Trying to download yahoo messenger. it acts ok till i get to 5% goes to 100% then back to 0 tried several times restarted computer and did the same thing. tried to save and run different times got no prgrams installed of yahoo at this time i do have dial up
    Sergeant:
  • 226 Answers
I've seen the exact same problem on my end, but only when using a weak wireless connection. Two issues I suggest to be the cause, one being a wireless connection that is not quite as strong as you may be believing that it is ( I've seen that quite a bit on my end ). That means that I.E. or FireFox may SEEM to be working great with whatever wireless connection a person may have but in fact it is very close to the edge of termination. The other possibility that I have seen is simply the Yahoo server that uploading the program to you is being over-used, meaning you may have to wait until a more favorable time or TRY to pick on a different Yahoo server, such as the British, Aussie, or Asian server. Just make sure you get the version of YM that speaks your language.
Posted on Aug 23, 2008
I can not sign into yahoo messenger
Start your troubleshooting with a clean browser
Download 'ccleaner' and use it daily. Run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.Never make changes to your Registry without saving the information.
http://www.filehippo.com/download_ccleaner/
On the sign-in page click Messenger > Connection Preferences - make sure there is nothing untoward in the lower 2 boxes - if incorrect make changes using the drop-box options > OK
Copy this Yahoo secure site URL
https://www.yahoo.com/
Open Yahoo Messenger > Tools > Internet Options > Connection tab > LAN settings > Uncheck everything then check 'Automatically detect settings' and 'Use a proxy server' > Advanced > Paste the address in the secure box and type 5050 in the port box > OK
Sign in
Feb 13, 2011 | Yahoo Messenger
Cant log in yahoo messenger due to error socialview plug in
Uninstall everything yahoo related from add/remove programs. Go to your C:, then Program Files and delete the yahoo folder from there also. Now go download ccleaner from www.download.com and run the cleaner, once that is done run the registry cleaner a couple times.
Try re-installing the latest yahoo from there. IF that failed also, you have one last shot that will work but it can be tedious a bit and a little dangerous so make sure to back up your files before proceeding. If the error still happens, do all of the above except for re-installing the yahoo. Now from the run command (Windows Logo Key + R), type: regedit <Hit ENTER>. Up top click on Edit and then click Find. Type: Yahoo! <Hit Enter>. Delete what it found and then press F3 to find the next yahoo! item. Delete everything it finds till there are no more matches found. Close the Regedit and reboot the pc. Now re-install the latest Yahoo Messenger and the problem is gone. I have done this several times for clients and this fixes it 100% of the time. Cheers!
Oct 26, 2010 | Yahoo Messenger
I tried downloading Yahoo Version 10 and I got the message "This application has failed to start because d3d9.dll was not found. Re-installing the application may fix the problem". I tried re starting...
It seems you are installing the Yahoo messenger using the Offline Installer. Don't just reinstall it, but uninstall the whole yahoo messenger packages, even from the registry and reinstall it after your computer is restarted.
First uninstall the yahoo messenger and then download and run this program (click here). Open the link, click the "Download Now" button, wait for about 20 seconds while the countdown timer runs, and then click "Download Now File" link once the countdown timer resets to 0. After it's downloaded and installed, close all the applications, open the program and click "Run Cleaner" and proceed forward by pressing yes (if you are asked), wait for few seconds and after it's done, click "Registry" on the left pane with blue icon. Now on the right pane, click "Scan for issues" then wait for another few minutes/seconds until the scanning progress reaches 100%, the click "Fix Selected Issues" > "No" > "Fix all selected issues" > "Ok" > "Close". After it's done, restart your computer and install the yahoomessenger (download yahoo messenger online isntaller) That should fix your problem with the yahoo messenger. If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 02, 2010 | Yahoo Messenger
I cant access my yahoo messenger
Hi! Temporarily have mail in-built messenger and don't expect video, voice or attachment services in this mail messenger. and at the same time, delete your previously available YM software and get updated one directly from web and have fine
Dec 18, 2009 | Yahoo Messenger
I cant use yahoo 10 in my pc they give me a error all the time i cant sign in
You need the following OS to support Messenger
Windows 2000 / XP / 2003 / Vista / XP64 / Vista64 / Windows7
If that is not an issue read on.
Check out the Yahoo blog for the latest help on this subject ( 18 August 2009 )
http://www.ymessengerblog.com/blog/2009/08/18/help-with-sign-on-issues-in-yahoo-messenger-9-0/
My own advice is:-
1) Start your troubleshooting with a clean browser
Download and run CCleaner daily - to keep your browsers fully operational
Use the settings as downloaded - Click on the 'Run Cleaner' tab until '0 bytes removed'
2) Shutdown computer - power off the router for one minute - restart computer
3) Have more than one browser available for trouble shooting. Keep browsers up to date to incorporate all the patches - I run Firefox, Google Chrome and IE. Keep one browser clear of add-ons and plug-ins.
Always have the browser you are using designated as default - even if you only have one
4) Make sure Yahoo toolbar is up to date if you have it
5) Sign in here to reset cookies
https://login.yahoo.com/config/login_verify
6) If you have a Yahoo email address:- drop the '@Yahoo.com' from your username to sign in
7) Check the date and time are correct on your computer
8) If you have your settings to sign in automatically and recently changed your password check this out
http://help.yahoo.com/l/us/yahoo/messenger/messenger10/messenger/mstacantsignin.html
9) Make sure your firewall has Messenger on the 'allow' list.Disable your firewall long enough to make a trial sign-in
10) Messenger 10 now carries a troubleshooting log - if you have a degree in computer science the results may be of some use
11) AVG free users may be interested in this forum
http://forums.avg.com/ca-en/avg-free-forum?sec=thread&act=show&id=40313
12) Time to consider a re-install.
Save your Profile folder to hard disk, if you wish to retain your message archives.
Download 'Revo free' and uninstall in the 'Advanced'mode. This will scan your C drive and Registry for anything left behind after it runs the yahoo uninstall software. Delete everything it finds.
http://www.revouninstaller.com/revo_uninstaller_free_download.html
Run ccleaner
Restart your pc
Download Yahoo Messenger from here.
http://www.filehippo.com/download_yahoo_messenger/
Dec 16, 2009 | Yahoo Messenger
I already tried a new accnt but still my messages disappear when i press enter to send
This error is most likely from yahoo. Their system has been acting up recently. Try using their messenger for the web instead. www.messenger.yahoo.com/web
Oct 11, 2009 | Yahoo Messenger
Cannot login to Yahoo Messenger 9 - Yahoo Messenger 8 acting up
When I try to download Yahoo Messenger, It looks like it has fully installed but it says There was a problem installing. I have tried this several times but,I can't get it to work. PLEASE HELP ME!!!!!!!!
Jun 02, 2009 | Yahoo Messenger
Downloading YM 9.0 it goes to 100% and never prompts completion
Hey,
it might happen if you are trying to download yahoo messenger directly from yahoo.com.
You may use software sites to download yahoo messenger version 9 and more likely it would work n vista.
One of the link is :-
http://www.download.com/Yahoo-Messenger/3000-2150_4-10029188.html?tag=mncol&cdlPid=10888512
I hope it wl slve ur question.....
Nov 15, 2008 | Yahoo Messenger
Yahoo messenger
Hi There!!
As i understand you have downloaded and installed yahoo mensenger, However its not working.
Please do the following to get yahoo messenger running.
1.First Uninstall yahoo messenger from your laptop.
2. restart your computer. Then check if all the files are deleted from Program Files and also from the registry. If not once again delete all entries of yahoo files.
3.restart your computer. Normally while downloading yahoo messenger, you have to make sure that there is no interruption in downloading. Else all the files dont get downloaded.
4. Normally to download yahoo messenger it takes 30 min to 45 min of time from the website.
5. Use the link below to dowload yahoo messenger. Please use different version of yahoo messenger as per the operating system you are using.
http://messenger.yahoo.com/win/
6. Once downloaded please install with all other messenger services exited.
7. Open yahoo messenger and login using username and password.
It will work
Regards,
Olafsson.
Oct 03, 2008 | Yahoo Messenger
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
