Question about Plantronics Explorer 340 Wireless Headset
Pairing my bluetoth to my blackberry curve phone
I have a plantronics 340 bluetooth. what button or buttons do i press to place my bluetooth in pairing mode?
  • manyak188 Aug 26, 2008
    how do you use it for a sony ericsson k550i
  • Anonymous Sep 17, 2008
    Blackberry Curve is asking for "Enter numeric passkey for 3xxPlantronics
    What is the passkey?
  • 3 Answers
When it is turned off, hold the main button in for 4 seconds until the light flashes red, the release. It should flash red and blue. This means it is in pairing mode.
Posted on Aug 28, 2008
How can I make working plantronics 232 with my verizon blackberry 9650
The headset must be put into pairing mode. Once you make your Blackberry phone discoverable, then put the Plantronics 232 headset into pairing mode by pressing the call control button until it flashes red and blue. If it's not flashing red and blue, then it is not in pairing mode. Here is a link for the pairing instructions for the 230 headset (which is the same for the 232):
Plantronics Explorer 232 User's Guide
Good luck from Headsets Direct!
Dec 04, 2011 | Plantronics Explorer 232 Bluetooth Headset
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
CAN'T GET MY BLACKBERRY 8330 TO PAIR WITH MY
Did you do the steps listed here?
This is the Plantronics information.
Your new headset includes Plantronics QuickPair technology to simplify
the Bluetooth setup process. The rst time you turn your headset on, your
headset automatically enters pairing mode for 10 minutes. Once paired
successfully, your headset stays on for instant use.
If not sucessfully paired after 10 minutes, your headset automatically
powers o. When you turn the headset on again, it automatically goes
into pairing mode until successfully paired with a Bluetooth phone.
To pair your headset for the rst time:
Turn ON the Bluetooth feature on your phone.
TIP: For most phones, select Settings/Tools > Connections > Bluetooth > On.
See your phone’s user guide for more information.
Press and hold the call control button to turn on your headset. (The indicator
ashes red/blue to show that the headset is on and in pairing mode.)
TIP: If you don’t see the red/blue ash, press and hold the call control button to
turn your headset o, and then press and hold the call control button again until
you see the red/blue ash.
Use the commands on your phone to locate your headset.
Search > 520Plantronics. See your phone’s user guide for more information.
When prompted for the passkey, enter 0000.
When pairing is successful, the indicator on your headset ashes blue. Your
headset is now connected and ready to use.
Apr 15, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Need numeric code to pair with blackberry pearl 8100
when pressing the call button to turn on hold it a little longer then usual after the headset has turn on, it will flah red and blue, then simply do a bluetooth scan with your phone, it will detect the headset.
May 30, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Won't pair with Motorola HS850 headset
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Plantronics Explorer 220 no longer connects to Blackberry Curve
You can have the two devices connected, but still get your sound through the phone. During a call (maybe call your voicemail or an automated number, just to make a call) try holding down the answer/end button on the earpiece until it beeps, and see if the sound switches from the phone to the earpiece. You can also try pressing the speakerphone button on your phone during a call to switch the call to the earpiece.
Did either of those ideas work?
Jan 26, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics 330 no longer pairs with Blackberry 8310.
I believe that the bluetooth symbol that you see indicates that bluetooth is enabled on your Blackberry, not that you are connected to a device (at least that's how mine works).
Here are some suggestions:
First, if you are on BES, check with IT to make sure no changes were made (they can block bluetooth).
Next, make sure you are using the most current software. It should be: v4.5.0.108. If you are using an older version, definitely update your software because the 8310 is known to have bluetooth issues.
Do you see your headset listed on "paired devices"? If so, I suggest that you delete it before upgrading the software.
Once your headset is no longer listed (or if it wasn't in the first place), re-connect it to your Blackberry as follows (apologies if you already know this part):
1. Re-set your headset:
Turn the headset off.
Press and hold down the control button.
After 6-10 seconds, the light will flash blue, then it will flash red, then blue.
Release the button when you see the red/blue.
2. On your Blackberry:
Open "Options"
Open "Bluetooth"
Open menu within Bluetooth
If not already on, click "Enable Bluetooth"
Open Bluetooth menu again.
Open "Options".
Turn "Discoverable" to "Yes"
Open the Bluetooth menu a 3rd time.
Click on "Add Device".
Your Blackberry will search for your headset.
If you are prompted for a Passkey, use 0000 (that's 4 zeros).
After a short time, your headset will appear on your Blackberry.
It should appear as Plantronics 3xxx.
Make sure you go back into Bluetooth Options and change "Discoverable" back to "No".
Once you have established a new connection with upgraded software, you should have no trouble with "Transfer Address Book".
Hope this solves your problem.
Dec 28, 2008 | Plantronics Explorer 340 Wireless Headset
Plantronics 520 will not pair
"Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue."
Dec 04, 2008 | Plantronics - Bluetooth Headset Plus Base...
I have a blackberry curve and am wanting to pair my bluetooth HS850 to it. Please help!
There actually is a trick to the HS850 - flip the boom closed, then hold down the button just until the light holds solid - IMMEDIATELY after it does flip the boom open and this should keep the light solid. Then on your cell/device search for bluetooth devices - you should be able to find it now. Passkey for most devices is 0000.
Jun 30, 2008 | AT&T Blackberry Curve 8300 Smartphone
Plantronics Voyager 510 & Blackberry Curve
 Plantronics Support Phone Number: 1-800-544-4660
Do not use the power button to sync.
To sync device, Press + button (volume) and Silver button (on boom) at simultaneously. LED Light will blink RED & BLUE.  Device ID should appear on your screen.
Jan 14, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics Explorer 340 Wireless Headset Logo
422 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
