Question about La Pavoni "PROFESSIONAL Chrome" 16Cup
Steam escapes while machine tries to heat up
This is a new machine, I have used it less than 6 times. It worked fine this morning. I started to make an espresso tonite, and when the machine was trying to heat up, I noticed a lot of steam escaping thru that big nut on the top right of the machine. I'm not sure what that piece is called. Of course the machine could never reach "pullable" temperature.
Can anyone help me....please?
Kathy
  • kjashley Aug 23, 2008
    I let the machine sit for awhile, already having decided from my chat session that it should be exchanged for a new one since it was only a few days old.
    For some reason, I decided to put some more water in the boiler and try it again. This time, steam started to escape thru the big nut again, then I heard something sort of click, and the steam stopped coming, and the machine heated up and it worked as it should have.
    This is wonderful!!!!!
    Problem Solver:
  • 5 Answers
That big nut is the pressure relief valve. It should normally be closed, unless the machine overheats, in which case it will vent the steam, thereby preventing an explosion.
The valve design means that it's somewhat normal for some steam to vent as the machine heats up, but once it gets close to working temperature, it should seal.
Pavoni does now have a replacement valve that avoids this problem. When your machine needs a major service, hopefully more than 5 years from now, you may decide to get the upgraded valve fitted.
Fergus.
Posted on Sep 08, 2008
Brew switch not responding
your not far,
test your switch with a test light
or you could always jumps the wire direct to your pump
if nothing works check for parts on ebay.
Jan 06, 2014 | Gaggia 102534 Espresso-Color...
Commercial espresso machine
Sounds like the safety thermostats on the machine is tripping because the machine is overheating or the circuit breaker is tripping because machine needs more amperage.
Nov 14, 2012 | La Marzocco Coffee Makers & Espresso...
Cuisinart Brew Master 00wpc brews slowly with most water escaping as steam
Try cleaning with white vinegar, using the method described in the owner's / instruction manual.
Jan 03, 2018 | Cuisinart Brew Central 12-cup Coffee Maker
Red boiler light will not go on. The boiler does heat up.
Open the steam valve when you turn the machine on that will vent out the boiler, keep it open until it starts to hiss slightly and produce small steam bubbles, then close and machine should heat to temp. If that solves your problem then the vent valve needs to be replaced, until then you can turn using the steam valve open trick.
May 31, 2010 | Isomac Tea Espresso Machine
At the end of initial pressure-up after first turning my Epoca on in the morning, the pressure goes past 'normal' until it blows the escape valve. What is wrong? Thanks. Matt
The vent valve is stuck in the open position, leave the steam wand open, while the machine is heating until you hear it hissing, then close steam wand and machine should heat up properly. Replace the vent valve as soon as possible.
Mar 01, 2010 | Rancilio Epoca ST-1 Espresso Machine
No Steam, No Coffee!
The steam boiler, might be damaged, or the main board is not sending power to the steam boiler. Open machine and check resistance on steam boiler elements.
Apr 18, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Steam escapes from the join
Some steam may escape even when the pot is put together correctly. However, make sure that the metal strainer disk is correctly nested in the thick rubber washer on the underside of the top piece, and that the washer is seated tightly and evenly.
May 17, 2008 | Alessi 9090/6
Steam escapes Steam Buggy
I've faithfully used by little yellow Steam Buggy to clean tight corners in my replacement windows and was always to get them looking new again and many other small places that needed blown out with steam when wiping or even scrubbing with a toothbrush doesn't work. I started to use it today and the steam started to come out around the black cap. After searching for a solution on the net I was very disappointed to find everyone else was having the same problem with no real solution. I had my hubby look at it and he said the gasket was worn and slip an o-ring on top of the gasket and now it back to working fine.
Just wanted to pass it along. A 10cent O ring will fix it.
May 12, 2008 | Tristar SB Steam Buggy Vacuum
My Vev Vigano Kontessa 12 cup espresso maker does not work properly
I had the same problem, so I embarked on a search mission. Here's what I found, and it worked for me. First, these pots are designed to work only for the amount of water specified for each size. So I have a 6 cup pot that requires 9 oz of water. If I try to put 8 oz. of water, I only get about 1 maybe 2 oz of coffee. Size of the grind doesn't matter as long as you stick to espresso grind (some coffee grinders have several settings for espresso grind). As soon as I put exact amount of water, it works much better. Now, you have to understand that some water gets evaporated as steam, and some water should remain in the boiler section of the pot for safety reason. The general advice is to take the pot off the burner as soon as the gurgling sound reaches its peak and just starts to subside.
That may result (as least for me) in weaker coffee than I like. So what I do, is I fill the coffee funnel with coffee grinds, tamp it very lightly, and then using a wooden skewer I make 3 or 4 holes all the way to the bottom of the funnel. That will help the steam to escape. Before I learned this trick, I thought it was a valve problem or a seal problem. As soon as I tried this trick, bingo! I personally like strong coffee. So I didn't want to compromise it and start adding less coffee to the funnel. The thing is that steam wets and expands coffee grinds, and that may be enough to hinder the process. If you make several holes, steam will not be building in the boiler section and escaping thrgough the valve or break the seal on the gasket.
Hope this helps.
Apr 11, 2008 | Vev Vigano Kontessa Oro 12-Cup Espresso...
La Pavoni "PROFESSIONAL Chrome" 16Cup Logo
474 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
