Question about Dryers
Dryer heats the first time and than goes cold
I already replaced the ignitor
  • juker2 Aug 23, 2008
    I replaced the 2 coils and the dryer is working fine
    Genius:
  • 1,028 Answers
Replaced the 2 black coils on gas valve if ignitor is glowing but burner not firing
Posted on Aug 23, 2008
Heats up for short time then goes cold. Cleaned out dryer vent. removed front of dryer and cleaned out inside trap and blower between trap and exhaust
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Aug 10, 2011 | Maytag MDG2706A Gas Dryer
My Kenmore gas dryer 110.97566210 works and heats when starting cold, after several cycles, the ignitor glows but the gas valve won't re-open. Is there a high limit sensor? i read a faulty ignitor can...
heatman101=-=-
Aug 05, 2011 | Dryers
My dryer heats up ok but after a short time it just blows cold air
heatman101][
Aug 03, 2011 | Dryers
I came home and my dryer had still been running for the whole time I was gone, about 4 hrs. The clothes inside were cold and not dry. This morning I tried getting it to work, but the clothes remained...
heatman101
Apr 23, 2011 | Roper Dryers
Dryer isnt getting hot its electric and i already replaced the heating element but did not replace the thermostat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 25, 2010 | Dryers
Ive changed the ignitor, sensor, thermostat, fuse-thrml, and thermostat-fix.. my dryer still is only heating for only 5 min then goes cold. what can i do? model: LGR7646JQ0
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils.
Nov 11, 2010 | Whirlpool LGR7648KQ Dryer
Gas dryer wont heat up, blows only cold air.what would cause this
Could be a bad hi limit thermostat. Could be a bad glowbar ignitor. Check the glowbar ignitor at the gas valve, is it glowing bright orange/red? If not. Replace the ignitor.
Jul 22, 2009 | Whirlpool Dryers
Gas dryer heats for couple minutes then goes cold
sounds like gas valve is not opening. your ignitor has to pull 3.2 to 3.6 amps to open gas valve. check amps
Jun 22, 2009 | Kenmore 63942 Dryer
No heat Whirlpool dryer
when you turn on the dryer does the ignitor glow if it does replace the coils if not check the thermal fuse
Dec 19, 2008 | Dryers
Dryers Logo
117 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
