bulb (not including shipping). However, if you do a search on a site like Ebay, you can find these bulbs for a lot less, even when considering the shipping cost. If you can wait for 2-3 weeks you can get a pair of these bulbs for about $2.50 from China or Hong Kong, including shipping. If you want to order from the UK to get quicker shipping, you can find them for about $8 for 2 including shipping. Just do a search for "25W 220V oven E14" or "25W 220V 300C E14" and you'll find them. Make sure they are high temperature rated (300 degrees Centigrade.) You can find them on Amazon as well, but I only saw Chinese suppliers listed (a 3-4 week shipping time usually indicates a Chinese seller).
Nov 22, 2008 | Ovens
I can't find the repair manual that was inside the oven anymore
Hi jeff; iv'e found a site for wiring diagram for kitchenaid,then you can download a pdf. files....
http://fixitnow.com/documents/FAULTCODES.pdf
if my solution help you please rate me as fixya ,in the premium solution there...
thank you in advance jeff...
Jun 27, 2008 | KitchenAid Architect Series KEMC308KSS...
Schematic for GE JGRP18GEL
We went to General Electric and requested the schematic for our
oven, they immediately faxed it to us, and also are sending a copy
in the mail.
All we needed was the schematic for the timer/control.
So, in the future, you can remember this....
Mar 10, 2008 | GE JGRP17 Gas Single Oven
Ovens Logo
146 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
