Question about JVC Everio GZ-MG21 Camcorder
Power Cinema 4.7 No Sound
I have a power cinema 4.7 with Pixelview PlayTV 550 Hybrid (USB).. i can watch tv but there is no sound at all even i increase all volume control..help me please.
  • Anonymous Feb 07, 2009
    No sound on my Power Cinema 3.
  • 13 Answers
SOURCE: Cyberlink POWER CINEMA NE
There are JVC software updates and camera checking software...These can be found only at an authorized JVC service. Anyway, did you drop it?
Posted on Sep 15, 2007
SOURCE: P0WERCINEMA NE FOR EVERIO
I had the same problem & just installed windows vista updates for Intel corporation which was an optional update, it has finally fixed my problem with the green lines!
Posted on May 26, 2008
Ajkill
  • 2035 Answers
SOURCE: GZ-HD7 Computer doesn't recognise camera.
Start > setting > Control panel > System (Switch to classic view if under Category View) > Hardware > Device Manager
Your can found a detail hardware profile list, If your IEEE1394 device had correctly install on your PC system and recognize by Windows XP then you will found a IEEE1394 bus host controller and at least one item of IEEE1394 device (My Sony VIAO is : Texas Instruments OHCI Compliant IEEE 1394 Host Controller )from the list. Please confirm the device status window shown : ( This device is working properly ) or not.
The jvc player is supplied with company software and i think it is not compactiable with sony software as software each company model and make differ in the different software.....................
Posted on Jun 25, 2008
SOURCE: no luck loading video to pc
I dragged and dropped the file into a new folder and it opened right up on the computer.
Posted on Nov 18, 2008
SOURCE: jvc power cinema NE for everio digital video camera, no sound on dvds??
I had a similar problem, I could play videos on my PC but they had no sounds.
I found a solution
In theory *.Mod Files contains mpeg format for the video and AC3 format for the sound.
In my case I was missing the codec fot AC3 format.
I downloaded one here:
http://www.free-codecs.com/download/ac3_filter.htm
And it worked
Sam
Posted on Feb 21, 2009
Sound bars
It has red and white RCA jacks you should be able to use as the input from your tv. Plug into audio out on tv.
Apr 14, 2014 | Panasonic SC-HTB65 Home Cinema Sound Bar...
Tring to connect my samsung tv to my samsung home cinema and having problems
Hi,here is my simple solution...
to listen your TV on your Stereo system thru your
samsung home cinema receiver,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
samsung home cinema RECEIVER corresponding your RCA or Optic connection..
There you go..Your TV sound is on the
samsung home cinema Receiver..By this means whatever you watch on the TV (TV tuner, satellite , Xbox ..etc.) ,it's sound will come thru your stereo..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Samsung Audio Players & Recorders
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
I dont have pip is there any software i can buy
Yes there are many sorts, you can get USB, or Internal cards, I myself have a Pixelview PlayTV Hybrid, that allows me to view, HD DVBT & Normal TV as well. In fact I use two cards, another Pixelview internal BT878, chipset. I run them boyh, so I can work on one screen, and have HD TV, & Normal TV PIP'ed on my other monitor, it all works great. Dscaler is a wonderful software to use.. But the software that comes with the cards works well too. One Must be set to RGB & the other to Overlay, though to allow both to work at once. Download Dscaler below, it plays DVD;s great as well, simply the best out there. deinterlace.sourceforge.net/
Feb 27, 2010 | Panasonic PT-43LC14 43" Rear Projection...
No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Dec 10, 2008 | Panasonic SC-HT75 System
Can't get tv sound from home cinema system speakers
you need an optical cable going from the TV to the home cinema for an audio output, it worked for, had the same problem!!
Dec 04, 2008 | Panasonic Home Theater System System
Buzzing in speakers of cinema surround
i have the same problem. haven't tried the fix yet, but someone recommend connecting the two pronged power cord to an adapter that switches it to a 3 pronged (adds the ground prong). i guess the adapters are less than a dollar and can be bought at most places.
Dec 04, 2007 | Audio Players & Recorders
37pf7531 tv
If you have a later Philips home cinema model: HTS3100, 3300, 3500, 3154, 3357, 6510 & others, the sound from the TV will go through the existing scart connection.
Just select TV on the home cinema remote control.
For any other models, use a scart - twin phono lead (red & white), from the TV to one of the inputs into the home cinema.
Scarts 1 & 2 on the TV will have different results. Try both.
Nov 29, 2007 | Philips 37PF7531D/10 37 in. LCD Television
JVC Everio GZ-MG21 Camcorder Logo
340 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
