Posted on Jun 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Epson wont recognize black refill cartridge. - Office Equipment & Supplies
Anonymous
Level 2:
Novelist:
  • Expert 72 Answers
  • Posted on Jun 26, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
72
Questions
0
Helped
41051
Points
245
I'm assuming that you are probably using Non-Epson Ink Cartridges, because those are what normally cause that problem, with a printer not recognizing an installed ink cartridge. Unfortunately, there is no way to make your Epson Printer use or accept that Non-Epson Ink Cartridge, if it cannot actually recognize it. Its even possible that some Generic or Third-Party brands, may not always be recognized by the newer models of Epson Printers, because of the inexpensive [cheap] and or incompatable Electrical Chips that are mounted on the actual ink cartridge. Sometimes you will even get Error Messages up on your Monitors screen, telling you that you are actually using a Non-Epson Ink Cartridge, or that your printer cannot recognize the cartridge that you installed. Sometimes the Ink Level Indicator, on your Status Monitor, will not show an actual ink level, but may indicate a cartridge error or problem instead. Not all Generic or Third-Party ink & ink cartridges are made the same and none of them actually contain the right formulation of ink, for the Epson Printers [formula is patented by Epson Company]. Some are probably close and seem to be better than others, but some simply can clog-up or even damage the Printhead Assemblies on Epson Printers, or simply won't be accepted at all. Epson Ink Jet Printers are one of the few printers on the market that seem to have so many problems with non-manufactors inks, especially the newer models made in the last couple of years. Its because the Epson Printers use a completely different printhead inking system than most other brands of printers. Most, if not all of the other manufactors, use thermal or bubble jetprint heads and because the other brands use a totally different system, they don't seem to have as many problems using refilled inks or non-manufactor's ink cartridges. Printer manufacters do not make available their ink formulation and in most cases, the formulation is patented. Any difference in the ink formulation can actually cause clogging in the small printhead nozzles or damage other critical components. One individual printhead nozzle is so tiny, that it will not accept a human hair, so you can see why they can get clogged so easily, or even why the nozzles can be so easily damaged...Even if you were actually using a New-Epson Ink Cartridge, its always possible that you got a bad cartridge. At this point, the only thing I can suggest is that you try a different New-Epson Ink Cartridge, or at the very least, a different brand of Non-Epson Ink Cartridges and see if that helps.
Why is my wf-4630 not recognizing initial cartridges?
if they are not epson original cartridges,they wont work,you cant refill or by refilled cartridges to use in this printer,if buying used cartridges,you have to be able to reset the printer,some cartridges reset the printer but most dont
HPoffice jet #J4580 printer wont recognize Costco refilled Cartridge
This model HP printer may only let you use genuine Canon/Epson printer cartridges. If you try to refill these ink cartridges it will not work because the HP cartridges have an embedded chip in the cartridge that detects the empty cartridge even though it has been refilled.
Epson cx7400 ink cartridge problem
Printer manufacturers do not want folks to use cartridges that have been refilled and they deliberately design their printers to not work with refills. If you get a generic refill you have to make sure that they have taken measures to counteract what Epson has programmed into their printers.
Chalk up the experience to GREED - they want you to use their grossly over priced inks - that is where they make their money! Check in Google for work a rounds this nonsense.
21helpful
5answers
My Epson NX415 does not recognize refilled and reset cartridges. What can I do about it?
Don't let your ink levels drop below 25% before refilling and resetting your cartridges. There is an inner and an outer chip on these cartridges. The inner chip disables the outer chip when it's contacts are no longer bathed in ink. So, it doesn't matter if you "reset" the outer chip after refilling your empty cartridge because the chip was disabled. I'm really curious how you refilled these cartridges yourself without souring yourself on refilling from the experience. I own a Cartridge World ink refilling store and I refilled a set of these cartridges when we had replacement chips available (we don't now because our chip distributor was violating Epson patents) and it was an absolute mess, took forever, and the cartridges still didn't work in our test printer.
5helpful
3answers
How to refill an Epson printer Cartridge T0881 Black ink, have the set although instruction do not include this model.
To refill epson cartridges, you will need a resetter of the cartridge to restore the ink level back to full content.
You can buy a spongeless cartridges with an autoreset chips for your printer so that you will not need the ink cartridge resetter anymore since it will auto reset. This is my suggestion since spongeless cartridges are easy to refill than the genuine cartridges. Hope you can find in your area. If not, you can go to the nearest ink refilling center in your area and you can let them teach you if they will. Hope it would help.
6helpful
2answers
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
I refilled a black Epson C60 ink cartridge but the printer won't recognize it. I keep getting the message that there is no ink in the cartridge when, of course, there is. How do I get the bloody printer to...
Epson ink cartridges have to be reset after they are refilled with little device called a "resetter". You can purchase one for about $25 on the internet. You reset the cartridge by touching the resetter to the contacts on it. The cartridge is then considered full again. I have one of these somewhere in my office.
1helpful
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
2answers
Epson c62 color ink cartridge says it is empty when i just refill
I use cheap replacement cartridges about 20$ for 3 color/5 black....the printer usually doesnt recognize the cartridges ink level but it still prints......do you use actual epson replacements? If you use cheaper replacements you might have gotten some with dud chips...prob the cartridges fault, not your printer
Epson stylus dx 7450 printer
You have a wide format printer but it has the same basic principle as the desktops. You can buy remanufactured cartridges which were reset for you. Or you can refill them. If you refill them, you need a resetter because Epson cartridges have a chip on them which needs to be reset. Because when they are empty, the printer will recognize it as empty and will not function till you put in a new cartridge. If you bought a remanufactured cartridge, and your printer won't recognize it, you need to go back to who sold you the cartridge and either have them reset it or give you a replacement.
k24674
ADMIN Andrew
ADMIN Andrew
