Question about Acer Aspire 3680 Laptop
Moved network hi. i'd had my laptop connected as the main computer for my network, concerning my internet connection, with a linksys router connected to that, and a linksys adapter for my pc connection. i just moved and my pc is the main connection for my internet, and my laptop doesn't seem to work without the internet connection. can i hook up my router to my pc and my laptop to my adapter, or is this something somebody'll have to situate for me? cuz i'm not really computer literate. thank you shaun
    Genius:
  • 2,028 Answers
You should be able to switch the two, however, if this requires a network to be set up in order to run both computers through the same router, I recommend having someone do this for you.
Posted on Aug 23, 2008
We have a main computer that the Linksys Router is connected to. My laptop used to be on the network. The hard drive died on the laptop and a new one was installed. All info is gone. I am trying to connect...
Hi
You do not say which operating system you are using.
First look under or on the back of the router to see if the network key is printed there.
If not, it will be in a prominent page in the router's Installation Manual.
Alternatively, right click on the main computer's wireless icon bottom right of screen > network and sharing center > click on the router icon > view status > details/wireless properties > security
This will show you all the details of your router.
Aug 26, 2011 | Linksys Computers & Internet
I have a wireless network of computers, one wired and 2 wireless. in the correct setup, my other acer laptop doesn have internet, but s connected to the router, and this laptop im using CAN connect...
All the computers should have the same NETWORK NAME or SSID.
Recheck the settings and make an adhoc connection for each of the computers to your router.
You can also get a USB wireless adapter to enable ht NO internet laptop and connect them.
Just keep playing with the NETWORK SETTINGS.
Make sure all are connected to the SAME SSID.
Hope it helped.
God Bless You!
Feb 05, 2011 | Linksys WRT120N Router
Internet signal is fine, works on main computer but not on laptop
download the driver here
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?os=19&softwareitem=dj-28354-1&lc=en&dlc=en&cc=us&lang=en&product=57565
Apr 03, 2010 | Linksys Wireless-G WRT54G Router
Laptop says no internet connection
First you need to ensure proper connection and filtering. Make sure the source cable is plugged into the Linksys router first. Direct connections must be made to the router, meaning the cable to your main computer should come from the router, not the main source.
Next make sure that the connection is made. You should see a light on the router indicating proper internet connection. Once this is accomplished, connect your main computer and you should have access to the internet on it.
Now comes the easy but somewhat tricky part (tricky only because icons can vary a little). If you haven't already done so, run the setup disk for Linksys. It's has simple, easy-to-follow instructions to set up your network. Now for the laptop. On the blue bar at the bottom of the laptop screen there should be an icon indicating internet connection. Click on that icon to show available wireless networks. Most likely your Linksys router will show up as a secure network. When you click on that connection it will ask you for a WEP key. That key is usually a 10 digit alpha-numeric key written on the back of the router. Sometimes it's on the box the router came in. Sometimes it requests a 12 digit WEP key, in which case simply add two zeros to the front of that same key. If you set up a password for your wireless network you will need that as well.
NOTE: if you have neighbors close, you should always secure your network with a password.
You may need to shut down and restart the laptop in order for the changes to take place.
It sounds confusing, but once you start you'll find that it's actually fairly straight forward. I hope this helps. Good luck!
Jan 12, 2010 | Linksys Wireless-G WRT54GS Router...
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Carl
Jun 21, 2009 | Linksys Wireless-G Broadband Router
When I try to connect my router to my laptop, the 321 error screen appears after about a minute. It says my ethernet cable is not plugged in properly, but it definitely is. Even the connection lights on...
This is a well documented problem with linksys routers. Go to google and type in "error 321 linksys". You will have to manually configure the router as stated on the linksys forum posts.
Jun 05, 2009 | Linksys WRT54G2 Wireless Router
Slow wireless internet connection for select PC's; fast for other
Make sure that your wireless mode is set to "mixed mode".
Intermittent Connectivity:
NOTE:
Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 20, 2009 | Linksys Wireless-N WRT150N Router
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
No internet connection on two desktops
Hi Tony, you think your laptop is connecting to your neighbor's wireless network. So try this.
1:Go to Control Panel, click on network and internet connections, double click NETWORK CONNECTIONS. Point your mouse to the WIRELESS NETWORK CONNECTIONS. It should show that you are connected(and it will show the name of the network that you are connected to). If you do not recognize the name of the network that you are connected to then you are connected to your neighbor's network.
IF YOU ARE CONNECTED TO linksys--unsecured wireless network, there is a chance that your wireless router is not functioning at the moment.
Try this first and i will be waiting if you have a follow up problem.
Good Luck
Mar 12, 2008 | Linksys Wireless-G Broadband Router
You are connected to access point but the internet cannot be found.
Do you have a connection wizard that you can run on your computer? Linksys offers them for downloading at their website. Try that -
have you named your home network so your wireless connection can "find" it? You don't mention how your main computer is networked in. A wireless adapter for a notebook will need to have a Linksys connection wizard run on the laptop.
If you have a Linksys router connected to your main computer, it should already have the piece of software you need. Most likely, you'll need to put it on a flash drive and install it from that onto your laptop. the wizard helps also to diagnose the right settings.
If you want to post what you are using for your main network (linksys router?) and which operating systems you are using, that will help.
For example, in Vista, you'll need to enable the option for "network discovery" under your laptop's control panel/network and sharing center.
You also need to have certain settings on your main computer for the wireless to work - there are two main types of wireless connections - B and G. Most of today's routers and cards will do both, but if you have an older router, it might not be set up to handle the newer or combined types. They run on different frequencies, so your laptop might not be "reading" your router's frequency.Also, if you have other wireless/radio frequency equipment near your laptop, it can interfere with the signal being received right.
You also need to be sure that your firewall allows the linksys system to access your computer (allowed programs).
Dec 10, 2007 | Linksys WPC54G Wireless-G Notebook Adapter...
Acer Aspire 3680 Laptop Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
