Question about Akai PT5492S 54" Rear Projection Television
Red light comes on but nothing else
Remote sensor stopped working at first then tv would turn on and off by itself now will not come on at all.
I AM HAVING TROUBLE GETTING A PICTURE OR SOUND ON MY TV THE RED LIGHT STAYS ON BUT NOTHNG ELSE, WHAT DO YOU THINK I SOULD DO, IS THERE SOMEWERER AN INTERNET SITE OR STORE THAT I CAN BUY THE MANUAL TO TRY TO FIX THE PROBLEM BEFORE CALLING THE REPAI MAN?
Posted on Aug 30, 2008
SOURCE:
The red power light comes on but nothing else works on my hitachi 53FDX01B PROJECTION TV
silly question but have you tried turning it on with the remote. if a tv has been turned off by remote and then power goes, turning it on by the tv switch will put the tv back in stand-by mode and you need to use remote.
just a suggestion.
Dec 13, 2013 | Hitachi 53FDX01B 53" Rear Projection...
TV CODE FOR SANYO TV FOR PHILIPS REMOTE
I turn on the tv and nothing comes on the screen. The tv set turns itself off and it blinks red 3 times fast and then 6 times slow....
Nov 06, 2010 | Philips Universal PH301S Remote Control
My remote does nothing that it was made to. It just stop working. I changes batteries and still the tv does not respond. When I press a button on the remote the red light comes on just like when it was...
try to check your remote sensor if working.Using your cellphone camera,point your sensor on your cellphone camera you should see a illumination of light on your remote control once you press the a button on your remote..if not try to fit your battery tou your remote there might be a loose contact on battery terminals..or open the casing of your remote control.visually inspect the battery terminals from a loose contact and corrosion.if this dont solve your problem,replace the crystal oscillator of the remote..it is the color orange square in shape with two terminals soldered near the ic..it is labeled with frequency....
May 17, 2010 | Toshiba 32A30 32" TV
Need the code to set the technika remote to ma toshiba telly
Maybe you could try the auto-set. Found this using google:
Auto code search
1. switch on the TV and select a channel eg. Bbc1 on the TV itself
2. press the appropriate device button eg. TV
3. press the green SET button for approx 5 seconds until the red light comes on.
4. release the green SET button and point the remote at the device to be controlled, the remote will emit a test signal about every 2 seconds.
5. when the TV switches itself off briefly press the green SET button to store the code found.
6. when the red light goes out the search is ended.
7. try out the remote if it works follow the same steps to set it to other devices eg. DVD. If it does not work follow the steps again.
cover other remote sensors on other devices when setting the remote.
Apr 01, 2010 | Televison & Video
Pioneer PDP435PG inadvertently reprogrammed by Casablanca remote.
Some ceiling fans have jumpers that can be moved to select a different frequency but you have to be sure both the remote and the fan receiver are set the same. Other than that, you may have to use some creative control. For example, I can turn on my TV by pointing the remote at the wall opposite the TV
Mar 29, 2017 | Pioneer PDP-4350HD 43 in. Plasma...
Volume on sky+ remote
my sky + remote has stopped working the red light comes on when i press buttons but nothing happens
Apr 06, 2009 | Televison & Video
Technika tt-16 universal remote control codes for a beko tv
Auto code search
Nov 10, 2008 | RCA Universal Remote Control
Powers on by itself
TV worked FINE for the past 2 yrs---this morning we woke up and the screen is totally BLACK! No sound..nothing. REmote doesn't do anything to the TV. Red light says ON unless we unplug it. Remote won't turn off the TV.
Any advise? Picture tube??
Worked great w/out any problems until we woke up today!
Thanks,
Tina
Jun 01, 2008 | RCA 32V420T 32" TV
Won't turn on
my orion tv is not working,it just stopped
Apr 29, 2008 | Televison & Video
SVA HD4208 42INCH Plasma will not turn on. Hi! My TV will not turn on. I have a red light lite up by the remote control sensor. When I hit the power button on the remote the red light blinks. Then I hear a...
The issue with these TV's are the boards internally go bad, for Power the three capacitors get round at the top and either you replace the whole board from SVA fro 300.00 or buy three capacitors and replace them
May 05, 2007 | SVA-USA HD4208TIII-VR 42 in. Plasma...
Akai PT5492S 54" Rear Projection Television Logo
107 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
