Question about HP Photosmart 120 Digital Camera
When a camera is inoperable or fails to function, or an error code appears in the liquid crystal display (LCD)
    Master:
  • 542 Answers
Follow the steps below in the order presented: Perform a power reset on the camera. Performing a power reset on the digital camera will normally correct issues such as the camera locking up or not turning off. When the power reset is performed properly, the camera will prompt you to update the camera’s date and time. This is an indication that the memory has been cleared and no further reset time is required. The power reset procedure must only be performed on a camera that has been running on battery power. If an AC power adapter is being used, the power reset procedure does not apply. This is due to the fact that the internal capacitor is fully charged. To execute a camera power reset, perform the following steps: Turn off the Digital Camera. Remove the Compact Flash Card or Secure Digital Card, if one is being used. Turn on the Digital Camera. CAUTION: To avoid damaging the camera, ensure the shutter button is not pressed during the following steps. Turn on Live View on the rear LCD. CAUTION: Care should be used when performing Step 5 to ensure that the camera is not dropped. Open the battery door and remove the batteries with the camera turned on. Re-insert the batteries after five minutes have elapsed. Turn on the camera. The camera should request an update for date and time (with the exception of the HP Photosmart 120 and 912 series cameras). Format the memory card. Navigate to the delete menu which varies with each camera, and format the internal memory and/or the memory card. CAUTION: Reformatting the memory card erases all of the files that are stored in the card. All photos, scripts, and miscellaneous files are deleted permanently. To preserve the existing images, use a spare card or a card that is already formatted.
Posted on Aug 30, 2005
SOURCE:
White LCD Screen disolay.
Sadly it sounds like the screen has been broken, often times any white on an lcd screen mean that the liquid crystals have been damaged, most likely from dropping the camera or bumping it into something. I had the same thing happen to an old camera of mine. Sorry for the bad news, but it is probably just as or more expensive to fix the screen than it is to just buy a new camera unless it is a very expensive professional camera.
Dec 04, 2013 | Olympus FE-370 Digital Camera
My hp lcd monitor screen is accidently suffered a pin hole. how to plug this pin hole to make screen normal and prevent white light from escaping from screen and read words on that part of screen which get...
LCD is Short for liquid crystal display, a type of display used in digital watches and many portable computers. LCD displays utilize two sheets of polarizing material with a liquid crystal solution between them. An electric current passed through the liquid causes the crystals to align so that light cannot pass through them. Each crystal, therefore, is like a shutter, either allowing light to pass through or blocking the light.
If you have a "hole" in it then you will most likely have to replace the display.
Aug 29, 2013 | HP Computers & Internet
Hi I have a fisher and paykel clothes washer model WA75T65GW it is displaying what i assume is an error code. green lights 3 and 4 light up along with red light 8 and it beeps continuously. Could you...
(00011001) Phase 5 IW - LCD Initialisation Error
The Intuitive Display has detected a problem with the LCD. Liquid Crystal Display
Primary Source: IW Display Module
Action: Replace IW Display Module
Oct 28, 2012 | Washing Machines
Dropped tv, and know there is ink running down the screen
Liquid crystals have cracked. TV needs a new liquid crystal array. Basically buy a new TV sorry.
May 04, 2011 | LG Televison & Video
Broken lcd, how can we go about it.
Call HP to determine if the unit is still in-warranty, and they will be replacing it. Otherwise, you may have to upgrade it through their Out-of-Warrranty programs.
Feb 13, 2011 | HP Compaq Presario V2555US Notebook
Meaning of LCD TV?
Dec 21, 2010 | Computers & Internet
Z740 Error code B03
Error message appears on EVF/LCD screen
  • Turn the camera off, then on again.
  • Remove memory card from the camera.
  • Remove the battery and wipe the contacts with a clean, dry cloth ( Battery life).
  • Insert a new or charged battery ( Loading the batteries).
  • If all else fails, get customer support help
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Nov 28, 2007 | Kodak EasyShare Z740 Digital Camera
HP Photosmart 120 Digital Camera Logo
151 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
