Question about Pentax *ist D Digital Camera
What size of flash memory card do you recommend me using with my PENTAX digital camera?
    Master:
  • 542 Answers
The answer depends on your personal needs and your budget. Memory cards are available in many sizes 8MB, 16MB, 32MB, 64MB, 128MB, 256MB and 512MB. The larger the card size, the more storage space and the greater the cost. One recommendation is to select a card that allows you to take images without having to worry about changing cards or downloading images very often (one of the advantages of digital photography). Among the most popular are those in 64MB, 128MB or 256MB sizes. You may want to purchase a second card to use as a back-up or replacement card that can be used if you run out of space on the first card or to use when the first card is unavailable (you may be downloading or printing images from the first card.)
Posted on Aug 30, 2005
SOURCE:
W what size SD memory card can i use?can i use
You may use any SD card up to 2GB in size. Make sure you don't try larger SDHC cards, as they won't work.
Nov 17, 2010 | Pentax Optio 50 Digital Camera
Wont save anymore photos. I have a 2gb card and have 361 photo's left. Is the camera memory full? Do I have to reconfig camera memory not card memory?
Possible memory card is too big for camera. Reduce size of memory cards you use - and carry more of them.
Sep 02, 2010 | Pentax Cameras
Can a pentax optio S5i support a 8GB memory card? Do I need to download a driver to support an 8GB memory card/
No the Pentax Optio S5i does not support an 8gb memory card.
8gb would be an SDHD card, the S5i came out before SDHD so it does not support them.
Standard Secure Digital Cards come up to 4GB in size so you could use one of these. The highest standard card I have is 2gb and that is fine in mine.
My S5i locks up if you put an SDHD card in.
The only firmware update that Pentax supply does not effect this, SDHD needs different hardware.
Jan 02, 2010 | Pentax Optio S5i Digital Camera
What Memory Cards will work?
Hi,,
Unfortunately, the Pentax K100D is not SDHC compatible, which means that the camera can be equipped with a maximum memory capacity of 2GB.
It is also advisable to choose a fast version of the Secure Digital memory card, such as Ultra II or Extreme III by SanDisk. I would recommend using a memory card of at least 512MB, or even 1GB if you can.
Hope this info helps
Dec 03, 2009 | Pentax K100D Digital Camera
Memory Card error message
The K100D works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot is is electronically incompatible.
Sep 25, 2009 | Pentax K100D Digital Camera
Memory card
  • Supported Flash Memory: SD Memory Card Integrated Memory: 23 MB
  • yes you can used the memory card with this.
Aug 24, 2009 | Pentax Optio S6 Digital Camera
Can Film Camera lenses and Flash be used for Digital Camera Body
If u used to have a Pentax camera, i would recommend you buying a Pentax DSLR, because Pentax film lenses still works on Pentax DSLR. I still use some of my prime lenses on my K10D.
Jun 05, 2009 | Pentax MZ-60 QD 35mm SLR Camera
Memory card size
The S5z is limited to SD cards, 2GB and smaller. The speed doesn't matter, but larger cards will not work in this camera.
Aug 26, 2008 | Pentax Optio S5z Digital Camera
Could 1GB Secure Digital Memory Card work in S40 ?
Yes, you may use any SD card up to 2GB in size.
Sep 08, 2005 | Pentax Optio S40 Digital Camera
Pentax *ist D Digital Camera Logo
41 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
