Remove the front cover from the TV set. This is held by a snap on. Pull the front cover outwards until the quick snap on disengages.
Remove the screw securing the lamp cover with a Phillips head screw driver
Remove the two screws that hold the lamp in place. Remove the lamp unit by holding the lamp handle, then pulling outwards.
Exercise caution when removing the lamp unit to avoid injury to your fingers
Replace with the new lamp.
Place the removed lamp into the empty box of the replacement lamp. Do not touch the front glass of the new lamp or its
receptacle. This may shorten the life of the lamp and reduce the picture quality.
• Push the lamp unit back to its original position.
• Tighten the screws firmly on the lamp unit. If they are loose, the TV may not operate correctly. Install the front cover. There is also a video on youtube just do a search on how to install a projection lamp. Hope this is helpful
i have a hitachi 60 something inch rear projection hstv that i need to replaice a lamp on it need help on it
