Question about Whirlpool RBS275PD Electric Single Oven
Very Old Whirlpool "Wall of Fire" Gas OVen
The front door of my ancient Whirlpool "Wall of Fire" double gas oven has come unhinged and I cannot put it back together again. Can anyone help?
What you have to do is get a couple of nails pull the hinge on the door down far enough to insert the nails in the holes and let it rest against the door this will hold the door at the proper angle to engage the hooks inside the hinge slots on the body of the range grasp the door on each side and insert the hinges in each side to engage the hooks then open the door all the way and remove the nails
Posted on Sep 02, 2008
I have a whirlpool accubake wall unit oven Took out door to clean glass now I cannot put door back together
you have a couple of hinges you have to pull out at about 45 degrees then slide door down on them and shut door
May 05, 2016 | Whirlpool RBD245PRB 24-inch Double Wall...
I have unhinged the oven door. I cannot get it back on.
how did you unhinge it .usually they need to be semi open to put the door back on .
Jan 17, 2016 | De Dietrich Ovens
I purchase the Whirlpool electric double oven range GGE350 almost a year ago. The problem I have is with the oven door. There is evidently spillage or something between the glass pane. How is cleaning...
Hello, Thank You for using FixYa. I will be helping you today.I would recommend paying for a service call to have a tech take the door apart for you. There are four pieces of glass in the door and lots of screws. It really is a pain to take doors apart we as techs get this call all the time. Believe me you will thank me you paid someone to do it. If it were easy i would tell you. Most people take them apart then end up paying because they cant put it back together.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Whirlpool RBD305PD Electric Double Oven
How do I re-insert the Thermador oven door so it is properly in place and functional? Issue cropped up when someone cleaning it put too much force on the door and it became unhinged on one side. I was...
Sorry to read about your problem, I hope this helps you out.
this takes alot of practice, really hard to explain..i suggest you call a service company....
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Jenn-Air JJW8230D Electric Double Oven
I have a Whirlpool double oven GMC305PRS01 when you turn on the oven it appears to me making all the right move IE it goes into pre heat and starts counting down but the elements are not getting hot.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message
Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Nov 22, 2010 | Whirlpool GMC305PRS Stainless Steel...
We tried using the self clean on our Whirlpool Gold Accubake Duo system range. It locked the oven door and gave code e1 f5. We disconnected the power and turned back on to the same codes. HELP!!!!!!
take the trim peices off. take the screws that hold it to the wall out slidee unit out a little to remove the 2 screws from the consol lift the consol up and off. make sure that you have turned the power off inside the unit you will see a tech sheet that will tell you what that error code means. let me know how it goes the tech sheet is usually on the left side.
Jun 16, 2009 | Whirlpool GBD307PDS Electric Double Oven
Cant find serial number - model AOGD2750
open the doors it should be on one of the door frames on a metal tag
Mar 24, 2009 | Amana AOGD2750 Gas Double Oven
Dead Whirlpool Double Oven
This happened to us the first time we used the self-cleaning feature. The repairman said we had to replace the whole electronic panel -- but when he put in the new panel it didn't work either. It turned out he just needed to replace the oven shutdown thermal fuse I believe. We finally got up enough courage to try the self-cleaning again and the exact thing happened. The door is locked and the electronic panel is dead again. So when we get it fixed we will never use the self-clean again.
Nov 05, 2008 | Whirlpool RBD305PD Electric Double Oven
Element wires fell behind oven
I just had the same problem with our Electrolux wall oven. I don't expect you are still having problems 3 years later, but thought I would post for the benefit of anyone else with this issue.
Firstly, turn your power off. I then had to unscrew two screws on each side of the oven door which allowed the oven shell to come forward. You should then see the power cord which you can remove from the powerpoint. If your oven is hard-wired in, then I would definitely call an electrician.
Once I removed the oven, I placed it on the floor and unscrewed a few screws that held the top and back casing on. After removing the casing, you can see the wiring and you just need to push the fallen wire back through.
Before you put the casing back on, you could replace your element just in case the wire falls through again.
Sep 17, 2007 | Whirlpool Ovens
Whirlpool RBS275PD Electric Single Oven Logo
136 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
