Question about Dell A940 All-In-One InkJet Printer
Paper not feeding thru
Is grasping the paper at an angle. Paper not feeding all the way my documents will not print. Help.
  • 173 Answers
If you do a lot of printing and have had your printer for a awhile more than likely you will need to replace the roller assembly (which is not as hard as you might think). Try making some adjustments and such first to see if you can get it to print properly without messing up the paper and printing some target pages. The best place to purchase a new roller assembly is through the manufacturer of your product because they should have exactly what you need. You can find what you need by typing in your make and the model number. Their website should also give you information about things to try first and also some good tips and suggestions about how to keep your machine running at optimal performance. The following link will take you to dell's official website . Let me know if you need further assistance.
If you do not mind please rate my help, I would greatly appreciate it. Thanks
Posted on Aug 23, 2008
Copying 8.5x8.5 original thru document feeder and it doesnt aal print
Most copier has an APS (Auto Paper Selection) as default, 8.5 x8.5 is a square original, I would suggest you manually select the paper tray (e.g. Letter) first (this will temporary disable the APS for this session), then lay it down on the original glass, or ADF (Auto Document Feeder).
If you do not disable APS, you will have paper jamming problem, you do not have 8.5 x8.5 is th paper tray, of course, you may try it feed from the by-pass tray, set the the paper size to 8.5 x8.5 or special size ....... Each manufacturer has a different name for the same function (terminology).
Nov 12, 2013 | Canon for IMAGERUNNER C2020 C2050 C2058...
Epson C86: paper not feeding and prints at an angle
try feeding the paper through manually if you cant do this then try printing a blank page and see if this still wrecks the paper if it does then it does sound like something is jammed on the roller the best way to clean this is with a blast of air from a compressor this is the only sollution as it will cost more to replace the parts than it would to buy another printer if it is still under warranty they should replace it for you if not you could take it to a computer repair shop where they will strip it down adn rebuild it for you this is a paper feed problem but im sure their must be somethig sticking in the way or maybe the paper feed has come lose at the one end sorry i couldnt help you any more ........................................
Oct 31, 2007 | Epson Stylus C86 InkJet Printer
Clean the feeder paper feed,separator roller with cloth and alcohol.
Feb 01, 2013 | Konica Minolta bizhub Office Equipment &...
The printer only prints half a page then moves to next page and a
Before printing, the printer checks the paper size. If the paper edge guide is positioned incorrectly, the paper may be fed at an angle. If this happens, the bottom of the paper is therefore at an angle and not perpendicular with the paper feed rollers. This can result in the paper sensor not recognising the real page width as it can only detect a certain amount of the bottom of the paper sheet which is nearest to it.
If only part of the width of the paper is detected, the printer considers that the paper width is less than it actually is. To avoid printing on internal parts of the printer such as paper feed rollers, the printer automatically cuts the image to fit the detected paper width As this phenomenon depends on the paper feeding condition, it can be random.
Reload the paper and make sure it is loaded correctly. All the way to the right and the paper guide correctly adjusted.
Feb 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Paper jams when using the ADF. Canon IC D780
When using ADF
* Set a document on the Platen Glass if you want to scan it at optimum quality,
* The area (range) within 0.08"/2mm from the top edge if document cannot be printed since the machine cannot scan it.
*Do not load the following types of documents in the ADF. They will jam.
-Wrinkled or creased paper
- Curled paper
- Torn paper
- Paper with holes
- Carbon paper or carbon-backed paper
- Surface treated paper
- Onion skin or thin paper
- Photogragh or thick paper.
1) Remove any documents from the PLaten Glass.
2) Open the Document Tray.
3) Load the document in the ADF.
Load the document with the side you want to copy, or scan face up in the ADF.
4) Adjust the Doument Guides to match the document width.
Note :
Ensure that the edge of the document stack is in line with the Paper Size Mark imprinted on the Document Tray.
Hope this helps.
Please rate my response.
Have a good day.
Nov 30, 2009 | Canon Office Equipment & Supplies
MP830, how to retrieve faxes in memory to my PC
- A margin appears
on printouts.
2 B Paper feed
Improper paper
- Multi-feeding
- Skewed paper
- Paper jam
- Paper feeding from the
- Plain paper
- Highest print speed
(Custom setting to 5)
- In the high temperature
and high humidity
- In the low temperature
and low humidity
- With the maximum
amount of paper set (13
and high humidity
environment, paper
becomes wavy; in the
low temperature and
low humidity
environment, paper
curls significantly.
When the maximum
amount of paper is set
in the ASF, and if the
paper-return tab fits in a
wave or curl of the
paper, the tab slips and
does not catch paper
properly, causing paper
feed problems.
- Reduce the amount of
paper set in the ASF to
half (approx. 5 mm
- Multiple sheets of
paper feed at the
same time.
- Paper feeds at an
- A paper jam
3 C Print results
Skewed paper
feeding (at the
level of +/- 1%)
- Credit Card size
Since coaxial tolerance
between the pinch roller
and the LF roller, which
determines the paper
feed alignment, is
0.2mm, skewed paper
feeding can occur.
However, according to
the field data of current
models, the skewness
level caused by the
coaxial tolerance of
0.2mm is within the
criteria of +/- 1%, thus
the phenomenon is left
as is.
- Align the paper guide to
the paper edge tighter
than usual.
- Paper feeds at an
- A margin appears
on printouts.
4 A Print results
Soiling on the
back side of paper
(lines or streaks
parallel to the
paper feed
- After continuous
borderless printing of
small sized paper (such
as 4 x 6), when a larger
sized paper (such as A4)
is printed.
- With Photo Paper Plus
Double Sided or
postcards, the
phenomenon is likely to
be noticeable and to be
complained of by users,
as printing is performed
on both sides of such
In borderless printing,
printing is performed to
the size slightly larger
than the paper size, and
ink off the paper is
absorbed by the platen's
ink absorber. Absorbed
ink may attach to the
platen rib(s) after
several dozen sheets are
printed, causing soiling
at the leading edge of
paper or on the back
side of paper.
1. Perform Bottom plate
cleaning (from the
MP driver or via the
operation panel) up to
3 times*1.
2. If soiling on the paper
still remains after 3
times of Bottom plate
cleaning, wipe the
platen rib(s) and their
surroundings with a
cotton swab.
- Paper gets
- The back side of
paper gets
Soiling on paper in
automatic duplex
printing (lines or
perpendicular to
the paper feed
- Automatic duplex
printing (Photo Paper
Plus Double Sided,
postcards, plain paper)
On the rib(s) inside the
sheet feed unit used for
duplex printing, ink
mist may accumulate,
smearing paper.
Temporary operational
Cancel automatic duplex
printing, and manually
print each side of paper.
Cleaning by user:
cleaning (from the
3 times*1.
- Paper gets
- The back side of
paper gets
- Even after Bottom
plate cleaning
was performed,
and the platen
ribs were cleaned
with cotton swab,
paper gets
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Copy of documents misaligned vertically on Canon Imagerunner 3045
Hello sir; When you feed originals in portrait, the paper tray have to set by portrait direction too.
Mar 30, 2009 | Canon Office Equipment & Supplies
Paper going thru at an angle and jamming
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Paper wont feed propaly
Something probably fell into that tiny pinch of an area where the paper goes. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over, poke it if you have to, and shake it around til the little bugger falls out.
Sep 22, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X73 print/paper problem
Same problem here. Went thru a few tests with Lexmark but didnt help. They next said it would be best to get new one since repair cost would be higher. Thru front door I do see a spring that moves freely. That must be broke. After their help they sent email for 20% off.
Sep 12, 2007 | Lexmark X73 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
62 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
