Question about Microsoft Xbox 360 Console
Xbox 360 we have a number of problems 1. no power to the fan 2. no power to the cd tray
  • 3 Answers
Hey, check out this page. It's got a good rundown of common problems.
http://www.squidoo.com/Xbox_redlight_fix
Most likely, it sounds like some power connections are short and need to be patched.
Posted on Aug 23, 2008
Tray stuck open
The gears on the Xbox 360 have become misaligned. Here is how you fix it. If the tray is out all the way disconnect the power.
Step 1:
Locate the tab on the left side of the tray.
Step 2:
Lift the tab with a pen or equal and pull the tray out.
Step 3: power on the Xbox 360 and hit the eject button. When you here the eject "ding" pull the power. Now the drive is in eject mode and the cogs are aligned to take the tray.
Step 4
Gently place the tray back in and slight nudge to engage gears.
Step 5
POwer on xbox 360 and give another nudge to help the tray realign.
Step 6
Open and close the tray a couple times. To assure sucess.
Aug 20, 2014 | Microsoft Xbox Video Game Consoles & Games
My xbox 360 lens is drity how do I clean it
There are a few ways.
1.Use a CD Cleaner, it looks like a regular CD but has brushes on the bottom of it.
2.Can of compressed air w/nozzle extension. Open the CD Tray and pull the power from the wall so that the tray can be moved around. Push the tray about halfway in then insert the nozzle to right above the CD Lens and give it a few shots of air. A flashlight can help with finding the lens.
3.Disassemble your 360, do not forget this voids any warranty. Once you have the case open, take out the CD Drive. Open it up, get rid of any dust and clean the lens really good. While it is open, clean out the fans, vents and heat sink which will help with cooling.
Hope this helps.
Apr 06, 2010 | Microsoft Xbox 360 Console
XBOX 360 cd rom is not reading discs
1. Make sure you REMOVE any discs from your XBOX' tray. 3. Turn on the console again, either by using the controller or the POWER button (NOT the EJECT button) and WAIT for the initial XBOX setup. ... This fixes the OPEN TRAY error 100 % of the time on my XBOX 360. XBOX 360 cd rom is not reading discs Google Search
Jan 13, 2018 | Microsoft Xbox 360 Console
360 wont read discs "open tray"
Sounds like a dirty lens. Have had this same problem many times.
2 easy ways to clean it are:
1. Buy a cheap lens cleaner, it looks like a cd with brushes on it.
2. Open up the tray and pull the power when it is halfway open. Take a can of compressed air with an extension and blow all dust off the lens.
Sep 05, 2009 | Microsoft Xbox 360 Console
CD tray will not work
mine has the same problem.
1. turn your xbox sideways
2. press the open disk tray button
3. hit your xbox on the curve, above the disk tray
it works for me
May 02, 2009 | Microsoft Xbox 360 Console
Xbox 360
you need to send it off to get repaired
Aug 26, 2008 | Microsoft Xbox 360 Console
Dead Xbox 360
Yes, the power brick has a yellow/orangeish light, It does not turn green when I try to power on the console.
Aug 20, 2008 | Microsoft Xbox 360 Console
Xbox 360
THINGS TO TRY loadTOCNode(1, 'whattotry'); 1. If possible, remove any discs that are in the tray. 2. Push the eject button to close the tray. 3. If the tray won't close and seems to be stuck, gently move the tray up, down, and to the side. 4. Check around the disc tray and make sure the faceplate is fitted correctly. If the faceplate isn't fitted correctly, the disc tray may not be able to close. 5. If the tray still does not close, contact Xbox Customer Service.
Jul 30, 2008 | Microsoft Xbox 360 Console
Disk Tray
Hi! This is a very rare problem. I personally don't know how to fix it but if you have purchased your XBOX 360 in the last 3 years you will have free warranty on it. You may call Microsoft and they will help you troubleshoot and solve/fix your problem. They will explain how the process works once you call. Here is their number:
1-800-4MY-XBOX
(1-800-469-9269)
I hope you get your problem reslolved! :)
Jul 21, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
23 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
