Question about Acer Aspire 5600 Series 5630-6951 Laptop
Acer laptop sporadic fan/dvd drive noise
My brand new aspire 5315-2176 laptop makes this sporadic noise like a fan coming on every three or four seconds. Is this normal? Appreciate any help.
VJF
    President:
  • 2,961 Answers
It is quite normal especially if you are running processor hungry applications, or down loading video files
Posted on Aug 23, 2008
SOURCE:
Laptop making loud fan noise like its overheating,
Go buy a can of compressed air and blow out the fans and vents. That should get it running quiet again.
Jun 08, 2012 | Acer Aspire 5336-2524 Intel Celeron 900...
The disc drive on my acer Aspire 5742G will not read any music cd's or dvds. I makes plenty of noise as though it is trying to open it but nothing!
The CD/DVD drive may need reseating to make proper electrical connection. Remove this drive and insert it back into the laptop.
Next try cleanibg the drive.
The laser lens maybe dirty, use a CD/DVD lens cleaning kit to clean the lens int the drive.
If this does not fix your problem then the CD/DVD drive is faulty and needs to be replaced.
Apr 01, 2012 | Acer Aspire 5742G
My aspire 5551 is new, but now once in a while, it makes a rumbling noise, like as grinding motor, should i worry, is it serious?
Well the ONLY things that could possibly make a grinding noise are the cooling fan (or fans) or a hard drive. Those are the only moving parts inside a laptop. If it does it while trying to access data it's probably the hard drive, which would be serious. Back up data ASAP and get a new drive. Shut it down and don't use it until you back up your data. The more probable option is one of the cooling fans/cooler. Blow it out with compressed air through the vent slots located on the bottom or the sides of the laptop. If this persists you would need to order in another fan. Call Acer about it if you think this is the issue. You would need to open the laptop up and install it yourself or get someone else to but it's an easy fix. Good luck!
That is unless the noise is coming through the speakers, which would be another problem...
Jan 18, 2011 | Acer Aspire One PC Notebook
Laptop recently started to make noise on start up, feels and sounds like it's coming from the area below the keyboard in the lower left part, it's an acer aspire 5570-2067. it makes noise for a while, then...
Def sounds like the fan , from where you say the sound is coming from . normally the fan should be able to be cleaned the panned holding the fan in the left hand corner . clean the fan with compressed air , or a paint brush . if this fails then you need a new fan .
Nov 23, 2010 | Acer Aspire One PC Notebook
The CD drive of my laptop Acer Aspire 4530 is not working. I've tried four CDs/DVDs, but it doesn't recognise them. I tried restarting. Is there something that I need to check on my laptop?
Open "My Computer".
Do you see an icon for the CD-drive?
If not, then you have a hardware problem (no electrical power to the drive, or the "data" cable is not connected, or the electronics inside the CD-ROM have failed).
Take your computer to a qualified technician, and get him/her to install a brand-new CD/DVD reader/writer, to replace the "dead" one.
Sep 26, 2010 | Acer Aspire 4530-5889 Notebook PC
It wont detect a dvd on my acer aspire 5315 laptop
If your laptop won't detect DVD drive try and check connection first. Turn your laptop upside down and remove three maybe four screw (deepens on laptop) directly over a DVD drive and pull drive out. Blow some compressed air inside of laptop and check for anything abnormal on drive itself. Then put it back in and check if it works. If not it's either bad DVD drive or bad motherboard. Thanks and good luck.
Apr 17, 2010 | Acer Aspire 5315 Notebook
Buzzing sound in Acer Aspire 5535
I've come across this before and it turned out to be the soundcard driver. See if there's an updated driver on Acer's website.
Strange buzzing can also be caused by a stuck or damaged key. Does pressing ESC help at all?
Unlikely to be the hard drive. They crunch and grind but don't buzz, unless they're completely knackered, when they can give you a three-tone buzz sound and won't spin up at all.
Hope that helps,
Matt
Aug 24, 2009 | Acer Aspire 5535-5050 Notebook
My acer aspire 4720z wont play any dvd's or cdroms
go ahead and delete the upper filter and lower filter
check it in safe mode
update the driver or reinstall the driver for the drive ......
May 02, 2009 | Acer Aspire 4720 Notebook
Acer aspire 2930 DVD player only opens some dvds
Try Media player classic under k-lite codec pack. Then open video files on the dvd. If it doesn't help try another codec player. If nothing helps could it be that dvd player is not capable of multilayer dvd reading.
Apr 10, 2009 | Acer Aspire 2930-4661 Notebook
Brand new acer,spindle is too large on multi drive for cds or dvds
There are three little spring loaded things that you have to push together to get the DVD or CD to fit, I had the same problem
Sep 15, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 5600 Series 5630-6951 Laptop Logo
284 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
