I have surround sound stereo and i am tryng to hook it up to a sylvania 6620LF4 t.v., i tried plugging the audio cables into the headphone jack and it didn't work, so i tried headphones to make sure that the jack worked.
  • 44 Answers
You'll need an Audio Out connection on the tv for surround to work properly. The signal level and the impedence mismatch of a headphones jack would not work or work poorly.
Posted on Aug 22, 2008
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
How do i connect my soni bravia television to internet
Hook up a computer to it. The tv could have an hdmi connector or monitor connector (check the back of the television to see which type of connectors you have available) so just plug a cable in from your pc to the tv.
For sound, a simple computer cable plugs into the headphone jack of the computer to the back of the television. If you have a PC, you may have a series of connectors for stereo surround sound systems (like a sound card). I use a simple jack that plugs into the headphone jack (stereo speaker jack) and also plugs into the pc audio in port on the tv. Now I just select the input (pc) from the sony menu and select the option for sound input and voila. As long as the pc is connected to the internet, your tv is your new monitor.
Feb 23, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Hello, I have a Sony STR-D85 surround sound system. I need to connect my phone to the system so that my phone's music plays through my surround sound speakers. The front of the console has a headphone...
Headphone jack is an output not input jack. Your going to need a cord to go from your headphone jack(output) of your phone to audio input on your receiver. The cord has a mini stereo plug to the phone and RCA plugs of left and right to your receiver auxiliary input. Good luck..
Jul 15, 2011 | Sony STR-DE485 Receiver
I need to connect a surround sytem to my tv but cannot find an audio out on it
Depending on the TV you have and the surround sound system you can use the following:
An optical out cable.
Headphone jack to headphone jack (a cable with a 2.5mm headphone jack on both ends) you then plug this into the headphone jack in the TV and the other end into the audio in jack in your surround sound system.
You can also use a standard scart lead to plug into your TV and surround sound system.
May 03, 2011 | Televison & Video
Im trying to find out where my audio outputs are so i can hook up my surround sound to it..
Hi, if you r are referring to t.v. connections, some flat screens only have 2 audio outputs-one is actually lti up with a reddish glow and is squarish in shape, this is a fiber optic connection that goes to the back of the receiver ( using a toslink connector ) the other audio out may be a small 1/8 inch( 3.5mm) stereo headphone jack-use a stereo headphone to rca adapter cable to plug into an audio input on the receiver. Thanks for asking FixYa, I hope this was of some help, and good luck-Prodzilla
Apr 20, 2011 | Audio Players & Recorders
I have a panasonic tv and i need to know how to hook up home theather system lenoxx electronics model HT 3915
Hi, the Panasonic t.v. more than likely has more than one kind of output. One of them should be actually lit up with a red glow around the edges, that is the fiber optic digital sound output. It's called a" TOSLINK" connector and is plugged into a matching jack on the surround sounds rear panel. The t.v. may also have a "LINE OUT", " T.V. AUDIO OUT " or " FIXED AUDIO " output this may be in the form of a small 3.5mm stereo headphone jack ( i still call them 1/8 in. plugs) this you can plug into the surround sounds line input on the back panel. If the line input on back of the theater system is rca just use a stereo headphone plug to rca adapter. I hope this helped and thanks for choosing FixYa, good luck-Prodzilla
Apr 15, 2011 | Durabrand HT-3915 System
How can I hook my computer to my surround sound so i can hear my music loud enough
One easy way is to purchase an audio adapter. It has the two red and black audio jacks with the one male audio plug, like for the headphone jack. Then you go from the back of the PC were you normally put your stereo speakers with the male piece, then plug your audio jacks into an auxiliary spot on your stereo.
May 20, 2010 | Compaq Computers & Internet
Can't connect wireless stereo to sylvania 6620LF4
you can hook this particular unit up to your stereo reciever if available. if i am not mistaken the original design purpose of these headphones were to be powered through a stereo reciever, at least it is a sure fire way of keeping your tv's sound in tact and using the headphones when needed. most receivers have a speaker a and speaker b configuration if you attach the lead from the headphone unit to the opposing speaker input then you can have the functions you desire and the performance you have indicated. hopes this fixya.
Best regards
Ryan
Feb 19, 2009 | Sylvania 6620LF4 20 in. EDTV-Ready LCD...
Can i hook a surround sound to my zune
It is usually as simple as getting a 3.5mm stereo headphone jack to RCA adapter, like this one:
http://www.radioshack.com/product/index.jsp?productId=3359117 (this will work just fine, even though it says 'ipod')
Or they have "Zune Ready" adapter kits, like this one:
http://www.radioshack.com/product/index.jsp?productId=3004031
Once you have the cable, you stick the headphone plug (3.5 mm stereo mini-phono) into the headphone jack on your Zune, then you insert the red and white RCA jacks into an open input on your surround receiver... most have an auxilliary input jack set on the front of the unit. All you need to do at this point is select the "aux input" for the source on the surround receiver, start your Zune, and make sure the volume on the Zune is somewhere in the 50 - 75% range, and you should be good to go.
Dec 08, 2008 | JVC THD-50 System
No sound with new Vizio 22" LCD TV being used as monitor
you have to hook up the 1/4 headphone jack plug to the TV, from the computer. an Y audio cable with RCA plug (male) with headphone 1/4 male plug. hook the headphone jack to the green hole of the computer(sound out) to the audio input of the TV better yet to a stereo AUX port. also make sure the mute button hasnt been pressed.
Jun 03, 2008 | Dell Dimension 4600 PC Desktop
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
