Need installation instructions for Maxtor 80 GB 7200 RPM Ultra ATA/133 8 MB Cache Hard drive for compaq presario sr1630nx microsoft xp
  • 22 Answers
GET SUPPORT AT HP.COM FOR INSTALLING A HARD DRIVE FOR YOUR COMPUTER MODEL.GO TO MAXTOR TO GET SUPPORT FOR INSTALLING THE HARDDRIVE MODEL YOU HAVE.JUMPER SETTINGS,ETC.
Posted on Aug 23, 2008
Hi,I've an external case (diamondmax 11 Model:6H500F0)--500GB SATA 3.0GB HDD. And I wanna to activate it,but I Dont have the Installation CD,plz I need your help URGENTLY. (I've an widows XP for my...
Maxtor DiamondMax 11 is a SATA Hardisk and you need SATA External Case. After adding the Harddisk, all you have to do is connect it to the system via the cable of the external case. There is no need for additional drivers/ CD as all the external harddisks are 'plug and play'and the Operating System detects them automatically.
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Maxtor DiamondMax 11 400GB 7200rpm 133MBps...
Hi my drive will only format as fat, i need it to load xp on it, am i doing something wrong?
No, your not doing anything wrong. The FAT32 file system is for smaller drives while the NTFS is for drives in excess of 100GB.
Oct 16, 2010 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
Need to know the capacity of A Maxtor internal drive SN:A60PVPVC Ndl:91303D6
The 13 GB Maxtor 91303D6 internal 5400 RPM hard drive can be connected via IDE. This 3.5" drive is designed for use with Windows. The 91303D6 is a drive with 512 KB of cache.
13GB EIDE ULTRA DMA/33 3.5LP 5400RPM
Aug 08, 2010 | Maxtor Hard Drive
I'm not sure wish Maxtor I have D740X-6L
Parameter Maxtor D740X-6L - Capacity 80 GB - Areal Density 40GB/platter - Interface Ultra ATA/133 - No. of Platters 2 - No. of Heads 4 - Buffer Size 2 MB - Rotational Speed 7200 RPM - Acoustic Noise 3.0 bels
- Avg. Rotational Latency 4.2 - Internal Data Rate (max) N/A - Avg. Seek Time (Read) 8.5 ms - Avg. Track-to-Track
Seek Time (Read) 0.8 ms
Mar 10, 2010 | Computers & Internet
I need to know what kind of hard drives and other hardware i can use with a HP Compaq D530 Socket 478
HERE shows an overview of the specs for the HP d530 series. Shows IDE type HD's.
Technical Specifications - Hard Drives
7200 rpm SMART III Ultra ATA/100 Hard Drives 40-GB Capacity 40,000 MB Rotational Speed 7200 rpm Interface Ultra ATA/100 Height
1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including settling) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 78,165,360 Operating Temperature 41° to 131° F (5° to 55° C) 80-GB Capacity 80,000 MB Rotational Speed 7200 rpm Interface Ultra ATA/100 Height
1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including settling) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 156,301,488 Operating Temperature 41° to 131° F (5° to 55° C) 160-GB Capacity 160,000 MB Rotational Speed 7200 RPM Interface Ultra ATA/100 Height 1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including setting) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 320,173,056 Operating Temperature 41° to 131° F (5° to 55°C)
Feb 21, 2010 | Computers & Internet
How much i can upgrade my d530 ultra slim desktop RAM and HDD
You can install up to a max 2 GB RAM and can add a 2nd hard disk
See the following Specs for your computer.
dotclear.gif HP Compaq Business d530 Ultra-Slim (Pentium 4 2.8GHz, 256MB RAM, 40GB HDD, XP Pro) Type Personal computer
  • Product Form Factor Ultra-slim desktop
  • Built-in Devices Speaker
  • Width 12.4 in
  • Depth 13.1 in
  • Height 2.8 in
  • Weight 15.4 lbs
  • Color Silver
Processor
  • Type Intel Pentium 4 2.8 GHz
  • Installed Qty 1.0
  • Max processors supported 1.0
Cache Memory
  • Type L2 cache
  • Installed Size 512.0 KB
  • Cache Per Processor 512 KB
Mainboard
  • Chipset type Intel 865G
  • Data bus speed 533.0 MHz
RAM
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM
  • Memory Speed 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor DIMM 184-pin
  • Upgrade Rule Max 2 x 1 GB module
Storage Controller
  • Type 1.0 x IDE - Integrated - PCI
  • Controller interface type ATA-100
Storage Controller (2nd)
  • Type 1 x Serial ATA - Integrated
  • (2nd) storage controller interface type Serial ATA-150
Storage
  • Floppy drive type None
  • Hard Drive 1.0 x 40.0 GB - Standard - ATA-100 - 7200.0 rpm
  • Hard Drive (2nd) None x None
Dec 08, 2009 | HP Compaq Business d530 Ultra-Slim PC...
I need to replace the hard drive in my v5000 Compaq laptop. it is currently a mk8025gas toshiba 80gb. how do i choose a newer updated hard drive to match? do i just install and turn back on with the xp...
Basically you insert a new drive and insert the Windows XP installation CD and follow the screen instructions.
The specification for hard drives for the Compaq V5000 are as follows :-
Table 6-3
Hard Drives
120-GB* 100-GB* 80-GB*
Dimensions
Height
Width
Weight
9.5 mm
70 mm
102 g
9.5 mm
70 mm
102 g
9.5 mm
70 mm
99 g
Interface type ATA-5 ATA-5 ATA-5
Transfer rate
Synchronous (maximum)
Security
100 MB/sec
ATA security
100 MB/sec
ATA security
100 MB/sec
ATA security
Sep 30, 2009 | Compaq Presario 1.8GHz Mobile AMD SempronT...
S-ATA Hard Disk not detect
hi Dear,
You have to update your BIOS. If you have intel mother board just go thought their website and download BIOS Flash utility of your particular Board and Update BIOS.
The above fix will surely solved your problem.I had same problem as you and it's now fixed.
May 10, 2009 | Computers & Internet
Bigger hard drive
I'm not sure if the motherboard supports SATA drives, so your best bet is getting any IDE (ATA) hard drive. It's up to you which kind you want. I've always been partial to Western Digital and Seagate.
If you are running Windows XP then you shouldn't have a problem with having a larger hard drive, I know Windows 2000 had some issues with them that required registery editing.
Dec 11, 2008 | Sony VAIO Digital Studio PCV-RZ22G PC...
Whats the largest replaement HD I can put in my Presario
The HD capacity is defined by the bios software in the computer, if HP/Compaq tells you that 80Gb is the maximum capacity, then I think you should believe them, after all they should be the first one interested in selling more high price products, go for the 80Gb is .
May 03, 2008 | Computers & Internet
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
