Question about Hitachi CP-X260 LCD Projector
No power to projector
My Hitachi x260 will not turn on at all. It was working fine, but no power seems to be getting to the unit.
If you left your unit on it may have received a power surge that cooked the card like mine did
Posted on Jun 19, 2009
Adquiri o projector e não recebi o manual. Estou necessitando de saber o que devo fazer quando a luz fica vermelha na lâmpada e temperatura.
preciso de levar o equipamento a uma autorizada? Onde ?
Moro em Belo Horizonte- MG - Brasil.
Agradecida Ana Lúcia Melo
ana@famaeduc.com.br
fama_ana2008@hotmail.com.br
Posted on Dec 18, 2008
No power
Could be both ,there is 1 1.4 amp fuse for 220v or 3.3 amp fuse for 110 volt model.Fuse should be visible,some came with what looks like a black pin and some look like a ceramic fuse.You may also have one that is soldered in .
Apr 19, 2014 | Hitachi CP-X260 LCD Projector
I cannot adjust the focus ,zoom ,or tilt on my Hitachi CP-X1250 projector
try adjusting it from the remote and from the buttons on top. if neither work there is a connector from the main board to the lens contacts you might be able to see it and adjust it having taken out the lens (bayonet with lock button. if all still fails I have a few spare main boards from lcd dead projectors, reasonable to replace. email me maybury@mac.com
Dec 22, 2012 | Hitachi CP-X260 LCD Projector
Where can I download a driver for HITACHI CP X 260 for mac?
i didn't know mac needed drivers for projectors.... windows just connects right away
I thought mac did the same thing
I didn't find drivers for any Hitachi projectors
you might wanna get the conversion thingy for the mac input tho, if you don't already have it
and if you do you might wanna get another one, cuz some don't work correctly which might be the case
Aug 08, 2011 | Hitachi CP-X260 LCD Projector
Where to buy hitachi cpx260 filter spare parts
I presume you mean the polarizers/filters etc. not the air dust filter
Feb 24, 2011 | Hitachi CP-X260 LCD Projector
I am not getting any signal between my laptop and my projector. it is connected with a vga cable
You may need to turn on your laptops external VGA output. The easiest way is to reboot the laptop whilst connected to the projector whioch shoud be powered up.
If that doesn't work then look for the "Fn" key, usually blue or green on the botton left of the keyboard and hold it down whilst you press the "F" key (ie on the function row) which has a monitor icon in a matching colour. It may also say LCD, or CRT. This should cycle through available monitor output options, it will take a few seconds to complete the setup after each press.
Feb 16, 2011 | Hitachi CP-X260 LCD Projector
CP-X260 PROJECTOR SHOWN A MASSAGE "CHECK AIR FLOW
If you have the user manual,read it first.It will show the reasons why those messages are poping up.Temperature sensors are located on the vents which gives you the problem messages. Usual problem is that the vents cooling your system is blocked preventing the air to cool your heating lamp.If you want to do service on your own(try your warranty first,opening the unit voids the warranty) you can unscrew the covers yourself.Unplug the unit first.Get a clear tape and as you remove the screws,tape the screws near the holes you got them from to prevent confusion upon rescrewing the covers back.Locate the vents filters,usually found on near exhaust fans and locate another one with a foam and screen near a smaller fan.Blow or get a smaller powered vacuum to **** dirts out.Re-install the foam and screen filter the way you removed it,be sure to observe the connector for the fans.
Nov 25, 2010 | Hitachi CP-X260 LCD Projector
We have a hitachi cpx260 projector. both the power light and the lamp light is red.
This usually means you need to replace the lamp.
1) To do this, power off the machine and disconnect the power cable.
2) Open the lamp compartment, and remove the lamp. You'll need a screwdriver for this. I recommend having both a flat-head and phillips-head as the screw on the compartment door and the screw holding the lamp in are not always the same type.
3) Replace with new lamp and fasten with screw.
4) Reattach lamp compartment door and fasten with screw.
5) Power on your projector and go into your menu.
6) Find the lamp timer setting and reset the timer to zero.
Oct 18, 2010 | Hitachi CP-X260 LCD Projector
CP-X260 LCD Projector: when i connected to my laptop the projector does n...
By nothing do you mean it does not power on? Is your laptop on? Does it have an image on the screen?
Most of the time, this is easily fixed by holding down your function key and pressing one of the F keys. Different laptops use a different key, but you are looking for the CRT/LCD key.
So, press and hold function + CRT/LCD and you should notice a change. Be patient as it sometimes takes a moment. There are 3 settings here. One will give you a display on your laptop but not the projector. One will give you a display on the projector but not the laptop, and one will give you a display on both. So if the first time you press function + CRT/LCD you get a change but it's not what you need, try it again and cycle through until you find what you want.
May 16, 2010 | Hitachi CP-X260 LCD Projector
Hitachi CP-X260 LCD Projector Logo
237 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
