Question about Nintendo Wii Console
My Wii Remote is acting up and the cersor is not appearing I have done everything the people tell me!
When ours does this it is the battery.
Posted on Aug 23, 2008
How do you re-align a Wii remote?
To Adjust the Wii Remote Pointer Sensitivity, follow these steps..
  1. Access System Settings.
  2. Select "Sensor Bar."
  3. Select "Sensitivity."
  4. Aim the Wii Remote at the television.
  5. Use the + and - buttons on the Wii Remote to adjust sensitivity until only two blinking lights appear.
  6. Press the A button when done.
Wii U
  1. From the Wii U Menu, select "System Settings."
  2. Using the Left Stick, scroll to the "Wii Remote and Sensor Bar" icon and press the A Button.
  3. Select "Adjust Wii Remote Pointer Sensitivity."
  4. Tap "Next."
  5. Point the Wii Remote at the sensor bar and press the A Button.
  6. With the Wii Remote pointed at the sensor bar, press the - and + Buttons to adjust the sensitivity so that only two white dots are visible in the black window.
  7. When you are finished, press the A Button.
  8. On the Wii U GamePad screen tap "OK."
Dec 14, 2017 | Nintendo Wii Console
My control for the wii will bring up the menu but the courser that you use to make selections does not appear.
Make sure the sensor bar is correctly plugged into the Wii, and that the Wii Remote has a clear path to the sensor bar. Move the Wii Remote around, as the positioning of the sensor bar may not be precise. If you are sure everything is how it should be, it may be that your sensor bar is damaged and/or broken. You may have to buy a new one.
Aug 20, 2011 | Nintendo Wii Console
Player 2's remote won't work when the dancing starts, but it will work for everything else. Player 2's motions are not being registered and won't count for points. Then the player 2 disappears (because it...
We had the same problem: IF YOU OPEN THE BACK COVER ON YOUR WII REMOTE THERE IS GOING TO BE a red button and some where on the WII too so you press that at the same time and your done
Dec 26, 2010 | Ubi Soft Just Dance 2 for Nintendo Wii
We have bougt a new controller how do we get it to work with the wii home console do we press two buttons together to get it to work? Can you help thanks
Lots of people have this problem including me, what you do is turn the Wii on,( turn off other Wii remotes once done turning on Wii system), press the connect button on the Wii remote 1st before pressing the SYNC button on the Wii system. If the Wii remote you are talking about is like the classical N64 remote then i cannot help you at the moment but there should be a manual that tells you how to connect it. I can do some research for you if none of the following work.
Sep 29, 2010 | Nintendo Wii Remote Controller
I have a wii remote charger and have just purchased some rechargeable batteries but they don't appear to be charging, everything is set up correctly but remote only showing 1 light lit and then going dead
Make sure your charger is plugged in your Wii AND turned on. If you do this, the remotes should charge.
If the remotes still don't charge, there's a problem.
May 03, 2010 | Nintendo Wii Remote Controller
Missing Wii character
you may have erased it from your wii fit but not your normal mii chanel
Jun 24, 2009 | Nintendo Wii Console
Pokemon Battle REvolution rental can't start the game
it could be simply that the remotes are not turned on.or it could be that they are not pointing it at the motion sensor or they are standing too close.
I would advise to stand atleast 5 feet away from the screen
note that the blue pokeball is the wii remote pointer
Mar 01, 2009 | Nintendo Pokemon: Battle Revolution for...
Troble with my wii control
Take out the batteries, replace, and then hit the synch button on both the console and next to the batteries in the remote. There's no reason it shouldn't work after you've done this.
Dec 29, 2008 | Nintendo Wii Console
Wii freezing up
Hi Ashley,
It sounds like the accelerometer in your Wii Remote is not working properly.
The "point-and-click" stuff like the Wii Menu use the WIi Remote's camera (which is behind the dark part on the front of the Wii Remote). The motion-sensing for swinging, tilting and other motion uses the accelerometer in the Wii Remote.
Wrap your Wii Remote in a towel and give it a whack against your knee (not so hard as to injure your knee) - sometimes the accelerometer part gets "stuck" and needs to be jarred out of position.
If that still doesn't work, then go to, click Support, and go to the Wii Troubleshooting section for more options.
Also, you don't have to use the same remote as #1. The first remote that is activated will become #1.
You can also push the Home button on the Wii Remote, then point to the bottom (where the battery levels are shown), press A, then click on Reconnect. It will tell you to press the 1 and 2 buttons on each remote in the order you want them to appear. Press the 1 and 2 buttons on the remote you want to be #1, wait for the remote to sync (the Wii will make a happy nosie), then do the same for the remote you want to be #2, etc.
Apr 01, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
13 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
