Question about Onkyo TX-SR602 Receiver
Dvd player hookup
How do I assign vidio 2 input on the reciever to one of the digital ( orange) inputs
Push setup, go to menu where the digital inputs are selected and set coax to video 2. I think it's the initial setup menu but not sure.
Posted on Oct 31, 2008
Cannot get new DVD player to work on Denon AVR-2307CI Receiver
TRY TO FIND DVD PLAYER RESOLUTION SAME TO THE RECEIVER....MAY BE IT WORKING..
Dec 28, 2013 | Denon AVR-2307Ci Receiver
Digital Coaxial not working on DVD player
There might be several problems. As the projector has component only connections and the DVD player none, then if the Receiver has component out, you can hook it up to that. If the receiver has HDMI inputs then you can connect the DVD player via the HDMI socket to it. The Coax sockets on the DVD player will be for sound. Number one should be connected to Digital coax 1 and assigned for it.
It's possible that the sound on the DVD player is switched off on the coax or has the wrong format selected. You will need to see the player's menu for this, so if you can't see the screen using the projector, connect a TV instead.
However if the receiver has no component out and no HDMI sockets you will have real problems connecting the DVD and using the projector with it. Though you should be able to hear the sound via the Denon.
May 28, 2017 | Denon Audio Players & Recorders
Ok so the issue is that after i have ran a hdmi cable from reciever to monitor, and 2 hdmi inputs (dvd and video2) into the reciever where im running a ps3 into the video2 port and foxtel/satellite tuner...
Try this, although recivers have video pass through, it is not the best option for video to your monitor. Depending on what you have for input/output on your TV/monitor, and, if you can, you should run all your video components directly to TV via(best)HDMI(video and sound) or, component and digital optical(best) or RCA, Then run digital optical out from you TV out to receiver in. You can use your monitors menu to chosse what you view and only have the onr input to you reciever. ASll you have to do then is go through you recievers menu to get the audio. Less connections less hassle. In other words, you would run your sat tuner to tv inputsat or cable, then dvd to dvd, PS3 to video 1 etc., on TV/monitor, then the single audio output to reciever.
Dave
Jul 03, 2011 | Audio Players & Recorders
I cant get the surround sound to work after connecting the Samsung BluRay Player to my Onkyo reciever using a optical digital connection or directly with the HDMI cable ?
Hi
You will have to assign the optical input to the input you are using, so for instance if you have plugged the optical cable into opt 1 on the onkyo reciever and wish to use the DVD input on the onkyo reciever, you need to go into the set of the onkyo to digital assignments or in/out assignments, dependent on the model, and select OPT1 for the DVD input. You can find out how to exactly do this in the onkyo's manual under 'digital assignments' or 'input assignments'.
Regards
TechSupp12
Dec 12, 2010 | Samsung BDC6500 BluRay Player
I have a Denon AVR2307 to which is connected,via optical audio and component video a DVD player/recorder and this works well but in order to take some of the work off the player part I've bought another...
HDMI signal from DVD can not be down converted to analog component signal.
Connect your new DVD to a component input 1..4. Make sure that component input assigned to desired input (dvd/vcr/sat/) (setup - input setup - input - component assign - component x etc). Connect coax output of DVD to coax x input of the receiver and assign it (setup- input setup - "input" - digital assign ..). Probably you need to setup DVD output resolution to 720i or 720p in dvd setup menu.
Sep 09, 2010 | Denon AVR-2307 Receiver
Unable to assign optical and digital inputs to other inputs
It won't let you assign the same input twice. Check to see that DVD is not already assigned to any other In(x) function.
From the manual:
• You cannot select a specific item more than once.
• You cannot assign the same input source to both “IN (2)” and
“IN (3)”. For example, you assign “CD” to “IN (2)”, “–––”
appears in “IN (3)”.
Mar 16, 2010 | Yamaha RX-V363 Receiver
Onkyo HT-S6100 to OPPO Dv 980H to Sony Bravia KDL 40W4100
Make sure none of the Digital or Component Input Assignments are programmed, if you're not using them. Set them to "----". This may help. Some of the Component input assignments may over-ride your other input assignments (perhaps even the HDMI input assignments).
Jan 25, 2009 | Onkyo DV-S353 DVD Player
Assigning inputs or selecting the type of vidio stream i want to use for my dvd player.
Not sure if I understand completely, but if you want to watch a source on DVD then then it needs to have its a/v outputs connected to the DVD inputs on the rear of the receiver.
Aug 22, 2008 | Onkyo TX-SR602 Receiver
What settings
What ever you want. the onkyo reciever allow you to select what input the hdmi inputs are assigned to.
you can assign DVD to hdmi 1, or 2, what ever you want.
Check the manual how to assign inputs.
Nov 07, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR602 Receiver Logo
69 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
