Question about RCA P52945 52" Rear Projection Television
TV will not turn on. No lights anywhere. It is like it has lost all of the power supply. sooner929
    Problem Solver:
Fuse in power supply board,inside near power cord.
Posted on Mar 01, 2011
TV Turns on (Blue Light) and then turns off but there is no imagae or sound of Tv Turning On! Nor Backlights turning on!
Sounds like there's a short in the power somewhere. I'd start with unplugging it then checking to make sure all cables and/or cords are properly connected (i.e. make sure there are no loose cords anywhere)
Sep 15, 2014 | LG 50PK750 50 in. Plasma HDTV
I have a panasonic TH-C42HD18. Last night a fuse in my fuse box flipped so I lost power to the tv. I reset the fuse (in the fuse box) but now My tv will not turn on. Everything else plugged in to that...
If you have no power light on TV ,then you must have a blowed Fuse on the power supply board.
Check Fuse and check board for Bad Capacitors they will be vented or swollen on Top.
1000uf 16v 2200uf 10v 3300uf 10v.
Jun 02, 2011 | Panasonic TH-C42HD18 42 in. Plasma TV
When I turn on my set, light turns green, then after 30 seconds turns red won't come on
Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
May 05, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
I have a Panasonic 32 inch HDTV. TV worked great until one day tried to turn on and nothing. It acts like it has no electrical power. We have tried plugging into different outlets with no luck. The red...
One simple solution may be to replace the power cable or the power strip that the TV is plugged in to. If you cannot get any power to the TV even after this step, it is most likely a motherboard or some sort of circuitry issue. Make sure you are using the physical buttons on the TV when trying to turn the TV on; leave the remote out of the equation. If it still does not come on, your TV may be far gone. HDTVs have a lifespan these days of anywhere between 3-5 years for plasma, 5-7 years for LCD, and the new LED tvs are supposed to last anywhere between 7-10 years.
Feb 28, 2011 | Panasonic Televison & Video
My panasonic plasma wont turn on after lighting hit what could have fried
The first circuit to be hit is the power supply but depending on the protection built into the unit, it could very well have passed high voltage on to the more delicate (and expensive) small signal circuitry.
The only way to establish the extent of damage on your own is, to replace the power supply assembly and hope that the set then turns on. If it doesn't, then you have gambled and lost.
Supplies are normally a separate board that is fitted with plugs making it possible for a DIY replacement. Supply boards can cost anywhere from ~$90 to $175 US.
If you live in a lightning prone area (as we do), I would highly recommend the installation of a 'whole house' surge arrester. With installation, the cost will be under $300 US and units from Intermatic such as ours come with a 5 year warranty and $10,000 in insurance in case the arrester fails to protect your gear.
Jun 13, 2010 | Panasonic TC-P50G10 Plasma TV
My Poloroid LCD TV wont turn on power supply brick light doesnt
The TV needs a fairly stable and well filtered 12V power supply. A jumpstart box is 12V, but is I seriously doubt that it is anywhere near filtered and stable, so most likely you would smoke the TV.
Hooking the TV directly to a 12V battery is just fine, as long as the battery has enough current to run the TV.
Oct 20, 2009 | Polaroid LCD-2000 20 in. Television
Dead, no power
It sounds like ze power supply blew when it was being turned off. This seems to be typical of plasmas. Bad power supplys wont let the tv come on and will result in no lights coming on. Since there R no lights coming on, I would suspect the power supply first, followed by the power control board,. and circuit board. It may cost anywhere from $250 to $500 to fix.
May 14, 2009 | NEC PXT-42SX1B 42 in. Plasma TV
No power, lost power while watching tv
after picture is lost, does the screen remain lighting?
Jan 13, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Toshiba TheaterView
Called Tv tech. He said it was the power supply connectivity. common problem in rear projection Tv's. Cost to replace was anywhere between $300.00 and $400.00 dollars. Time for a new tv :-(
Feb 21, 2008 | Toshiba 50A60 50" Rear Projection...
RCA P52945 52" Rear Projection Television Logo
37 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
