Question about Brother ML-300 Typewriter
Garbage inside the wheel
Hi I have a Brother ML 300 typewriter and it has a lot of garbage inside like stickers for folders.
How can I open it to clean it?
  • cinleiva Aug 22, 2008
    the garbage is not insede the wheel, is all over the wheel
    Scholar:
  • 183 Answers
Take off the ribbon, pull the lever on the right of the print hammer, remove the printwheel and carefully remove any foriegn objects. when you put the P/W back in make sure the side with the letters is facing the platen
Posted on Nov 01, 2008
How do I get the spacebar to work
keyboards do get dirt inside so that it cant make contact or it could be a bad circuit board in the keyboard
Aug 25, 2014 | Brother "Ml300 - Ml-300 Electronic...
Need new 3 pitch pinwheel for Brother ML 300
I don't Believe that there is such a thing, there are 10/12 wheels.
DickyO
Mar 30, 2013 | Brother ML-100 Typewriter
I have a customer who bought a Brother ML 300 typewriter a little over a year ago. When she is typing, and then hits return, the printwheel is not hitting the paper. I checked the printwheel to be sure...
Hi - there a many reasons why this happens. Try these first. Replace the ribbon. This might have become tight (faulty) and make this happen. Nasty fault? maybe the power supply has caused error and lacks power in the hammer to hit the back of the print wheel.
Jan 04, 2011 | Brother ML-300 Typewriter
ML-300 Typewriter: different characters appear than what is typed...
To resolve this issue, you will need to replace the daisy wheel.
May 17, 2010 | Brother ML-300 Typewriter
How do I set left margin for brother model ML-300
Go to brother.com, click on support you will find a downloadable manual there.
DickyO
May 11, 2010 | Brother ML-300 Typewriter
The correction tape wheel is broke.
Check on the brother website for on authorized service center. They should be able to repair this for you. Try the link below.
http://www.brother-usa.com/service/default.aspx?PGID=10
Mar 26, 2010 | Brother ML-300 Typewriter
Can parts be changed out
Hello-
Yes. The Brother ML 300 and the Brother ML 500 use the same products (Typewriter Ribbon, lift off tapes and Daisy Wheels).
Take care,
Duane ONeil
www.FJAproducts.com
800-982-9989
Jun 03, 2009 | Brother ML-500 Typewriter
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
Brother ML-300 Typewriter Logo
55 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
