Question about Sony Ericsson W300 Cellular Phone
Flex cable change
Hi I followed your instruction to remove flex cable thankyou.
However I noticed that the flex cable has camera attached but the new one in the picture on ebay looks like it does not have camera attached, do I have to remove the camera from the old flex please?
razorbill1
If you buy one without camera then yes you do have to take it off the old one and put it on the new one. My best thing to do with this one is to just buy a flex with camera already on the new cable. The camera has very small parts and it is very delicate if you are not sure how to take them and move them to the new one. It is not that much more to just buy with camera and you don't have to worry about it working if it is a fully functional flex cable new. I hope this helps if you need more help let me know and I will do my best to walk you through. If you want to try to take the camera off and put it on the new one I can walk you through but I cannot guarenteed on your end it will work. Like I said very fragile and delicate. Good luck!!
Posted on Sep 08, 2008
HORIZONTAL STRIPES ON PICTURE
Hi!
Turn on the camera
Pull the lens at maximum zoom
Turn off the flash!!!!!!!!!!!!!!!!!!!!!
Shoot the picture - look into the lens.
If no motion picture shutters in the lens:
1. Faulty flex cable shutter
2. Faulty valve solenoids
etc.
Requires repair of the shutter assembly in the lens
If you saw the shutter and blurry pictures as paint - matrix defective - Replace the camera matrix.
Dec 08, 2013 | FUJIFILM Finepix S2100HD Digital Camera
Tip
IPhone 3G instructions - disassembly
Got this great instructions from - www.rapidrepair.com.
Tools required:
Small Phillips Screw Driver
Small Flathead or exacto razor
Safe Open Tool
Remove the sim tray, use the included sim card removal tool (or a paper clip if you've lost the tool.)
Holding your device on end you will notice two small screws on either side of the dock. These screws must be removed in order to open the case.
Insert a small thin tool between the chrome ring and front panel glass directly above one of the screw holes. You will need to exert a small amount of pressure to separate the display from the back panel.
Lift the panel up from the dock end being careful not to tear or break any ribbons connected near the other end.
Unplug ribbons 1 and 2 by lifting them from the main board. Under ribbon 2 you will need to find and unclip ribbon 3, then carefully remove the display assembly.
Remove the seven screws circled in red. Note: One screw is located under the DO NOT REMOVE sticker.
Unplug ribbon 4.
Lift the mother board out taking note of the camera which is still connected to the underside of the board. You will need to unplug the ribbon circled in red.
Place the mother board to the side.
Use the attached tab to pull up on the battery, there is a mild adhesive on the back side, so it will take a bit of force.
Remove the screw circled in red.
Carefully remove the camera.
Remove the nine screws circled in red.
Remove the headphone jack and attached flex cable.
Remove the speaker assembly which also contains the dock connector, antennae and home button as well.
Remove the 2 screws circled in red.
Place the ******** assembly to the side.
Remove the 2 screws circled in red. You will find 3 screws on the opposite side which must be removed as well.
Lift the LCD free from the front panel glass.
Pictured is every component inside the iPhone 3G.
You did it!
on Jul 20, 2008 | Apple iPhone 3G
IN SONY HANDY CAM HDD XR150 - LCD SCREEN THE SOME COLOR LINES ARE DISPLAYING INSTEAD OF PICTURE . THE PROBLEM OCCURRED AFTER REMOVING THE HANDY CAM FROM THE TV SET AS PLACED IT OVER 30MIN.
You need a new sony display flex cable installed in your camera.. it is a rather simple procedure.. dont let anyone tell you it is going to cost 300-500.00 to fix. the cable or flex that makes the display viewable is called a LCD display Flex. If you don't get any image on your display, the image has lines, display has no backlight or anything like that, replacing this flex cable should fix the problem.
you can buy the flex cable on ebay for less than 30.00 and the fix is rather simple.. the display has the flex cable on the back side and there are 3 screws that holds the display on the camera body. when you take them out of the camera using a PH00 small screw driver, you can then take the flex cable out of the display and easily replace.. it doesnt take rocket science to take these out and replace them.. good luck.. remember... you can buy the flex cable that makes the display viewable and then when it is replaced you will then be back in business with your camera.. good day....David...Mt Holly, NC
Jul 29, 2011 | Sony Handycam DCR-SR300 Camcorder
Where on back of computer does cannon cable go. Have one end attached to camera. Son said attach other end to computer and follow instructions to download my pix and select ones I want.
Hi, your son are right only one end is conected to a computer USB connector,later you follow instructions or options to download the pictures to pc.
Greethings
Feb 20, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Pictures are over exposed except when in low light or zoomed in.
The cable to the shutter has broken, causing the shutter to remain open - overexposing everything but low-light pictures. You can find a replacement cable on ebay...But it is far too difficult to install (the lens assembly must be disassembled, and the cable needs to be soldered). If you you handy, you can replace the whole lens, which includes the cable. You can find new replacement lenses in ebay for about $35.
Sep 25, 2009 | Casio Exilim EX-S600 Digital Camera
Instruction to replace u600 slide flex cable
download the service manual for the sgh-u600.you need experience and special tools.isnt so easy.be carefull with the parts screws etc and check the rev. before order the flex cable.USE ONLY ORIGINAL!
Jul 16, 2009 | Samsung SGH-U600
Retrieving data, broken screen
hi
The Phone needs a new Keypad flex and most likely a left hinge pin. When the phone is open, the cable runs through the left side of the hinge. It is very common for the hinge pin to become chipped and put a small cut in the Flex Cable.
You can get the parts on ebay. search for motorola v3 keypad flex, and motorola v3 hinge, or knuckle.
thankyou.
May 04, 2009 | Cell Phones
Sony Ericsson W300i Removing the Housing
The housing is difficult to do. You have to be careful to not rip the flex cable that connects the two pieces. Once you remove the orange button on the side you will see a blue circular type pin. You must push that in all the way while gradually pulling your phone apart. Also at the same time you want to watch to make sure the flex cable don't snag itself of the folding parts. It slides in one way and you must be careful to not rip it. It is kind of in an S shape and slides in very delicately. once you get this part then the rest is easy to do. I hope this helps some and good luck. And yes I do repair these and replace all the parts on these phones so I know how difficult it can be for the first time. If you have anymore questions or if you want me to elaborate more on this just let me know.
GOOD LUCK!!!!
Dec 08, 2007 | Sony Ericsson W300 Cellular Phone
Sony Ericsson W300 Cellular Phone Logo
219 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
