Question about Timex T303T Clock Radio
Unable to set time zone on my Timex T303T - Timex T303T Clock Radio
    New Friend:
Try this website for the manual
http://www.timexaudio.com/pdf/T303IB57271_12.PDF
Posted on Dec 08, 2010
SOURCE:
How do I change the time zone on my Timex atomic T303T clock?
http://www.acurite.com/media/manuals/75324T-instructions.pdf
Mar 09, 2015 | Timex Audio Players & Recorders
How do you set the time zone on a Timex T065s alarm clock?
Press and hold the "UP" button for three seconds. Repeat until you hit your zone.
Feb 24, 2013 | Timex T065s Solar Powered- Radio...
How do I change the time on my TIMEX T307S clock?
Hello
To adjust time follow this.
Auto-Set Time and Date Settings
This model is equipped with the Auto-Set feature, meaning that the time and date have been programmed at the factory
and will already be set when you first plug the model in. Auto-Set will automatically adjust the time and date settings for
daylight-saving time and leap years. Auto-Set is programmed for Eastern Standard Time; if you do not live in this time zone,
you can easily switch the setting to one of six other time zones.
1. To change your time zone setting, press and hold the 8 Time Zone Button. The current Auto-Set Time Zone in the
lower-right-hand corner of the display will flash for approximately ten seconds, after which the display will revert to the
standard clock display.
2. While the Auto-Set Time Zone is flashing, press the 1 Reverse and 6 Forward Buttons to select your time zone.
The display will show each zone's current time setting. There are seven zones to choose from:
Auto-Set Time Zones
Z-01 Atlantic Standard Time
Z-02 Eastern Standard Time
Z-03 Central Standard Time
Z-04 Mountain Standard Time
Z-05 Pacific Standard Time
Z-06 Alaskan Standard Time
Z-07 Hawaiian Standard Time
3. Find your time zone, then press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the
setting to lock into place.
Manual Time and Date Settings
1. To change your time setting, press and hold the J Time Set Button so that the clock display begins flashing.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, shown by the PM Indicator.
3. After setting the time, press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the setting
to lock into place.
4. To change the calendar, press and hold the 9 Date/7-5-2 Button until the display shows the flashing year.
5. Press the 1 Reverse and 6 Forward Buttons to set the current year. When you have selected the year, press the
4 Enter Button, then use the 1 Reverse and 6 Forward Buttons to set the month/day.
6. After you have set the date, press the 4 Enter Button or wait for the display to beep twice and lock into place.
Mar 15, 2011 | Timex (T307S) Clock Radio
I have set the 2nd time zone, but I can't set the watch to display the 2nd time zone.
Had the same problem when my niece was playing with my watch and switched time zones and I couldn't find the paperwork to switch it back. After not finding the solution online I played around with the watch and figured it out. Just hold down the start split button till it switch zones. It will beep when the switch completes.
Feb 24, 2011 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
How do i reset the Timex Zone Trainer Digital Heart Rate Monitor Watch T5J983 for each workout?
There are two ways to find the user manual for your Timex watch.
  1. Find your watch on the list below and click on the language link for your manual.
  2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table.
If you are still unable to locate your user manual, you may emailTimex Customer Service or call us toll-free at 1-800-448-4639.
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Nov 18, 2010 | Timex T5J983 Zone Trainer Digital Heart...
How do u get hourly beep to turn off on digital watch
To set time, date, and options:
1) With time and date showing, press and hold SET.
2) Current time zone (1, 2, or 3) flashes. Press + or to select time zone to set, if desired.
3) Press NEXT. Hour flashes. Press + or to change hour (including AM/PM); hold button to scan values
4) Press NEXT. Minutes flash. Press + or to change minutes
5) Press NEXT. Seconds flash. Press + or to set seconds to zero.
6) Press NEXT. Month flashes. Press + or to change month.
7) Press NEXT. Day flashes. Press + or to change day.
8) Press NEXT. Year flashes. Press + or to change year.
9) Press NEXT to set options. Press + or to change value and then press NEXT to go to next option. Press DONE at any
step to exit and save settings. Available options are 12- or 24-hour time format, MM-DD or DD.MM date format, hourly
chime N, beep for button presses, customizable mode set (Select “HIDE” for unwanted modes – they are removed
from mode sequence).
Timex has two ways to find information about your particular watch. Some of these models only have a guide consisting of a few pages. If you don't have the manual, Try this link:
Complete Timex link site:
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
I hope this helps you. Thanks, Bill
Aug 31, 2010 | Timex Watches
T301B Tme Zone
OK kalalist4,
You cand find the manuals for all Timex Clock/Radio conbinations at:
http://www.timexaudio.com/product_manuals.asp
Go Get 'Em
FixedThemAll.......
Oct 28, 2008 | Timex Auto-Set Dual Alarm Digital Clock...
Timex T303T Atomic Time Clock Radio With Dual Alarm set time zone
Go to the manual for this device located at the following web address;
Your solution is on page 14.
Aug 23, 2008 | Timex T309TT Clock Radio
Timex T5E881
You have to get in the right time zone, that’s why you are an hour off (and this may also occur if you are in an area that switches between daylight savings time each spring and fall).
Press mode until ZO appears on the watch face.
Press and hold ADJ. Time zone will begin to flash.
Select start/stop or adjust to get to the right time zone P, C, M, E (pacific, eastern, Mountain, central)
If desired , press mode to select DST (daylight savings time) and press start/stop or adjust to turn it on or off.
Press adjust when done.
Nov 10, 2007 | Timex 1440 Nylon watch
Timex T301B
Petewete,
Here is the manual.
http://www.timexaudio.com/pdf/T301IBOnline57204_83.pdf
Frank081541,
You can't adjust the Daylight Savings Time. I called Timex and they confirmed this.
Mar 06, 2007 | Timex Auto-Set Dual Alarm Digital Clock...
Timex T303T Clock Radio Logo
179 people viewed this question
Top Timex Audio Players & Recorders Experts
Janelle Schoonover
Janelle Schoonover
Steve Allison
Steve Allison
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
