Question about Mitsubishi VS-50607 50" Rear Projection Television
My 60" mitsubishi tv won't come on
My tv won't come on, it was working perfectly then all of a sudden it started showing timer minutes and it went off. when i turned it back on it wouldn't come.I reset it, it still won't come on, i don't know what to do.
  • JPA1978 Dec 10, 2008
    I have the same problem. Sometimes my TV will just not turn on and the green reset button just flashes forever. The first time I paid $400.00 for the repair guy to replace what he called a cap kit. 5 months later the same thing happened and he came over under warranty and fixed it in about 3 minutes. I got robbed! What is the fix? Also I have a black box that appears and covers most of my screen. I can make it go away b pushing a button EXC. But once you touch anything like channel or volume it reapears after a few seconds. It is annoying. Help please.
  • Anonymous May 22, 2009
    mitsubishi 60 in projection tv won't come on, thought i hit timer on remote because i saw sleep timer come up on tv, it did not go right off but about 15min later did. i can't get it to come back on. already tried unplugging and resetting , however green power light not even coming on
Posted on Sep 10, 2008
SOURCE:
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
WD-65734 Mitsubishi TV won't turn on. System reset
Are there any lights lit on the front of the TV? Have you checked for a bad lamp? When you reset the TV the timer/power light should flash on and off rapidly for 60-70 sseconds. Does that happen?
Aug 26, 2011 | Mitsubishi WD-62526 Projection TV
I have a sony grand wega 42we655 projection TV and i have a yellow spot on the right hand side of the TV. it looks like an X in the middle of it. any ideas? TV works fine otherwise. Thanks.
I have a mitsubishi 60 " that I got jan 2009 got up to turn it on and it went to green timer light audio is on but no picture turns off in little bit hit reset button but the timer light blinks
Mar 07, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blinking timer light will not turn off.
You most likely have a fault in the defelection circuitry that is causing this. A repair is needed, none-the-less....accordianman
Jan 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
RCA P60921 60 in. Rear Projection not working
could be the flyback as some eat them depends on how old it is, and what model it is be more specific. also possible high voltage divider box
Nov 11, 2008 | RCA P60921 60" Rear Projection Television
Flashing Tv screen
Turned out to be a problem with my dish receiver. Found out by attaching a separate DVD unit to the TV, and it didn't flash. I then realized everything ran through the dish receiver. Called them, reset ( by unplugging for 90 seconds) and all was well.
Jul 20, 2008 | Mitsubishi VS-60111 60" Rear Projection...
Locked Channel
try settings and the set all data to factory default or restore to factory settings, then you my start new installation. Jkahangwa
Jun 05, 2008 | JVC AV-27230 27" TV
Mitsubishi (2001 ?) 60 inch projection TV Model VS-60609. DVDs and video games work perfectly but NO tv reception- we have Comcast. I've plugged cable into every possible hole on the TV- no luck. THX!
My mitsubishi 2001 tv model 60609 plays sometimes for a couple of minutes and then turns off; but you can still hear the volume and if you try to turn it back on it will turn right back off.
please help me!
Apr 23, 2008 | Televison & Video
Mitsubishi VS-50607 50" Rear Projection Television Logo
108 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
