Question about ViewSonic VX924 19" LCD Monitor
Black screen, blinking power light, no signal
Had my monitor for less then 6months now. Basically when I power on my PC the monitor displays the start up screens Untill the windows start up screen, where the monitor goes to black. The power light blinks for awhile, untill a message on the screen says "No signal" and the power light goes from green to orange. Multiple restarts (15-20) sometimes fixes the problems, not always.
I've gotten to cables, new vid card
Its a software bug in the monitor. Mine has done this since new. There is a race condiction between the monitor starting and Windows Starting. If the monitor starts faster then it thinks that there is no DVI connection and it will then revert to VGA mode. Try this to fix it, unplug the monitor from the wall (leave the PC ON), wait 1 minute and then pulg it back in.
EAV
Posted on Nov 13, 2011
    Champion:
  • 293 Answers
Hi...there,
It's seems you got a defective DVI card. Try using a VGA cable instead. Have nice day!
Posted on Sep 08, 2008
I have a acer.x223w when,it powers up the.screem stays black, n i get a blue blinking light on.the bottom
I disagree with ikkenom only due to the symptom of the flashing blue light. This would indicate to me that the monitor is not getting any display signal and is in sleep mode at least the is what happens on my Samsung monitor. Used to be that they use a two color led in the monitor, green when ON and getting display signal and amber or orange when in sleep mode. I would check the computer by trying a different monitor. If you have a second monitor, great, if not, maybe a friend will let you bring your computer over and try the computer with their monitor. Could also be a display adapter setting. Do you get any change when you first turn on your computer? i.e. Do you get the BIOS or manufacturer screen when first turned on? Also if you disconnect the monitor cable from the computer and power cycle the monitor, do you get a No Signal display for a few seconds before the monitor goes black and the blue light starts flashing?
Let me know what happens with the testing above or if you need further instructions to carry out testing.
Thanks, Jim
Feb 21, 2013 | Computers & Internet
Apple Cinema HD Display 30'' black screen, power light blinking
I don't know what might have happened, but a number of years ago I had an apple monitor and the power light on it started blinking, so I got in touch with apple and they told me that it's flashing an error code, so they told me what the blinking indicated and fixed it.
So I think the blinking of the power light on your monitor could be indicating an error code so I suggest you call apple and they will identify what the error is indicating.
Feb 11, 2010 | Apple Cinema HD 30" LCD Monitor
The system unit is started but the monitor is making black so, what is the problem , pleas tell me the solution
first check your monitor front power light blinking or not.
if it's blinking then then remove the signal cable to the cpu then check the company logo moving in the monitor.if it's moving means your monitor is OK.means no display in *********** board.
Jan 08, 2010 | Computers & Internet
After starting the computer the screen is black and only displays digital analog on screen and the blue light is flashing. It then displays a box say "check signal digital analog." please help me. Thanx.
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
Dec 02, 2009 | Samsung Syncmaster 940BW LCD Monitor
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? Monitor will go on for a split second, then screen will go...
they normally turn off like this when they aren't receiving a video signal from the pc (same as when you turn off the pc). make sure that it is connected properly, and that the video output is activated. try disconnecting from the other monitor while its on and connect the problem monitor...if it still isn't working then there may be a problem with the cable or the monitor itself. Try another VGA or DVI cable. Hope this helps
Mar 29, 2008 | Computers & Internet
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
My monitor will only blink a black or white screen.
check the warranty online for your screen.. go the the acer support website and look up warranties, and it will ask for a really long number on the back of your screen, and it will tell how long the warranty is good for and what to do with it.
Mine is doing the same thing. flashes white then black and that is all
Dec 31, 2007 | Acer AL2016WBbd Monitor
Dell monitor
Monitor Help CH000315, Black borders on side of screen. CH000316, Dead or black pixels. CH000403, Macintosh and/or PC monitor compatibility.
Black borders on side of screen. Additional information about what causes black borders on computer displays.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
ViewSonic VX924 19" LCD Monitor Logo
547 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
