Question about Maxtor Hard Drive
Jumper Settings Will this HD run on cable secect? and which jumpers to use? charlie
    Problem Solver:
  • 17 Answers
If you leave it at cable select the cable will set the drive to either master or slave depending on where it is on the cable, the first or second connector. Just make sure any other drive hooked up is set to cable select.
Your best option is to actually set each drive to master and slave. Each drive should show you where to put the jumper. Make sure you only have one master and slave though.
Which jumper to use? The one thats already on the HD...?
:D
Check out this page for more information on Cable Select:
http://www.pcguide.com/ref/hdd/if/ide/confCS-c.html
Posted on Aug 23, 2008
SOURCE:
Jumpers Serttings on Quantum HD
CS = Cable Select
DS = Master
SP = Spare (Slave)
Nov 10, 2013 | Maxtor Computers & Internet
Jumper settings to connect to mac
If the hdd is a 3 1/2" version you need a power supply to run it. The usb will only power a mini SATA 2 1/2 or smaller as the 3 1/2 needs 12volt supply as well.
Jul 02, 2017 | Western Digital Caviar WD1600BB 160 GB...
I have a newly installed ide to sata converter with a 160G HD but was not recognized in the bios or HD not present
set the the hard drive jumper to Master,, if that dont work try Cable select and lastly slave, Some converters require specific jumper settings.
Mar 31, 2011 | AOpen Computers & Internet
Maxtor hd jumper settings n256 91366u4 primary
MAXTOR: no jumpers --> Master
one jumper --> Slave
two jumpers --> Cable Select
Dec 20, 2010 | Maxtor Hard Drive
How to conect SATA and IDE HD drives
Use the jumper settings and use the sata for Primary master and IDE with cable select or slave jumper settings. Both will work properly.
Good Luck
Dec 15, 2009 | MSI K7N2 Delta2 400FB nForce2 Ultra...
How to set jumpers in an old quantum fireball Lct20 HD. The master mode needs to be "jumpered"
Please look on top of your HD and u will see a table that show u the HD jumper setting (Master, Slave or Cable Select).
Then look again the rear side of the HD and u will see some pin that locate beside the power input of the HD, that is the jumper pin.
Now set the jumper according to your requirement refer to the jumper setting table just now. To set it just unplug the jumper (look like a U shape contactor covered with plastic) and plug it back according to the requirement. Sometime u may lost the jumper contactor, nevermind just use what ever conductor cable to roll between the two pin and make sure the pin is connected that all.
YBC (/\)
Oct 06, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Swap two hard drives
Indeed you can. Make sure the jumper settings are identical for the swap, and as long as the replacement one has windows xp running on it you should be fine.
Mar 04, 2009 | IBM ThinkPad T22 2647 Notebook
I have a HP a6013w, I have 2 spare IDE Hard drive I am trying to install one with a IDE to SATA adapter. I have all devices hooked up and the light on the adapter is on and the extra HD is running. So I go...
check the jumper settings on the hd one has to be a master for operating system and the rest has to be the slave drives .... sometime certain hd's may work under cable select and make sure cables are seated correctly and no bent pins jumper needs to have a snug fit use a toothpick to remove or bend pins straight..
Nov 11, 2008 | Computers & Internet
Maxtor 31536H2 Jumper Settings
Here is a picture of the jumper settings for most Maxtor hard drives:
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
May 15, 2008 | Maxtor Hard Drive
Maxtor 40gb hard drive as master
Hi, Below is an image of a Maxtor 3.5 HD settings as shown on the actual HD. If you are connecting 2 of them in a single IDE flat cable/strip, one must be master and the other must be slave. Jumper settings on the left is for master, the second is for slave. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 15, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Maxtor Hard Drive Logo
94 people viewed this question
Top Maxtor Computers & Internet Experts
Ekse
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
