Question about RIM BlackBerry Pearl 8100
Dual band amateur radio ic-3210a no rx no tx on uhf side?
    Brigadier General:
  • 6,966 Answers
Since the problem involves both the RX and TX of the UHF (assuming display/logic circuitry is OK), then possible areas of concern would be:
  • UHF VCO/PLL section;
  • UHF voltage regulator.
I am assuming that you are comfortable/familiar working with electronic circuitry and components, a DVM and a soldering iron. Initial course of action would be:
  • check for CPU triggers to IC4 and IC6;
  • check +5 & +8 regulator and the 30V DC to DC converter (unlikely, but worth the effort).
  • of course comparing with standards voltage checks would be the best route. A service manual would be of help.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 23, 2008
Receives,no Tx
Many possibilities:
1: The radio took a hit and broke the PCB or the connection to the RF out jack.
2: Some other PCB joint failure
3: The RF output IC is toast
4: The driver is toast
5: The tx oscillator is so far out of whack it cannot develop the frequency it is set to.
6: You have a bad cable or antenna connector
7: You have a bad battery, battery contact or power connection
8: You have a power supply or other problem
Sep 26, 2015 | Icom IC-T7H VHF/UHF Handheld Dual Band...
My baofeng radio will transmit but will not reseive
Check your settings for the RX frequency. Then check to see if the RX Tone is turn on and is set to the correct frequency. Just turning the rx tone off should allow you to hear any station coming in.
Aug 06, 2014 | Dual Uv-5r Baofeng Band Uhf/vhf Radio Usb...
Reset kenwood tm-v71a
There are more steps than just powering the radio on while pressing the function key. Please review the steps listed on this page: http://www.manualslib.com/manual/86675/Kenwood-Tm-V71a.html?page=95
Jun 04, 2014 | Kenwood Tm-v71a Vhf & Uhf Dual Band Mobile...
Will recive but will not trasmit uhf
Can you give details with the model#. is it a dual band VHF/UHF
will it RX UHF etc..
Apr 20, 2013 | Uniden Radio Communications
I have an Icom v-8000 radio.The TX is very good with 75 watts out-put. But have nothing in RX.No signal and no audio.
What you have is an amateur band radio, which requires you to be a licensed operator to use it. It is possible that the frequencies have been removed from the eeprom prior to your purchasing same.
You can have Rx only frequencies programmed by an authorised 2-way workshop, but until you become a qualified amateur operator, you will not be able to get Tx frequencies programmed.
For licensing info for Amateur operators visit www.vk6wia.org.
Regards,
Peter
Feb 20, 2013 | Radio Communications
Will not receive and transmit on 15mtrs and 17mtrs
Hi Seamus,
Is this only on those bands, not an issue with other bands?
If so, then your radio may not be fitted with the correct frequencies to transmit on those bands, they are after all allocated in part to the Amateur operators, which requires licensing to operate.
The fact you can't Tx/Rx, indicates this to be the issue.
I can't help you if you are not a licensed HAM Operator, sorry...
Enjoy the other bands available for your radio.
Cheers,
Peter
May 06, 2012 | Yaesu FT-1000MP Owners Manual
Why can't i listen to aircraft pilots & tower on my Uniden bearcat BC60XLT-1? Our airband frequency here is 108-137 mhz.
Your scanner does not receive frequencies between 54 and 137 MHz, and there's nothing you can do to enable reception in that block. Your only option is to purchase a scanner with air band coverage. Here are the reception ranges of the BC-60XLT-1:
29.0-29.7 MHz 10 Meter Amateur Band
29.7-50 MHz VHF Low Band
50-54 MHz 6 Meter Amateur Band
137-144 MHz Military Land Mobile
144-148 MHz 2 Meter Amateur Band
148-174 MHz VHF High Band
Above bands in 5 kHz steps
406-420 MHz Federal Government
420-450 MHz 70 cm Amateur Band
450-470 MHz UHF Standard Band
470-512 MHz UHF "T" Band
Above bands in 12.5 kHz steps
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
Bill B.
Listening in since the 60's
Feb 26, 2011 | Uniden Radio Communications
Cobra 148GTL can't TX on USB
Its the cap that feeds the first transistor to the first of the finals. It is either shorted or burned out.
Or the audio IC. It could be putting just enough out on AM to seem like its working, and then not enough for side band.
look at the caps near the finals. Look for a burn one, or one that could be twisted, or shorted in any way.
May 01, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
What's the channel frequencies for a common 22 channel motorola 2 way vhf radio?
Not sure what you want.....VHF band ius approximatly 130mhz to 175 mhz..... in that VHF band there is a commercial VHF band aprox. 155 mhz to 175...... the amateur radio vhf band is aprox. 135 to 150mhz.
With amateur radio, any freq in that range can be used...... with commercial radio the FCC cangive a company any freq. in that range also.
If you are looking for FRS/GMRS frequencies they are UHF freqs not VHF.
So I'm not sure exactly what you want......sounds like you might want to program in FRS freqs into an Icom amateur radio. If thats  the case you will need an Icom that will do UHF freqs.
Oct 12, 2007 | Unwired UFR650 (14 Channels) 2-Way Radio
RIM BlackBerry  Pearl  8100 Logo
117 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
