I cant get my wireless router to work - Computers & Internet
  • 22 Answers
IF YOU MEAN NO POWER OR INDICATOR LIGHTS,PRESS AND HOLD THE RESET BUTTON ON THE BACK FOR ABOUT 5 SECONDS.UNPLUG THE POWER.WAIT A FEW SECONDS MORE AND RE APPLY THE POWER.IF YOU MEAN TO WORK WITH YOUR DSL MODEM,RE-INSTALL YOUR ROUTER SOFTWARE AND THEN HOOK UP THE HARDWARE.MODEM,ROUTER,CAT CABLES,ETC.
Posted on Aug 23, 2008
6ya staff
SOURCE:
Trouble printing from wired connections but wireless users are working fine
Its possible that in ap mode it cant handle wired and wireless and that the wired connection takes priority of the only available ip address, thus the wireless cards cant get an ip and so cant connect.
of course that could be b*****s but you never know.
yes i know you said it works fine when using xp pro so maybe the router doesnt release the ip correctly with win7.
any chance of installing a wifi card from one of the xp machines into the win7 machine just to test it?
can you test connecting one of the xp machines with wired and see if the other can connect using wireless?
So please You will have to reboot your router and all the wireless XP systems, while the Win 7 system is off. You may have to reboot the router once in a while. Not the most elegant solution, but this is the only way my XP systems with wireless would work.
Nov 03, 2011 | Adtran NetVanta 1335 Router (1700515E2)
Cant connect ,no light on wireless connection. was
you need to setup the wireless connection if you havent already and your router needs to be a "wireless" router in order to create that type of internet connection. Have you laptop then scan for one which would be the one you just made and input the correct information to connect. If that doesn't work I'd suggest getting a new wireless router
May 06, 2010 | Belkin F5D8236-4 Router
Our wireless net work comes up but we cant connect to it why?we have a wireless g wgr614v9 router and we cant log on to it with the passphrase
The Netgear router needs the wireless settings configured i.e SSID, WPA encryption etc and the wireless card in the laptop/computer needs to be configured with the router's wireless settings for the laptop/computer to connect with the Netgear wireless router. Pleas click on this link and follow my instructions to secure your wireless network, configure the wireless router's settings and configure the wireless card in the laptop/computer :-
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 21, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Cant sign in to wireless password not accepted
Try to connect your computer with an ethernet cable with the router
Open the router interface using the default gateway that your computer is receiving
Under Wireless, select security and check the security mode and check the compatibility with your operating system.
Remove all preferred wireless networks from computer
If the compatibility is appropriate, and if security key is exact(case sensitive), this is sure to work
Jan 17, 2010 | Linksys WRT54G2 Wireless Router
Pc not finding network ...internet working (going thru router) but not finding network. cant get to login screen for router to adjust any settings. Ps3 cant communicate with wireless router either....
I think you will need to check the wireless settings of the router.
try changing the wireless channel on the router.
make sure that the SSID broadcast is enabled.
for this you will need to access the router set up.
Click Here for step by step solutions
Nov 03, 2009 | NetGear WGR614 Wireless Router
Cant get it to work
try to plug it into the modem then plug the router into the wall then try it
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 17, 2009 | Belkin (F5D7231-4) Wireless Router
Cant get my router to work
Connect the computer to LAN port one of the router using an Ethernet cable, access the configuration page (ie 192.168.1.254), configure the router as Dynamic IP, Configure the wireless network as (WEP or WPA), Check the IP address of the WAN section.
Note: If you have an IP address to the WAN section the Internet connection is working, Connect through the wireless network by finding the wireless network name was been created to the router.
Mar 09, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless conection
i cant remember the password so i cant log online fr om my router
Feb 09, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Cant connect to wireless router
Make sure the wireless adapter is enabled on the elonex laptop and its properly installed.
Connect wirelessly on the elonex one laptop using the same SSID and security key that you used on your main laptop.
Aug 07, 2008 | Belkin (F5D7230-4) Router (587009)
Can't Connect to Internet
there is a need to reconfigure your router to work with your modem. If configured already before, then there is great chance that this has been set back to factory default.
Oct 06, 2007 | U.S. Robotics USRobotics USR5461 Wireless...
Open Questions:
Computers & Internet Logo
32 people viewed this question
Ekse
Marvin
Marvin
