Question about Dishwashers
WATER WILL NOT DRAIN. HOW DO YOU GET THE ARM OFF?
  • 706 Answers
The arm has nothing to do with the drain system.. Chances are your drain filter is clogged and limiting drain water to the pump.. Check near the base of the dishwasher for the drain outlet and see if there is a screen filter of some sort that needs to be cleaned.. Without a brand name and model nuber provided in your question, the only solution I can provide is generic.. Hope that helps ..
Posted on Aug 23, 2008
Slow or no drain of water. cleaned out sump covers and ran drain cleaner thru cycle. looking for possible secondary filter.
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Hope it helps...
Jun 27, 2011 | Hotpoint Dishwashers
Hi, We have Tecnik Dishwasher TKD 795/3 it wont seem to drain the water, we have tried to clear the pipes but they seem to be clear, Can you give us any tips on how to sort this problem out? Thank you
Jun 25, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Wtaer will not drain. what are things to check.
Hope it helps...
Jun 24, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
Kenmore dishwasher won't drain. Can hear motor trying to cycle but it sounds like it's locked.
Hope it helps...
Jun 23, 2011 | Dishwashers
Will not drain
Jun 23, 2011 | Thermador DW44Z Built-in Dishwasher
My kitchenaid kudv24 will not drain water out
Jun 21, 2011 | KitchenAid 24 in. KUDS25SH Built-in...
Dishwasher is not draining
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Thank you !!
Jun 04, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
WATER DOES NOT DRAIN COMPLETELY
Your dishwasher's drain pump is not designed to work until the water is completely drained but rather in sync with the timer. The motor will stop when the timer stops no matter how much water is left inside the machine.
In your case, either of the following is causing the trouble:
  1. There's a part clogging in the drain line.
  2. A debris is caught in the drain pump impeller.
  3. Drain valve is not opening completely.
  4. Worn belt if your washer uses a belt to drive the pump.
Here's the remedy to each of them:
  1. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. The drain pump is usually mounted directly to the motor and attached to the bottom of the dishwasher. Remove the lower rack, the spray arm, and the spray arm support to reach the pump from inside the dishwasher. Look for the wash impeller, which forces the water through the spray arm. Beneath it is the drain impeller, which is similar in size and shape to the wash impeller. Clear the drain impeller from any debris that prevent it from pumping out water properly.
  3. Sometimes the drain valve solenoid or the diverting lever sticks and prevents the dishwasher from draining properly. Lubricate the lever to free it up. Replace it otherwise.
  4. If your machine uses a belt to drive the pump, the belt may have been worn and cannot drive the pump properly. Replace the belt if that is the case.
Feel free to give updates.
Dec 01, 2009 | Maytag Dishwashers
MY DISHWASHER WON'T DRAIN ALL THE WAY WATER STAYS IN THE BOTTOM
Hi
If the water doesn't drain from your dishwasher, check these---
Drain line/air gap -- Clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump-- Dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--It is a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid--Dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly.
Please do rate this solution as FixYa if found helpful and revert for further assistance.
Thanks
Rylee
Apr 29, 2009 | Dishwashers
Maytag JetII dishwasher
try removing the wash arms( should be a center mounter ***** that releases the wash arm. possible that hte holes in arm have become clogged w/debris. although oyu cant seperate the arm try getting the debris out from the large center hole.
Mar 11, 2008 | Maytag 24 in. MDB8750A Jetclean II...
Dishwashers Logo
62 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
