Question about Linksys Wireless-G WRTP54G Router
After resetting the wireless access point the computer can not recognized it. Why is it so?
When the device was set the computer could not recognize it so that I could restore the configuration How do I go about it?
  • Anonymous Aug 23, 2008
    I got exact same problem - no ethernet port is working on my router. Also note, wireless is still working flawlessly.
  • 60 Answers
Try all the ports on the router, check if the Ethernet light is lit up on the router. Check you lan connection if it says connected, check the IP address and use the default gateway address to access the router's UI. If its saying limited or no connectivity, try to turn off the router then turn it back on and check again. If that didnt work, try to reset the router for 30 seconds by pressing the reset button.
Posted on Aug 24, 2008
I cannot set up an ad hoc network.. i also cannot connect to an ad hoc network with WPA security type.. it says that the capability of my network adapter does not match the requirement of this...
Recent computer devices are wireless compartibilbles least requiring network adaptors to establish. Ascertain the computers recent innovations also from where enabling the Wi-Fi features capturing available peripherals. For example, ascertain that another device from where networking requires establishment has wireless feature from where computer recognizes. Where each device are wireless compatible would recognize requiring passes to communicate with network structures. In a situation that one of the device has password sets, would require ascertain what entry passes makes connectivity. For example, networked computer already established requires verifying from network administrator to capture another device on the structures. Also, condition where the computer devices are prior innovations would require modems or adaptor devices or routers to complement the network structure or signal sharing. Such a situation requires ascertain the host computers as the administration point from where passwords are distributed to each device peripherals.
Mar 12, 2011 | Computers & Internet
I have congigured my Linksys WAP54G Access Point with a lan cable hookup. The system recognizes the port but once I unhook the cable it will not recognize it wirelessly.any suggestions?
From what I am understanding: you are setting your wireless up and when you are done with configuring the settings, you are unplugging the laptop/desktop from the device and trying to access the Internet. Correct?
If thats the case I will assume these things:
- You are seeing the wireless router when you are trying to connect but it still wont let you connect.
OR
- You are NOT seeing the wireless router and want to connect to it.
What you will have to do it go back into the router (hard wired into it) and start over. Make sure you access the wireless setting and ensure the settings are compatible with your wireless laptop. If your laptop is very new then the setting at the bottom will work if your laptop is older then the options like WEP/WAP Personal setting will do. Make sure you write down the settings you used for refrence later.
When you rename the device, wirite it down too!
Ensure you "Apply" all the settings and "Logout."
When you are done, go to "Start," "Control Panel," "Network and Sharing Center," "Set-up a connection or network," "Manually connect to a wireless network," and enter all the information you wrote down!
Let me know if there is anything else you need help with!
-paul
Jun 26, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Where does it install to and do i need an installation cd
what you have a is usb wireless network adapter, which is a device that allows you to connect a usb enabled computer (laptop/desktop) to a wireless router (access point) so you can got connect to a network or go online if your router is set up for it.
you would usually need a driver for your computer to recognize and work with this device. the driver usually comes on a cd with the unit. you would usually insert the cd and follow the instructions, or you would usually also install the drive and then connect the device.
hope that helps.
Dec 26, 2009 | Netopia 3-D Reach (TER/GUSB-N1)...
I'm using the gateway 2 wire 2701hg-b for the wired home computer but we can't get the laptop (2nd computer) to connect wireless. what am I doing wrong.? The set up wizard was used and recognizes the...
I've had many problems with 2wire gateways. I would first suggest changing the default WEP key if you are using WEP at all. I actually recommend you use WPA2. It's much more secure. If that does not change anything, it could be RF (Radio Frequency) interference. Turn off any 2.4 GH wireless devices. This includes any wireless landline phones you have. Wireless access points operate on the same range (2.4GHz). The difference is is that wireless phones 'hog' the frequency. 802.11x devices have special protocols implemented (CSMA/CA) to 'share the air'. If that is the problem and still want to use the wireless phones, set your wireless access point to use a different channel. It's it's on 1, set it to 11. You'll have to do some testing for best results.
Jul 26, 2009 | Computers & Internet
Wlan disconnected
I'll need more information to give you an effective answer. If your wlan was connecting just fine, and now you don't have a stable connection, it could be a range issue and you'll have to get closer to the access point.
If your wlan doesn't work at all, and won't get recognized by your computer you may need the latest drivers, in which case I'll need the model number of your wlan device.
If it works, finds your wireless connection but can't connect, try resetting your wireless router.
May 05, 2009 | Computers & Internet
Problem using wireless access point to conect desktop PC to WLAN
I have solved the problem:
- first, I had to change the management address in CF-WFAP into address that could be recognized by the router (i used 192.168.1.2),
- DHCP turned off, and set default gateway and DNS to 192.168.1.1. as in router, computer IP was set to 192.168.1.xxx, push "apply", change web address to new one,
- set AP mode to station-infrastructure, push "apply" buton to restart AP,
- set security to same security as in router and copy key into proper field, push "apply" again to reset the AP
- finaly check wireless station around and choose the router (same encription)
Mar 21, 2009 | Computers & Internet
Not recognizing wireless
Window Vista- Go To Control Panel, then go to Mobile PC, then Window Mobility Center, then go to the top right of the mobility center and click on Turn Wireless On
Jul 19, 2008 | Compaq iPAQ Connection Point CP-2W...
Wireless G 2.4GHz Linksys CD missing
go to this link www.linksys.com then choose your region, then select the model number. note: model number can be found at the box of the item.
then download the driver..
Nov 28, 2007 | Linksys WPC54GX 802.11g/b Wireless Adapter
Wireless adapter not recognizing IP address
Try pressing and holding the reset button in for 15 seconds and unplugging the power cable and plugging it back in. That should reset the router to factory settings. It can also be done through the router's web interface.
Nov 02, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
Linksys Wireless-G WRTP54G Router Logo
66 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
