Question about Technics Audio Players & Recorders
I have a SA-203 receiver. I am trying to hook it up to my computer to record my LPs. I have run a stereo cord from the headphone jack to my "line in" on the PC. When I play anything (stereo, turntable or cassette) on my computer, only 1 speaker works. The software that I am using to record (Spin It Again) reports the same problem. Is there a way to fix this, or do I need a new stereo? (I bought this system in 1982).
I did hook up my PC to my SA-203 successfully. I noticed the amplification was weakest when I hooked up through the "phono" connection but in all cases both speakers worked. Be certain you have plugged in the cables completely and the contact points are clean. If you open your Technics SA-203 you will see it is apparently not very complicated so if the connections are the problem you can probably even fix it yourself. Go to Radio Shack online as it is unlikely the sales help knows s**t about there electronics part bins and probably neither will the manager. But once again, I really believe you just need to fiddle with the plug at the "phones" connection on your receiver. Good Luck and sorry I took so long.
Posted on Oct 28, 2008
How to hook up stereo audio receiver VSX - D704S to my laptop
You need an 1/8" stereo jack to rca cord. Plug into headphone out on PC then into back of receiver (I.e. aux/cd). Then turn stereo to that input.
Oct 08, 2016 | Audio Players & Recorders
I have RCA cables , How do I use my computer music ? What connections and settings?
Are you trying to play music off your computer through a stereo or receiver??? If so you will need a cord with red & white (rcas's) on one end & an 1/8" jack on the other...Run it out your headphone jack of the pc (usually color coded light green) and turn input of stereo to corresponding input you plug into..
May 23, 2016 | Kenwood Kr-5600 Vintage 70s Am/fm Stereo...
Need help connecting to PC
You need adapter cable 3.5mm mini stereo plug to double RCA plugs (one red, one white). Plug 3.5mm end into headphones/audio out socket on PC, RCA plugs to AUX IN sockets on rear of SA-222, select AUX on front of SA-222 to hear audio from PC through system speakers.
May 03, 2017 | Panasonic Technics Sa-222 Receiver
Hello, I have a Sony STR-D85 surround sound system. I need to connect my phone to the system so that my phone's music plays through my surround sound speakers. The front of the console has a headphone...
Headphone jack is an output not input jack. Your going to need a cord to go from your headphone jack(output) of your phone to audio input on your receiver. The cord has a mini stereo plug to the phone and RCA plugs of left and right to your receiver auxiliary input. Good luck..
Jul 15, 2011 | Sony STR-DE485 Receiver
How to connect speakers to RCA model #RP-8070D
This unit is just a 5 disc CD player and cannot drive large speakers all by itself. Normally it is hooked up to a stereo receiver / amplifier which is what provides the power to drive the speakers which are wired to the back of the stereo amplifier.
If you have a home stereo, then just run the cables from the 2 AUDIO OUT connectors on the back of your CD player to the CD IN connectors on the back of your stereo.
Then turn your stereo on and select CD on your stereo input mode selector and you should be able to play the cds on your RCA and hear them through the stereo speakers.
If you do not have a stereo amplifier with speakers to connect it to, then you can always listen to it through headphones connected to the headphone jack.
Or if you have a set of self powered amplified speakers, like the kind you hook up to a computer, then you can run the AUDIO OUT cable from your cd player into those as well.
Good luck.
Apr 14, 2011 | RCA Audio Players & Recorders
We are trying to hook our TV up to our computer to use it as a monitor. What cords do we need to do this besides the normal monitor cord?
if you want audio as well, it will depend on what kind of audio connection your tv has next to the VGA (computer monitor) connection. If it looks like the normal RCA audio, (red and white plugs) you will need to get a male headphone jack (to plug into your computer headphone or speaker out jack) to stereo RCA cable so you would have a headphone jack on one side of the cable and a red and white plug on the other side. Now if your TV just has what look like a headphone jack next to the VGA (computer monitor plug) you will need to buy a male to male stereo headphone jack cable. for both of these, just make sure the cable you get it long enough, or buy an extension.
Mar 21, 2011 | Sansui HDLCD1908 19 in. LCD TV
On the box, it says I can hook it to the tv, but there's no jack that hooks to the tv....
You need a 3.5MM FEMALE Stereo Jack (looks like a headphone jack receptical) to stereo RCA MALE cord. Then plug it into the RCA monitor or audio out of the TV.
Cheers,
Kevin
Feb 26, 2010 | Philips MMS 321 Computer Speakers
HOW CAN I HOOK UP MY IPOD TO MY RECEIVER
Use a phono to RCA stereo jack (pic below) and hook one end to the head phone jack on your ipod and the other ends to your amplifier aux or tape input and adjust the volume to low on the ipod - select the input on the stereo - Aux or tape in.
You'll need this type of cable
Nov 13, 2009 | Technics SA-EX500 Receiver
IPod Won't Play In Stereo
Dear , your headphone jack needs to be replaced..This is a very common failure in Classic models..However your ipod should work normal Stereo on the dock ..Take care.
Sep 10, 2017 | Apple Audio Players & Recorders
Harmon Kardon SC20
Easy, just use standard rca patch cables from the Tape Out jacks to the audio input jacks of the cd recorder.
Jan 14, 2009 | Audio Players & Recorders
484 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
