Question about D-Link AirPlus DI-524 Wireless Router
D-link DI-524 firmware problem
Hi I have the same problem. I recently installed firmware 1.23 for my revision A3 D-Link DI-524 and it no longer broadcasts any wireless signals. Before the firmware update it worked perfectly, now it will only let the directly connected computer work and it won't let me access the setting using 192.168.0.1. I don't quite understand the solutions given here if someone could please help me by clarifying or giving me another answer that would be great thanks.
  • 667 Answers
Sorry - I've been out of town. A few things. Just in case you upgraded the firmware through a wireless connection you should never do this. Let me know what operating system you're using just so I know. Before you actually reset the router to factory defaults, if you haven't done it already, I want you to go to a command prompt. In XP start>run>type "cmd" without the quotes and then click on ok. In Vista click on start to open your search box and type "cmd" When you click ok it may ask for your permission so just tell it to go ahead. At the prompt type ipconfig and let me know the sets of numbers that come up. Read through this and please answer all the questions when replying. Thanks.
Jeff
P.S. - Also if you want, if you don't have it fixed yet, send me a email at oldnovii@aol.com I might have a quicker way to fix this than sending comments back and forth all day and night.
Posted on Aug 31, 2008
  • 35 Answers
Well if you upgraded the firmware it should have solve any issue. Now do you have a different wireless computer.If you do check to see if that one is detecting wireless signal.Also if you havent created a network name when you upgrade firmware router goes back to factory default settings check to see if it is (laptop)detecting default.Make sure wireless capability is on.On computer.Also check to see if wireless light on router is on.IF light is not on then there is a problem with router.Try downgrading firmware to original firmware.
Posted on Aug 27, 2008
D Link 524 password
If you're looking for the default username and password information for your D-Link DI-524, or perhaps how to reset it incase you've forgotten it, this website below outlines the lot of it.
Keep in mind, D-Link made a lot of revisions of this router, and one set of steps might work for one revision, and not on the other. Pay close attention to your revision. The article attached will outline where to find it (it's usually on a barcoded sticker on the underbelly of the unit).
http://pcsupport.about.com/od/d-link-default-passwords/a/di-524-default-password.htm
Hope this helps!
Aug 25, 2014 | D-Link Computers & Internet
How do I set security on my DWL-952
There are 2 possible areas raised by this question. The first is a security patch needed to fix the firmware of your router, which by the way is not dwl-952. Your router is a di 954. Dwl 952 is a bundled router and network interface. The details of the firmware update are below.
Security patch for your D-Link router
These firmware updates address the security vulnerabilities in affected D-Link routers. D-Link will update this continually and we strongly recommend all users to install the relevant updates.
As there are different hardware revisions on our products, please check this on your device before downloading the correct corresponding firmware update. The hardware revision information can usually be found on the product label on the underside of the product next to the serial number. Alternatively, they can also be found on the device web configuration.
Please make sure you follow the firmware install guide provided within the ZIP firmware package.
DI-524 Revision E1/E3Thu, 28/11/13
The new firmware 5.13b01 that fixes the security vulnerabilities
DI-524 Revision Ex 5.13b01
Please note: please unzip the file and use the file DI524Ex_FW513B01.bin to update firmware.
DI-524UP Revision A1/A2Thu, 28/11/13
The new firmware 1.08b02 that fixes the security vulnerabilities
DI-524UP Revision Ax 1.08b02
Please note: please unzip the file and use the file DI524UPAx_FW108B02.bix to update firmware.
The second possibility is to set the local security on your network.
From the wikipedia page:
Wireless security is the prevention of unauthorized access or damage to computers using wireless networks. The most common types of wireless security are Wired Equivalent Privacy (WEP) and Wi-Fi Protected Access (WPA). WEP is a notoriously weak security standard. The password it uses can often be cracked in a few minutes with a basic laptop computer and widely available software tools. WEP is an old IEEE 802.11 standard from 1999 which was outdated in 2003 by WPA or Wi-Fi Protected Access. WPA was a quick alternative to improve security over WEP. The current standard is WPA2; some hardware cannot support WPA2 without firmware upgrade or replacement. WPA2 uses an encryption device which encrypts the network with a 256 bit key; the longer key length improves security over WEP.
The complete article is here
Wireless security
Log in to your router and find the wireless security section. Set up the security model that best suits your needs and then set up your wireless network card with the same information.
Mar 11, 2014 | Computers & Internet
How to i setup this router "D-link DI-524
Link to router information, you need to select your model revision, then you will be able to download your installation guide, firmware updates, etc
ttp://www.dlink.com/products/default.aspx?pid=DI-524&tab=3
Mar 04, 2011 | D-Link AirPlus DI-524 Wireless Router
My dlink router it worked..but the signal is off and on and off again what di i do
First thing I would do if you haven't already is update to the latest firmware. follow the link below and choose the correct model/revision of the model you own from there you can download the latest firmware as well as the manual if you need it to view how to update the firmware. It is quite easy in the interface when logging into the router. If you need further assistance please let me know. Also please take the time to accept/rate my solution when you find my assistance helpful.
Thank you,
Lee
Dec 03, 2010 | D-Link AirPlus DI-524 Wireless Router
Lost disc for my fouter can I download something
This model's characteristics are "Install the D-Link DFE-530TX+ adapter into a desktop computer. The four Ethernet LAN ports of the DI-524 are Auto MDI/MDIX and will work with both straight-Through and Cross-Over cable." The rest u can visit this link and satisfy yourself. NOTE: VISTA might not support this router since its been discontinued manufacture of this device quite some time back. The link is : http://www.dlink.com.au/tech/Download/download.aspx?product=DI-524&revision=REV_B&filetype=Firmware..................sodeep
Jun 05, 2009 | D-Link AirPlus DI-524 Wireless Router
DI-524 status problem
Did this happen after a firmware upgrade? If so, this link may help:
http://borgetech.blogspot.com/2007/09/d-link-di-524-revision-b4-status-light.html
Apparently there's a utility which will force firmware to load on the router. The steps are a bit technical, though.
If that doesn't work, the router is probably toast. Time for a new one.
Feb 08, 2009 | D-Link AirPlus DI-524 Wireless Router
Change from 'unsecure' to 'secure' router
You don't need to install anything extra to secure the network. It's a matter of changing router settings. You set up the router through your web browser by going to "http://192.168.0.1" which accesses the device's setup screens.
There are several revisions of this product. Here is the URL for D-Link's selection page for the router:
http://support.dlink.com/products/revision.asp?productid=di-524
Click on the picture that shows the version you have, and then you'll be taken to the page for that version. You can download a manual or look through the FAQ's which will guide you through the process of setting up the security.
Jan 01, 2009 | D-Link AirPlus DI-524 Wireless Router
Where can I get a free d-link DI-624 installer online?
There are multiple revisions of the DI-624, each with version specific drivers, firmware, installation guides, and other resources. Please use the descriptions below to identify your revision.
The links will take you to the drivers and install guides.
Note: The revision is located on the label on the bottom of the device next to H/W
The DI-624 Rev. A has 2 antennas.
<img src=http://support.dlink.com/prod_img/revisions/DI-624v.jpg>
Driver here: http://support.dlink.com/products/view.asp?productid=DI-624
The DI-624 Rev. B has 2 antennas.
<img src=http://support.dlink.com/prod_img/revisions/DI-624_revBv.jpg>
Driver here: http://support.dlink.com/products/view.asp?productid=DI%2D624%5FrevB
The DI-624 Rev. C has only 1 antenna.
<img src=http://support.dlink.com/prod_img/revisions/DI-624_revCv.jpg>
Driver here: http://support.dlink.com/products/view.asp?productid=DI-624_revC
Dec 25, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Drivers for DI-524 Wireless Rourter D-Link
You can find donwload here:
follow the instruction.
me this help,
melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
May 21, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
1,245 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
