FixYa.com
Tags:
Fuji FinePix 2600 Zoom Digital Camera
How do I make an image file smaller so I can send...
posted by Guest on Aug 30, 2005
How do I make an image file smaller so I can send it by e-mail?
Best Solution
posted on May 25, 2008
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
want to know the easiest way?
just open up Microsoft pulisher and copy and paste the picture into there,then click right, Save as picture.
wish it work for you.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 30, 2005
Helpful (85)
toto
toto - usenet poster
Rank:Wiz Wiz
Rating: 80%, 63 votes
To make an image file smaller for e-mail transmission, change the image file size in "Exif Viewer" or "FinePixViewer".
Changing the size of an image file
1. Start up the Viewer and select the folder containing the image you wish to send.
2. Double-click the thumbnail for the image file you want to resize to open the image in its own full-size window.
3. Select "Image size" in the "Image" menu.
4. Set "%" as the "Unit" used for file size display. Then enter a value lower than 100 as the "Width" or "Height" and click the [OK] button.
5. Select "Save as" in the "File" menu to save the image. (You can also reduce the image file size by lowering the quality in "Save as type".)
Solution #3
posted on Nov 16, 2007
Not Rated (0)
t00nz
Rank:Guru Guru
Rating: 90%, 893 votes
And very good free software that does a good job of this is available at:
http://www.irfanview.com
Solution #4
posted on Nov 08, 2007
Not Rated (0)
scottyja
Rating: 0%, 0 votes
I'd suggest using the Image Resizer Powertoy for Windows (if you're using Windows). I use it all the time:
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
You can just right-click on a file and opt to resize it. You can change the original or make a copy when resizing. It's perfect for posting on blogs or sending as email attachments.
Solution #5
posted on May 16, 2006
Not Rated (0)
carlos-aec
Rank:Master Master
Rating: 83%, 120 votes
carlo... indicated that his solution for
FinePix S5500... Problem
is valid for all Digital Cameras
Hi:
You can change the resolution of the picture you want using software. That way you still have the one with higher resolution and another to send.
My advice is using the resolution 800 x 600. It's the size of a 15'' monitor (normally).
Regards
This Problem Also Relates To: HP Photosmart 945 Digital Camera HP Photosmart 720 Digital Camera Panasonic Lumix DMC-FZ30 Digital Camera Panasonic Lumix DMC-FZ20 Digital Camera Panasonic Lumix DMC-TZ3 Digital Camera Sony Cyber-Shot DSC-S40 Digital Camera Sony Cybershot DSC-T200 Digital Camera
Can you Help with these Digital Cameras problems?
Digital Cameras
can't upload videos into...
can't upload videos into... Answer This...
Digital Cameras
MY CAMERA SHOWS ERROR
my camera shows error ... Answer This...
Digital Cameras
i dropped my i830 polaroid
i dropped my i830 polaroid... Answer This...
2600 says batteries are dead...
Even with fully charged brand... Answer This...
Download problem
When I plug the camera into the... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
