Question about Dell Inspiron 2200 Notebook
How to charge up my new battery
I just bought a brand new battery for my 2200 inspiron as I previously had to use the ac adapter permanently for it to run.
Can you let me know the optimum way of charging the new one up as it came with no instructions
Thanks
Simon
    Genius:
  • 2,028 Answers
Let it charge for a good 12 hours before running the machine, basically overnight. The power management system will recognize that this is a new battery, and is programed to start the initial charge sequence for a new battery. It is supposed to do this whether the machine is in use or not, but I recommend 12 hours just to be on the safe side.
Posted on Aug 22, 2008
SOURCE:
Hi i need help plz, i've my laptop do not power when i plug the ac adapter ther' is no ligth
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 23, 2011 | Dell Inspiron 2200 Notebook
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
New power adapter and new battery, wont charge through power chord, dell inspiron 1150
If ac adapter and battery have been replaced (Dell Branded AC adapter is required) then the only thing left is motherboard.
Oct 28, 2009 | Dell Inspiron 1150 Notebook
Dell inspiron 8100 no ac power-power only with battery
You may have to run the battery/charger utility test.Look under control panel classic view.
Jul 14, 2009 | Computers & Internet
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Inspiron laptop Battery won't charge
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Apr 06, 2009 | Dell Inspiron 9400 Notebook
AC adapter for dell laptop inspiron 2200
You can order the part from this link
Dell_PARTS_ADAPTER
Once you open the link scroll down and select the second adaper in the list
60 Watt 3 Prong AC Adapter with 3-ft Power Cord for Dell Inspiron 2200 / Latitude 110L Laptops
May 20, 2008 | Computers & Internet
AC Adapter
Hey thats one of two things your (internal charging unit) if so your SCREWED if not its the sowtware issue witch means you gotta tweak the settings especially if you just upgraded your OS if tweaking doesnt work then re-install your OS then set your OS setting Correctly to the best of your knowledge have fun...it take a bit of patience and a couple hours i had the same prob.....seeya
Oct 28, 2007 | Dell Inspiron 2200 Notebook
My laptop battery won't charge
possible when the old AC adapter blew it took part of the power management circuit with it, This is the circuit that detects and charges the battery, I'm not sure whether this a seperate replaceable daughter card or whether it is part of the main motherboard. you will need to investigate this (or send it for a service)
Oct 09, 2007 | Dell Inspiron B130 Notebook
Dell Inspiron 2200 Notebook Logo
91 people viewed this question
Ekse
Clive
Clive
