Question about Onkyo TX-SR602 Receiver
Assigning inputs or selecting the type of vidio stream i want to use for my dvd player.
If i select dvd player on the onkyo, how do i assign the orange vidio input or inputs on the unit.......
Not sure if I understand completely, but if you want to watch a source on DVD then then it needs to have its a/v outputs connected to the DVD inputs on the rear of the receiver.
Posted on Oct 31, 2008
Unable to connect a blu ray dvd player to onkyo tx-sr605 via hdmi
Not sure what unable to connect means..but I will assume you have the correct cable.
First make sure you have plugged the from the HDMI cable from the DVD play into the IN 1 HDMI port on the back of your Onkyo
On the Receiver
Enter the Setup mode
Select INPUT OUTPUT ASSIGN
Next make sure the HDMI monitor out is set to YES on the Receiver
Monitor out
HDMI Monitor - YES
Next you need to assign the HDMI INPUT to DVD
HDMI INPUT
DVD - IN1
CBL/SAT - IN2
This may be your issue.
Next step would be to verify your television input settings.
Nice receiver!
Best of luck!
Apr 13, 2011 | Onkyo TX-SR605 Home Theater Receiver 7.1...
My television picture does not appear on my zone 1 and zone 2 television. I just get a blue screen although I get audio. The crazy thing is that when the function is set to DVD. I get the picture. I...
Hi. Most likely the assigned input isn't correctly setup. Try this:
1. Press 'setup' on your remote control.
2. Navigate to 'Input Assign'.
3. Navigate to the correct next option (HDMI/Component/Digital) - this depends on how you have connected your DVD player up.
4. Find the name of the connection you've plugged your DVD into (physically look at the back of the receiver).
5. Select the DVD option, and press left/right until you have selected the correct input.
You may need to change to Tuner then back to DVD, but that should do it.
If you need further help, please let me know exactly how you've connected your DVD player (HDMI? component?), and the name of the physical connection you've plugged into.
Hope that helps!
Mar 04, 2011 | Onkyo TX-SR876 Receiver
Assinging coaxial 1 to dvd
hi.
Do the following to assign COAXIAL 1 to dvd.
1. Press the DVD button on frond panel ( will display the current setting).
2. Press and hold DVD button for 3 seconds ( will display the selections ).
3. Press DVD button rapidly and select COAX 1 ( will sect COAXIAL 1 as DVD input).
ok
Feb 18, 2011 | Onkyo TX-DS484 Receiver
I cant get the surround sound to work after connecting the Samsung BluRay Player to my Onkyo reciever using a optical digital connection or directly with the HDMI cable ?
Hi
You will have to assign the optical input to the input you are using, so for instance if you have plugged the optical cable into opt 1 on the onkyo reciever and wish to use the DVD input on the onkyo reciever, you need to go into the set of the onkyo to digital assignments or in/out assignments, dependent on the model, and select OPT1 for the DVD input. You can find out how to exactly do this in the onkyo's manual under 'digital assignments' or 'input assignments'.
Regards
TechSupp12
Dec 12, 2010 | Samsung BDC6500 BluRay Player
Why cant I supply my onkyo surround sound system
You need to assign the HDMI input(s) to the functions they represent, using the Front Panel Tuning/Preset control...
If you connect a video component to an HDMI input, you must assign that HDMI Input to an input selector in Setup.
For example, you could assign the “DVD” setting to “IN1”, and assign the
“CBL/SAT” setting to “IN2”.
Likewise if you use digital audio inputs...
Assigning the Digital Input
If there’s no sound, press the [DIGITAL INPUT] button repeatedly until sound is heard. The digital input is now properly assigned.
If you connect your DVD player to the AV receiver’s COAXIAL 1 DIGITAL IN, and your cable/satellite receiver
to the COAXIAL 2 DIGITAL IN, as shown, it’s not necessary
to assign the digital input.
Feb 12, 2010 | Onkyo HT-S5100 Theater System
Onkyo HT-S6100 to OPPO Dv 980H to Sony Bravia KDL 40W4100
Make sure none of the Digital or Component Input Assignments are programmed, if you're not using them. Set them to "----". This may help. Some of the Component input assignments may over-ride your other input assignments (perhaps even the HDMI input assignments).
Jan 25, 2009 | Onkyo DV-S353 DVD Player
Receiver will not recognize a 5.1 input
Have you selected the digital input through the audio setup? You can assign different digital inputs to various video inputs and this may solve the issue
Jan 17, 2009 | Onkyo TX-NR905 Receiver
Dvd player hookup
Push setup, go to menu where the digital inputs are selected and set coax to video 2. I think it's the initial setup menu but not sure.
Aug 22, 2008 | Onkyo TX-SR602 Receiver
VSX D511 No input select
I am getting no sound via my optical cable input. The back of the AMP says that the optical is TV/SAT but i can't change the input to digital it will only go to analog. DVD player is set to Bitstream all dvd options set to DTS, but still no sound going through. Any help would be apprecaited
Jan 29, 2008 | Pioneer VSX-D511 Receiver
What settings
What ever you want. the onkyo reciever allow you to select what input the hdmi inputs are assigned to.
you can assign DVD to hdmi 1, or 2, what ever you want.
Check the manual how to assign inputs.
Nov 07, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR602 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
