Question about Asko W6021 Front Load Washer
Asko excellence dishwasher
How to remove F2 light flashing
    Sergeant:
  • 351 Answers
Check in the base for a water leak.
Posted on Aug 27, 2008
Hi I had f2 flash up on the control panel so we drained it and turned it back on it now shows 5 on the control panel and wont do anything else it is a ASKO D1976
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be there when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now. Hope it helps...
Daniel
Jun 08, 2011 | Asko D1976 Built-in Dishwasher
My Asko Dishwasher D1976 on the main panel all of the top lights are on and in the display window it flashes F2. The motor is on but nothing else is happening can you help. I have checked that drains are...
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be ther when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now.
Hope it helps...
Daniel
Apr 22, 2011 | Asko D1976CSTM Built-in Dishwasher
My asko dishwasher flashing F2. Can't stop it! What do I do! Thanks, Elva
Hi
Hope it helps...
Feb 16, 2011 | Dishwashers
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
ASKO Dishwasher F2 light flashing
Hold the Rinse button for 5 seconds to reset.
Jan 19, 2009 | Asko D1776 Built-in Dishwasher
Asko dw95.4 dishwasher flashing f2 when switched on
remove the dishwasher from under the bench and tip it back to let the water run out from underneath,remove the rear panel at the bottom and run test for leaks or blockages.
Oct 09, 2008 | Asko Dishwashers
Asko Excellence Dishwasher Model # 1504
I have a manual for 1504 and it says F2 blinking means high water level in machine
Apr 15, 2008 | Asko W6021 Front Load Washer
Asko 1895
water in base remove dishwasher and tilt to side and it will restart,but you may have a leak,also check the inlet valve may not be closing fully.hope this helps.
Mar 06, 2008 | Asko 24 in. 1895 Built-in Dishwasher
Asko Dishwasher F2 Error Flashing
F2 flashes, and wll not stop runing. No water in pan. help
Sep 29, 2007 | Asko D1776 Built-in Dishwasher
Asko W6021 Front Load Washer Logo
115 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
