Question about Onkyo Audio Players & Recorders
I have an Onkyo TS-DX777 since new and has never faulted, but of latelly it starts making high frquency sounds followed by some cracking while playing anything, it does this every few minutes, could you help?
Just put the bone in the amplifier and start it fire and everything will be ollright.
Posted on Mar 06, 2009
6ya staff
SOURCE:
My Onkyo tx-sr707 AV receiver no longer produces any sound in any of the modes: ie, TV cable, radio etc.. I still get a picture through my cable's hdmi connection, That hdmi connection runs from from...
You may know by now Onkyo has severe HDMI board problems. If your unit comes on with no sound, forget about the heatsink solution. The second solution of wavesoldering the Ic's is chancy at best, and requires someone with proper soldering equipment for Surface mount flat pack ic's. I've seen a hear gun attempt blow the surrounding electrolytic capacitors out of their cans. Onkyo extended the warranties for many of their high failure boards. Check the following site to see if you qualify for the exchange/repair/replacement: http://www.avsforum.com/forum/90-receivers-amps-processors/1652514-onkyo-acknowledges-failed-units-extending-warrranties-until-2018-a.html.
Dec 17, 2017 | Onkyo TXSR707 72 Channels Receiver
My receiver is not picking up the subwoofer, there is noise coming from the sub when I'm playing with the conection. The speakers are working and im getting prefect sound from them Please help.....
It would be helpful to know if this is a new problem on working equipment or a new problem on NEW equipment. And if you've flipped through the manual without success.
Of course you KNOW the sub must have its own amp, right?
First, you need to determine if the Onkyo or the unnamed sub is at fault.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR608-Receivers-manual/id/23653ag916/t/2/
At the Onkyo, check to make sure you have run the speaker setup starting on Page 40. If that doesn't work...
Disconnect the subwoofer pre-out at the Onkyo and move it to the VCR Out, tune an FM station and be ready for some real loud subwoofer output if your sub has no volume control of its own. If you can hear the sub, it works and it's back to the Onkyo. If not, the unnamed sub
Apr 09, 2011 | Onkyo TX-SR608 Receiver
My Onkyo S7300 receiver doesn't work, it makes choppy sound why it turns on
this may be the HDMI heat issue i've found with these amps. the issued is caused by the heat produced by the 5V voltage regulator under the HDMI board. once the sound starts to get choppy and or cutting out sometimes with a loud boom. the only way to get around is by installing a fan. First try using a 12V 4Inch fan place it directly on top of the amp cover over the HDMI board use a good Power adapter so the fan runs fast. Now IF it works! I suggest you install a Internal fan I have attached the picture for you to follow. the fan will not be as loud because the supply will be only 6 Volts. NOW TO AVOID THIS ISSUE FROM HAPPENING AGAIN TURN OFF THE HDMI CONTROL UNDER THE HARDWARE OPTIONS. HDMI PASSTRU IS THE MAIN ISSUE HERE. the regulator sits there for hours cooking that board. it's why half of Onkyo HDMI capacitors and regulators die out.Be careful do this at your own risk. High Voltage inside this amp. good luck.mvianna_0.jpg
Mar 19, 2011 | Onkyo HT-S7300 Theater System
My Onkyo TS-SR604 has a "power on problem" whereby
Check to make sure the speakers are secure, if everything is fine! the problem is in the audio output ic's in the receiver. This will need a technician to take it further to find out how much the cost will entail.
Jan 11, 2011 | Onkyo TX-SR604 Receiver
I got a new Onkyo Cs-525 with Onkyo speakers a month back. My vendor said that it will take 300 hours of playback before my speakers completely burn and start giving the the best possible output. Now I...
Burn-in? On speakers? Never heard of it, especially for something not pretending to be sky-high esoteric and expensive, following the believing-is-seeing (or hearing) rule.
If I had to guess, I'd say you're hearing speaker buzz from stress or resonance from something in or near the speakers. Does it manifest itself at all levels, both speakers, all sources (analog and digital)?
Wild guess... are track lights present and ON when you hear the problem?
Aug 03, 2010 | Onkyo CS-325 Shelf System
When power button turned on, receiver powers up
I have had the same problem with my new Onkyo HT-S 5305B (A/V Receiver + 5.1 speakers). To solve this, try to follow "Troubleshooting" guide that came with your system. I followed it 2-3 times. In my final attempt, when system was not shutting down but stayed-n with no sound, I played with the setup and tried changing audio adjustment, input, dimension etc. and slowly I was able to get speakers up one after the other. It's working fine now.
However, I am little concerned that why such a high-class Onkyo system failed in less than two days, forcing me to troubleshoot. - Apurva
May 10, 2010 | Onkyo TX-SR500 Receiver
How do I link my Onkyo TX-SR507 to a PC?
It sounds like you don't fully understand the Onkyo's HDMI port assignment procedures.
But why burden an HDMI cable with audio only? Don't you have a coaxial digital or spdif optical output on the PC you could use? That would make things simpler for setup. Just jam it into one of the appropriate audio inputs on the Onkyo.
Jan 28, 2010 | Onkyo Tx-sr507 A/V Receiver
Mitsubishi ts-5545, Black screen and Heart beat
A couple of things:
1) Either a bad power supply or a flyback 'supplies the high voltage to the 3 CRT's' .
2) The HOT 'High Output Transistor' is gone bad or the leads 'solder joints' have cracked and are not making a good connection.
time to get it into the shop or have a tech come to your residence to look at it.
Good possibility of getting it fixed.
A/V Media Guy
Nov 22, 2009 | Mitsubishi TS-5545 55" Rear Projection...
No sound
The unit is in protect mode until then. What needs to be determined is why it takes that long for the system to settle down. Basically, there are circuits built in to prevent faults from causing damage to external devices like speakers. These circuits prevent the output section from turning on until all of these voltages are correct. If you recall from a long time ago, it was common for the speakers to produce a loud pop when the receiver was first turned on. These circuits prevent that (as one example).
This unit should be brought to a service shop as it will require signal tracing to determine the faulty component. This is not likely to be diagnosed remotely through a forum like this.
Good luck and keep us posted.
Dan
Jun 06, 2008 | Onkyo TX-SR702 Receiver
Onkyo 605 Reciever no sound from zone 2 RCAs
did the AS amp ever work properly from the RCA's?
Dec 05, 2007 | Onkyo TX-NR801 Receiver
260 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
