Question about Lands Phones
I LOVE TO TEXT I DO NOT USE T9 WHEN IM TYPING AND MAKE A MISTAKE WHAT BUTTON DO I USE TO DELETE I HAVE A LG KG800
    Master:
  • 848 Answers
Press the button C (cancel).... it is used to delete the text message ....
Posted on Aug 23, 2008
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
Daughter borrowed phone and switched the text msg typing to auto fill and numbers. I have tried every thing and I can't figure it out, can you please help me? Thank you, Susan
Based on your description, what you are referring to is called T9 Predictive Texting. It allows words to be entered by a single keypress for each letter, as opposed to the multi-tap approach used in the older generation of mobile phones in which several letters are associated with each key, and selecting one letter often requires multiple keypresses. Example, when typing the word 'love' in a T9 activated phone, all you have to do is press the numbers 5, 6, 8 and 3 once in sequence. As compared to the regular texting, in order to complete the word 'love', you have to press the number 5 thrice, the number 6 thrice, the number 8 thrice, and the number 3 twice.
If you want to disable T9 predictive texting, it can usually be disabled by pressing and holding the hash or number key (#).
Hope this information is helpful.
Apr 08, 2011 | LG Cell Phones
While typing in aim my laptop keyboard skips letters, randomly selects a new im, or underlines words.
Tape a double piece of paper directly over the touchpad.
(If you don't use it). It worked for me. Now I don't have to worry about accidently hitting it and making my typing skip or delete text by mistake.
Feb 17, 2010 | Fujitsu Computers & Internet
Cant text in t9 mode
a master reset of the phone will help
Nov 24, 2008 | Motorola Mobility RAZR V3
Texting and taking off the t9 feature of assuming what im going to type
sometimes it will pop extra words up like that for me, but i found that if you just ignore it and keep typing, they will go away. try it :)
Aug 18, 2008 | LG Shine KE970 Cellular Phone
The text dictionary keeps giving me the wrong words and i cant change, how do you knock it off. the phones a samsung d900i
Using T9 mode
T9 is a predictive text input mode that allows you to
key in any character using single keystrokes.
Entering a word in T9 mode
1. Press [2] to [9] to start entering a word. Press
each key once for each letter.
For example, press [4], [3], [5], [5], and [6] to
enter HELLO in T9 mode.
T9 predicts the word that you are typing, and it
may change with each key that you press.
2. Enter the whole word before editing or deleting
characters.
3. When the word displays correctly, go to step 4.
Otherwise, press [0] to display alternative word
choices for the keys that you have pressed.
For example, OF and ME use [6] and [3].
4. Press [ ] to insert a space and enter the next
word.
Other T9 mode operations
• Press [1] to enter periods or apostrophes
automatically.
• Press [ ] to change case. Lower case (No
indicator), Initial capital ( ), and Capital lock ( )
are available.
• Press [ ] to insert a space.
• Press the Navigation keys to move the cursor.
• Press [C] to delete characters one by one. Press
and hold [C] to clear the display.
Adding a new word to the T9 dictionary
This feature may not be available for some languages.
1. Enter the word that you want to add.
2. Press [0] to display alternative words for your key
presses. When there are no more alternative
words, Spell displays on the bottom line.
3. Press <Spell>.
4. Enter the word you want using ABC mode and
press <OK>.
"The faulty interface lies between the chair and the keyboard"
Apr 21, 2008 | Sony Ericsson w580i Cellular Phone
Need help on my lg kg800 chocolate phone
i think its factory defect or try to reset the factory setting///
Feb 03, 2008 | LG KG800 Cellular Phone
T9.
To activate T9, undertake the following steps:
Messages
New text Message
Press the first button from the right on the last row
Go in the option T9.
Choose 'On'
Nov 21, 2007 | LG Prada KE850 Cellular Phone
Text messages
u hav to press on the part of the screen where ur typing till a faint down arrow comes there. press that and change the word. if the word is not there you must create it in the t9 function. to create a word from scratch press on the part of the screen where your typing a few times and the press options then press create word.
Nov 05, 2007 | LG Prada KE850 Cellular Phone
Lands Phones Logo
77 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
