Question about HP Photosmart 120 Digital Camera
Why does my battery gauge seem inaccurate? - HP Photosmart 120 Digital Camera
    Master:
  • 542 Answers
In a variable-load high power device such as a digital camera, the battery level indicator gives a prediction of remaining battery life, based on current rate of consumption. Since different operations consume different amounts of power, the battery gauge may appear inaccurate if changing the operations being performed by the camera, which changes the rate of power consumption.
Posted on Aug 30, 2005
SOURCE:
1995 Kawasaki ZZR 1100 inaccurate fuel gauge
Hi, Anonymous and the usual suspects are:
1. Blown instrument fuse.
2. Faulty sending unit.
3. Faulty wiring between sending unit and gauge.
4. Faulty ground or power connection.
5. Bad fuel gauge.
For more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
https://www.bikechatforums.com/viewtopic.php?t=270987
ZZR International View topic fuel gauge and consumption
Kawasaki Ninja ZX 11 Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 03, 2014 | 1995 kawasaki ZZR 1100
Why does my camera feel hot and says batteries are too low to take pictures (when I put brand new batteries in the camera).
Are these rechargeable batteries or disposable?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00613589&cc=ch&destPage=document&dlc=de&lang=fi&lc=en&product=1147860
The following link describes how to choose the right AA battery for your HP Camera.
Also this is the reason why your batteries say you are low (link is to the HP support page)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00613156&cc=ch&destPage=document&dlc=de&lang=fi&lc=en&product=1147860
The battery gauge predicts the remaining battery life, based on the current rate of use. Since digital camera operations such as focusing and using the strobe use battery power at different rates, the battery gauge may seem inaccurate until it adjusts to the new rate of power use. In addition, after changing settings or replacing the batteries, sometimes the camera takes a few minutes to determine how much charge is remaining in a battery. During that time, the battery gauge may not be accurate."
Sep 20, 2011 | HP PhotoSmart M627 Digital Camera
I have a Taylor Led scale #9876B ...I purchased maybe 2 mo ago , This is my 2nd one . The first one stopped reading my weight , and will say err. so I took it back , got a new one same kind , now this one...
I have the 9876 also. After 2-3 yrs it quit. W/ new battery it does the walking o's, then ERR1. I opened it and found that it uses a strain gauge, read by an MCU. The wires leading to the strain gauge were crushed between the top of the gauge and the plastic top cover. If I wiggle the wires I get a reading , but inaccurate. Then when they lose connection, there's no reading. Considering the slop in the metal links to the strain gauge, I don't consider it repairable.
Mar 29, 2011 | Taylor Health & Beauty
Gas Gauge goes way past emty all the time
I don't have a solution, but I can provide more details as I am having the same problem.
The gauge seems to drop below E at random times. It seems to only happen after the engine is turned off and restarted. The gauge will then move as if it is still sensing the fuel levels, but it is inaccurate as it has started below E.
I have taken my car to the dealership, and of course it didn't do it while it was there. It's getting pretty annoying and if anybody knows what the problem is, please share.
You can look at the electronic miles remaining gauge to see how much you have left, but I like things to work the way they're supposed to.
Aug 08, 2010 | 2004 Chevrolet Impala
2001 cadillac dts fuel gauge inaccurate as well as other DIC displays
disconect negative ground on battery, will reset computers...disc for about 2 min...and bingo,,youre good to go
Dec 08, 2009 | 2006 Cadillac DTS
Hyundai Elantra 2003. Fuel gauge seems to be inaccurate...why?
Faulty fuel tank sending unit or gauge or something in the tank-loose float maybe?
Nov 19, 2009 | Hyundai Motor 2003 Elantra
Accurate when still display changing inaccurate
You might have air bubbles trapped on surface of transducer. Use soap on it so water sticks to surface, no wax, oil, or grease.
If transducer is mounted inside the boat, you have air trapped between it.
Jul 12, 2009 | Uniden Qt206 Thru Hull, Digital Depth...
Fuel gauge inaccurate
Change the fuel gage sender unit in tank.its faulty.
May 30, 2009 | 2001 Jaguar S-Type
Fuel gauge inaccurate & warning light always on.
Hi. the inaccurate fuel gauge is easily fixed by replacing the fuel guage sending unit that is located in the fuel tank. this sending unit sends the appropriate signal the the gauge on the dash. all calculations are configured by the sending unit and if this device is malfunctioning, it will not send an accurate reading to the fuel gauge. simply replacing this device will fix the fuel guage issue you are having at this time.
Concerning the Amp drain after two days. this is caused by some sort of energy drain that can be in a faulty vacuum pump that isn't shutting off or, some sort of defect in the ECM. you could also have a faulty fuel pump relay that isn't shutting of and this will slowly drain energy from the battery within a two day period as well.
You can narrow down the battery drain by using a volt meter(needle) or multimeter. open the fuse box located on the drivers side below the dash. pull the fuse box door and expose the entire fuse box. you will need to pull each individual fuse independently to test if the actual slot is being used with the ignition switch in the off position.
Use the fuse slots contact prongs for testing the current level if any. with the ignition switch off, test all slots for live current feed. each slot that is dead is not affected and you may reinsert the respective fuse but, if you run across a live slot that is receiving a current while the ignition switch is in the off position, this specific slot will be the affected device that is draining the battery.
Test all fuse box slot accordingly. you will find the drain with this procedure.
Please rate and god bless:)
May 13, 2009 | 2003 Volkswagen Golf
Fuel gauge inaccurate 2002 Pontiac Bonnyville
this problem is caused by the sending unit inside the fuel tank, very common problem.
Feb 15, 2009 | 2002 Pontiac Grand Prix
HP Photosmart 120 Digital Camera Logo
53 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
