Question about Canon Rebel XT / EOS 350D Digital Camera
Terminal Cover will not stay closed
Terminal cover bent while in bag. Won't stay closed on one end or the other.
  • KBREBELXT Sep 19, 2008
    Thank you, sm4344! I'll try your fix!
  • 81 Answers
I assume you're referring to the rubber cover on the left side of the body, if so, just get some black gaffer tape from your local camera shop. It holds very well and does not leave any residue on the body.
Posted on Sep 18, 2008
SOURCE:
I own a elecrolux 2100. the power light comes on but the vacuum wont start
First, turn dial on top of vacuum counter-clockwise so the smallest dot lines up with the arrow. See if it stays on. If not, detach hose and turn vacuum on. Place palm of hand over intake. If it turns off, it's possible that the tubes connecting to the CVA are clogged and simply need cleaned. This is most often caused by using "made to fit" Electrolux bags. Dust is sucked through the bags and into the motor compartment of the machine. All interior parts get covered in dust and need to be cleaned. If this is the cause, the vacuum is best cleaned and repaired at an authorized Aerus Electrolux store. If the vacuum shuts off, or won't turn on before placing hand over the intake, it's probable the control valve assembly is bad and needs replaced.
Another cause is an overheated motor due to clogged screen at back of bag well, full or clogged bag, dirty afterfilter, bad wiring/connections, clogged hose, clogged power head, or bad motor. It depends largely on the type and model of cleaner. Clogged wands are also a possibility, but unlikely.
Check and clean screen at back of bag well.
Replace bag. Make sure it's a genuine Electrolux bag made by Home Solutions.
Check and replace afterfilter if necessary. These should be replaced after every six bags.
Broken and worn wiring connections are often found in the hose ends due to abuse and normal wear and tear. You can check the continuity of the hose using a continuity tester or multi-tester. If a multi-tester, turn dial to one of the Ohm settings. Place one probe into one of the terminals on the end of the hose. This will be referred to as T1. Touch the other probe to each of the terminals/connections on the other end of the hose. These will be T3 and T4. One of them should read zero, the other should read infinity. Repeat this with the other terminal, which will be T2.
Drop a marble in one end of hose and let it roll through. If it doesn't roll through, the hose is clogged and needs to be cleared. Plug hose into the exhaust port of the vacuum, place other end in the in port. Turn vacuum on. This provides a blowing and sucking action which should clear the hose.
Detach hose from power nozzle (PN). Drop a marble into the wand end of PN. If it rolls through, it's clear. If not, there's probably a clog behind the brush where the intake opening is. You may be able to reach this through wand end with needle nose pliers, or either end with a knitting/crochet needle or a bent coat hanger.
If none of these "fixes" provide the answer to the problem, it should be taken to the nearest Aerus Electrolux store for diagnosis. Repairs or checks involving disassembly of the vacuum should always be done by an authorized Aerus Electrolux service technician.
The store nearest you can be found by following the instructions at the below listed link:
http://www.aerushome.com/storelocator/
Apr 17, 2011 | Electrolux Vacuums
My vacuum shows a full bag after 20 seconds of running. Put a clean bag and the same thing happens.
Mar 31, 2011 | Electrolux Epic 6500 Vacuum
My electrolux2100 every time i turn it on it stays on for about 1 min then the proctection button come on then the machine turns off i wait a second and then it turns back on and does it again what can i...
Mar 29, 2011 | Vacuums
Unit turns off when any type of restiction to air intake. For example when unit is turned if hand is held in front of hose connection unit will turn off
This actually cover several models of Aerus and Electrolux canister vacuums. Models covered include: 2100, Epic 6000, Epic 6500, Aerus Lux 5500, Aerus Lux 7000, and Aerus Lux Legacy. Be aware that some of these models may still be under warranty. Any disassembly of those machines will void the warranty. Use of non-genuine bags also voids the warranty. Use only Home Solutions Aerus/Electrolux bags.
Mar 04, 2011 | Electrolux Epic 6500 Vacuum
Does not turn on epic 6000
Feb 27, 2011 | Electrolux C101 Bagged Canister Vacuum
I install a new bag and the bag light comes on and the unit turns off.
Feb 19, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
Changed bag and filter, filter light keeps coming on, not working
Jan 12, 2011 | Electrolux UltraLux 2000 Bagged Canister...
I have an electrolux 2100 canister vacuum that turns right back off every time we push the power button. We have a new bag installed on it, and it will stay turned on if the hose is off, but as soon as we...
Dec 29, 2010 | Electrolux Vacuums
The "change bag" light has
Dec 28, 2010 | Electrolux Epic 6500 Vacuum
Canon Rebel XT / EOS 350D Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
