The tape gets stuck and the vcr starts eating the tape and it wont' come out unless pulled and then the tape may break trying to get it out Thanks. Janis Pearson jcpinca@att.net
  • 883 Answers
SOURCE: Eating tapes and then refuses to work
try opening the case. then, using your fingers, roll the gear that drives the tape eject mechanism until a full tape eject limit is reached. power up and try
Posted on May 20, 2007
  • 883 Answers
SOURCE: Eating Tape when rewinding in vcr mode
look for a tiny pinhole and insert a pin while powered up to reset the device. if no-go, then the take-up reel needs attention...needs possibly a new or well-cleaned-with-alcohol-swab rubber belt
Posted on May 27, 2007
sharcnet
  • 2130 Answers
SOURCE: Eats tapes
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through. The pincher wheel & capstan are not used during a fast forward or fast rewind, so if your tape is getting caught during the FF or RW and not Play, it's probably not related to capstan & pincher wheel.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
3. You didn't say if the unit played ok. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
So when when you hit eject, the excess tape that should have been wound up tight in the cassette before the eject sequence, is getting caught inside the player.
Let me know if I can be of further assistance to you.
- Jim
Posted on Feb 07, 2008
sharcnet
  • 2130 Answers
SOURCE: vcr eating tapes
Let me know if you need more information as to where to purchase these parts.
- Jim
Posted on Feb 12, 2008
SOURCE: I have a sony vcr
SYMPTOM: Unit does not load or eject. RESOLUTION
Replace slider with new part number 397744203
SYMPTOMS
No playback video.
RESOLUTION
Located and removed solder short between pins 9 and 10 on IC1201.
For error codes for this model, you might need the full service manual.
Contact me at billyjones@fletchersite.com if you need this.
Posted on Mar 16, 2008
Tape got stuck now when trying to eject makes noise then turns off
Good day
Your tape break off inside VCR? Look for broken piece & remove (very carefully)!
RESIST all temptation to touch the drum head! They are very sensitive, & can be ruined easily.
If no broken tape inside, you may have a "broken tire"..a tape spool drive rubber ring.
It's repairable but best bet to find an electronics technician.
The trouble I really suspect is
The loading drawer! There are wee flimsy plastic gears that "pull" the tapes in etc,..they break,...not work after. Need to replace broken parts. Glue won't solve those for long...I've had short-term success.
Mar 11, 2011 | RCA VR622HF VHS VCR
Toshiba VCR
Check this link it has some solutions that you can try in removing the tape inside the VCR http://www.fixer.com/no-eject.html
Hope that helps...........
Sep 12, 2008 | Televison & Video
In Mar.89 I bought a VCR Model HS-U50. Works great BUt a tape is now stuck in the cassette loading slot and while the Power button comes on and I try to eject the tape, since it wont come out or eject, the...
I took the cover off and noticed the tape was wrapped all around some wheels and unwrapped the tape from the wheels and got it out. Ate the tape up BUt at least its out. However, I tried a new tape and can now see what the problem may be. It keeps on eating the tapes, they get all scrunched up inside around various wheels and while I can get it out, each tape is mangled and beyond use. So something is causing the VCR to incorrectly wrap the tape around each aligned whlle. Dont know how to fix this , BUT since I wont be able to get parts or help on here to do it by myself, Can you be kind enough to find me a repair service outlet in Ottawa, Ontario, canada.
Dec 26, 2009 | Mitsubishi Televison & Video
VCR is eating tapes
There are different reasons that a VCR could start eating tapes. It could that it just needs a good cleaning or it could have a mechanical problem you will really need to have it checked out by a service center to determine why. If you have small children I would check it for signs of “peanut butter sandwiches. J
Nov 29, 2009 | Philips Magnavox DVD/VCR Dual Player
Tape Problem
3. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
- Jim
Jun 27, 2008 | Mitsubishi HS-U776 VCR
Vcr eating tapes
- Jim
Feb 12, 2008 | Philips Magnavox 20MC4304 20 in....
VCR stops, ejects, eats tapes
clean the heads and retime the gears.
Nov 24, 2007 | Symphonic WF802
Tape stuck in vcr
If the tape is really stuck, your only resort will be to unscrew the cover off the unit and get to the assembly where the tape heads are. You can just simply pull the tape out (carefully). Some of the tape might still be spooled on the capstans or pinch rollers.
Mike
Nov 13, 2007 | Sony RDR-VX530 DVD Recorder/VCR
VCR Eats the tapes
Often the "Pinch Roller" type Tape Drive can "Dry Out" and it slips. this causes the tape to get all screwed up.. It could also be a belt that turns the capstan.. Or even a thing called the "Mode Switch" In any event Ya probably be best to take it in for repair as it's not really a "Homer" I suggest ya get a quote and an explanation, and see if it is economically worthwhile?
Aug 22, 2007 | Sony SLV-D550P DVD Player/VCR
Nov 16, 2006 | Symphonic SL260A S-VHS VCR
Televison & Video Logo
231 people viewed this question
Top Televison & Video Experts
