Question about Acer Aspire 5050 Notebook
Ethernet port,keyboard,card reader not working
After a storm, I turned my computer on and tried to access the Internet. However, the connection was not detected and the lights that usually showed up weren't blinking. I checked the Device Manager and it doesn't show anything not working correctly. Also, my keyboard doesn't work and neither does my card reader, but everything else works correctly. Anybody know how to fix this?
  • Steve Rand
    Steve Rand May 11, 2010
    I do!
    Replace the broken parts that were fried by the thunderstorm. Problem solved!
    Now ask me what to do with a broken window! =-]
    Seriously though, all those parts are connected to the motherboard. There is no magic "make it work again" button... it's probably just a fried motherboard that will need replacing. Sorry =-[
    Problem Solver:
  • 10 Answers
Try taking out the battery and plugging into the mains to see if the battery is causing it. Worth a go.
Cheers
Posted on Mar 20, 2009
SOURCE:
Internet stopped working after lightning strike and new motherboard didn't help
Can you please describe in more detail how the internet doesn't work?
If you have the laptop and the desktop connected to the same router? If so, if you turn on Sharing, can you see the other machine? (or if you have a network attached printer, can you print to it?) If you can do other tasks with Ethernet, then it is not a computer hardware problem.
Does the cable modem have wireless and four Ethernet ports, or does it have just one Ethernet port? Do you have a separate router?
Jun 28, 2014 | HP Pavilion Media Center TV m7480n...
Modem not working
call you internet provider to get the modem replaced. Usually it's the Ethernet port on the modem that has been damaged from the storm.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Jul 02, 2012 | Acer AX1900-582G50mi PC Desktop, Intel...
Cisco access point
How to configure wireless access point using a laptop
Wireless technology makes connecting to the Internet possible from anywhere within the range of the network. Unfortunately, not all Internet-capable devices have wireless technology, and many still require an Ethernet port connection. If you have a laptop with a wireless card and an Internet connection, you can make the laptop a wireless access point and share that connection with other devices, whether your laptop runs a Windows or OSX operating system. Windows computers allow other devices to access the wireless network via a physical connection to the laptop, while OSX computers allow AirPort equipped devices to connect as well, creating a second wireless bubble for the network.
Instruction:
WINDOWS
1 Turn on the laptop and the device with which you will share the connection. Ensure the laptop's wireless card is turned on and you have an Internet connection.
2 Connect an Ethernet cord to the port on the laptop, and the other end to the receiving device. You need to make the connection first, or you will not be able to access the sharing options for the connection.
3 Open the list of network connections on the computer. In Windows 7 and Vista, access this list by typing "Network Connections" into the Start menu search bar and pressing "Enter." In Windows XP, click on "Network Connections" in the Network and Sharing Center section of the Control Panel.
4 Right click on the wireless connection and select "Properties," then navigate to the Sharing tab. This tab will not appear unless both devices are connected.
5 Check the box marked "Allow other network users to connect through this computer's Internet connection." Click "OK" to save the changes.
OSX
1 Click on the Apple menu and select "System Preferences." Click the "Sharing" option, then choose "Internet Sharing."
2 Select the Airport and wireless network in the "Share your connection from:" drop-down menu.
Select an output format for the connection in the "To computers using:" drop-down menu. Choose "Ethernet" for a physical connection or "AirPort" for wireless broadcasting.
Turn on the device you wish to receive the connection. Connect the devices with an Ethernet cable, or turn on the receiving device's AirPort card and connect wirelessly.
Dec 12, 2011 | Computers & Internet
I use a cable internet connection which works. When I connect the router, I ran cable to blue connection on router and another ethernet cabel from the computer to another port on the router. When I do...
Turn the cable-modem off.
Turn the router off.
Use an Ethernet cable to connect the cable-modem to the 'WAN' (or 'INTERNET') port on the router.
Use another Ethernet cable to connect one of the 'LAN' (or 'NETWORK') ports on the router to the network-port on your computer.
Turn the cable-modem on, and wait for its lamps to settle-down to a steady pattern.
Turn the router on, and wait for its lamps to settle-down to a steady pattern.
On your computer, you should be able to access the Internet.
Also, look at the colour of the EIGHT wires at each of each Ethernet cable.
The order of the coloured wires should be IDENTICAL at both ends.
Jun 26, 2011 | Buffalo Technology Buffalo Wireless-N...
I have cable internet and how would i connect the DGL-4500 wireless router to cable???
I have used Cat5e plenum Cable for my internet connection and I faced same problem. If you are just concerned with internet access and not access between devices on your LAN, then you just need to connect the first router LAN to the WAN port of the second router with the mentioned Ethernet cable. It is also in your best interest to make sure the IP ranges are different between the two DHCP servers you now have. That is, make sure they are not on the same subnet or serving up conflicting IP's.
Feb 21, 2011 | D-Link DGL-4500 Wireless Router
Lenovo WinXP - Ethernet port issue
Hi. Try to check the steps as give below.
  1. Check the ethernet port with other spare wire if you have to check if it is a wire problem or if it is itself your ethernet port.
  2. Try to connect your ethernet port directly to the router to make sure ethernet port is working and there is no connectivity issue with the switch.
  3. Try to check the System BIOS settings and see if it is not disabled from there.
  4. Lastly download any free Live OS of Linux and boot your computer using it. See if the ethernet card is working or not.
Steps from 1-3 is for checking physical connectivity of the ethernet port and the last step is for checking OS issue. If network card do not work with Live OS as well, you can directly come to conclusion that its ethernet card that is not working properly and you need to get is repaired.
Cheers!
Apr 14, 2010 | Lenovo Thinkpad T60 Notebook
Internet connections
Change your ethernet cable from DSL to computer Ethernet port.
Jul 21, 2009 | Acer Aspire One PC Notebook
Wireless router to modem problems
Since it says network cable unplugged on the computer when wired to the router, you need to check these first:
â Make sure that the Ethernet cable is connected from the modem to the router’s Internet (WAN) port and the computer to the numbered port of the router. The computer should used to be connecting to the Ethernet port of the modem, if not; you should contact your ISP first.
â Make sure that the Ethernet adapter/LAN card on your computer is working properly. You can check that on the device manager of your computer.
â If those are all working fine that would mean the router is not yet configured for Internet access or we can say that the settings for the provider are not synchronized with the router.
To configure the router, you can do these general steps:
1. Connect the computer to the numbered port of the router and the modem to the router’s Internet (WAN) port.
2. Turn off the computer, router and modem.
3. Turn on the modem first, wait for the lights to stabilize then turn on the router. As soon as the lights are stabilized, you can turn on the computer and check for internet connection.
However, if the Internet connection still does not work. That means there are additional settings needed to be done. You can message me about the name of your ISP and I will provide you the specific steps you need.
Sep 23, 2008 | Belkin (F5D7230-4) Router (587009)
No internet connection
compaq what??
how old??
what do you have as wirless car or Network card??
go to the mfger web site download the new driver fo the cards and try again.
Apr 17, 2008 | Internet KM-2501P Enhanced PS/2 Multimedia...
Acer Aspire 5050 Notebook Logo
48 people viewed this question
Ekse
Alun Cox
