Question about Samsung SyncMaster 540N 15" LCD Monitor
Samsung monitor troubleshooting
Monitor is receiving power, screen stays black. Can it be repaired?
  • Anonymous Aug 25, 2008
    Screen Stays Black even it is powered on.
  • 3 Answers
If it is black when you power it on, then let it sit 10 minutes or so. Then, if the screen is a nice, even warm across the whole screen you know the inverter board is working and the bulbs are lit. That means the LCD screen is bad, or the controller board is bad or the firmware needs upgrading. If the screen is still cool, then the inverter board is bad.
Posted on Sep 28, 2008
  • sureshearn May 21, 2011
    all comments are wrong.. i m samsung engineer.this prblm occurs coz of capacitor(C115) .replace it (1000uF/10v) ur prblm wil solve..for more information call me 9730944747
My computer power is on and my computer also start quick but the screen of the this moniter start after 15min to 30mins this problem how to solve.
Monitor is receiving power,screen stays black.
Posted on Sep 16, 2008
WHY IS THE GREEEN POWER BUTTON FLASHING ON MY MONITER AND THE SCREEN THEN GOWS BLACK
When the power light is flashing the monitor is not getting a stable signal. This is hard to answer without direct troubleshooting. Check the cables first, make sure they are connected securely. If you still have problems test another monitor you know works or move monitor to a computer you know works, this will determine if the monitor is the problem or not and tell you if it is your "graphics port or adapter". If another monitor works fine, use the working cables to test the "broken" monitor. If you have an "all-in-one" computer, ignore the above steps and use a start-up repair disk. The reason this is hard to troubleshoot is there are so many things to diagnose. More than likely your "graphics card" is failing. These are some tricks to repair. You can update the driver, buy a graphic card separate from the stock port.
May 21, 2016 | Dell E172FP 17" LCD Flat Panel Monitor
I have a Samsung SyncMaster 172n monitor and the screen stays black when I turn the power on. The power light starts flashing about 3 seconds after I turn it on. All the power cords are plugged in, the...
When the monitor starts up you should be able to see the Samsung screen logo, if not it does point to the monitor. But lets be sure! hook a spare monitor to the computer, if it is okay! the Samsung Monitor is the problem and is not cost effective to repair, cheaper to replace. Now if both screens show the same problem, this indicates the Video Graphics Card in the computer is the culprit.
Jan 19, 2011 | Samsung SyncMaster 172N 17" LCD Monitor
I HAVE A SAMSUNG 2253 22' LCD MONITOR,POWER LIGHT FLASHES,AND SCREEN STAYS BLACK ,IT TRYS TO LIGHT UP ,BUT STAYS BLACK,MY OLD TINY 15' LCD WORKS FINE ON THE SAME COMPUTER,MY 22 USED TO WORK FINE??????
A flashing power light like that indicated a blown power supply. Your monitor should be under warranty with Samsung. Check the mfg date on the back sticker, if it is less than 3 years then contact Samsung. If it is out of warranty then contact us at tech@ccl-la.com and we can get you the info you need to do the repair yourself.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | Computers & Internet
My screen stay black, the monitor has power al2017
I called tech support and it was suggested to send the acer AL2017 monitor back to them to make repairs to the circuit board.
Dec 10, 2009 | Acer AL2017 20" LCD Monitor
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
Samsung 940bf-screen stays black
Your monitor is having a problem with the power supply. Because of the small spaces in the monitor case heat builds up and causes parts called capacitors to blow. If you can solder you should be able to do the repair yourself. Go to our web page2.gif at:
www.ccl-la.com/badcaps.htm and look at the pictures and repair guides. Open your monitor and look for parts that look like the pictures. Replace any that you see and your monitor should be back operational.Be sure to install the new parts with the polarity stripe on the side going the same direction as the bad ones came out. You will need to replace them with a high quality part with high temp value (105c). If you don't want to do the repair yourself we do offer a repair service.
I hope this helps, if so please rate my solution.
Buddy
www.ccl-la.com
Sep 10, 2009 | Samsung SyncMaster 940BF (Black) 19" LCD...
Monitor keeps losing the screen and goes black several times before it finally stays on
it happened may b due to inproper power supply.So check the monitor data cable & other connections also.
Aug 08, 2009 | Acer 22" X223w LCD Monitor
Samsung 931B Monitor Screen will not stay
jane657, Hi there. Will you stop pushing the On/Off button on your lcd/fpd. It's Broke. Period. End. Finito!!! You will not fix it. However there is one test that you should do to determine hoe bad the problem is. You will need to reconnect the 931B to a known good pc that has been fully booted and has the WIN-DESKTOP or IE fixya web page showing. quickly connect the931B to the wall outlet and the PC. Turn on the monitor!!! Yes, I know it will only come on for a second..After the screen goes to BLACK, Shine a bright flashlight onto the screen at different angles, 1-2 inches from the screen. Let me know if you see something even though the screen is black. Anyway here are your options as a consumer/user. 1. Check if unit is under warranty. 2. Check withh Samsung to see if they have a SWAPOUT program. You send them your monitor+$40-$90 and they return a refurbished same model to you with a 30 day warranty. 3. Trade in for new monitor. 4. Check with local TV/Monitor repair guy who knows all there is to know about cold-cathode-fluorescent-tubes, their power-source(inverter type) and lcd monitor power supplys (SMPS) 5. Repair on your own. Not recommended for amatures with no solid state troubleshooting skills and no instrumentation for support. Bye for now. I'm louie12fix on fixya or lmistyrel@ aim.com
May 14, 2009 | Samsung SyncMaster 931BF LCD Monitor
My monitor is receiving power but the screen stays black.
Hi..!
check your system's RAM or memory..
otherwise your motherboard is faulty..
Check it out..
Amit..
Feb 20, 2009 | Samsung SyncMaster 540N 15" LCD Monitor
Samsung SyncMaster 540N 15" LCD Monitor Logo
1,782 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Brian Sullivan
Brian Sullivan
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
