Question about Whirlpool Calypso GVW9959K Top Load Washer
Ld erroor and leak
On this machine i am getting an ld error. it fills with water then stops and i get the error. if i put the spin cycle on to get the water out the water pours all over the floor out the bottom of the machine. and i have to power it off. please help!!!!!
  • Jake dog Aug 25, 2008
    Yes I have the same problem. Had the LD (without any leaks) a couple months ago. Unpluged machine for 10 seconds & it worked fine. Now, after wife put wrong detergent & got lots of suds, it will no longer drain compleatly & leaks out the bottom pretty bad after many tries to rinse with very little clothes.
    Back cover comes of tonight to inspect. Need some insight as to what to look for.
    Thanks
    Sam
  • malskl2 Aug 25, 2008
    The machine starts to cycle, it fills & washes but when it attempts to drain it is leaking from somewhere towards the top of the unit (all over the floor) & eventually the "Ld" message appears on the display. Checked drain hoses for blockage & found nothing. Please help - this is an expensive appliance & I can't afford to replace it right now!
    Novelist:
    Champion:
  • 261 Answers
Ok ld is long drain, you will need a pump assembly to fix this and they cost around a 100 bucks as kenmore is upgrading this feature. Tilt the machine back and remove the bottom panel with a 5/16. On the back right corner is your pump, a white and black hose attached, If the pump is grey it is easy to clean out the socks as two steel latchs hold it. We usually replace to save getting really wet again. Just follow the wire harness and notice the motor on the pump uses 3-5/16 bolts to secure it in place.
Posted on Sep 04, 2008
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Ge washing machine fills up with water on spin cycle
Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture. 11_11_2013_2_52_52_am.png
Aug 16, 2013 | Washing Machines
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
Nov 21, 2017 | LG Dishwashers
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
My washer stops at the spin cycle. The LD code
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jul 16, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Calypso washer Ld code?
I just had the same problem. I borrowed my neighbors wet vac. The hose of the wet vac fit right over the end of the drain hose and I sucked out all the remaining water. My hope was that if the hose was clogged that it would clear it out. It seems that it worked. I put the drain hose back in the drain and turned on the extended spin cycle. It was working, so I put the water logged clothes back in the washer on the extended spin cycle and it took the water out. I am now in the process of washing another load to see if it really fixed the problem. I hope this helps.
Jan 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Kenmore Oasis HE 27082 Displays "LD" error falsely
remove the harness and replace it is what this will lead to,just watch and you'll see
Apr 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
42 people viewed this question
Dan Webster
Dan Webster
Sal De
